GitLab
Explore
Primary navigation
Search or go to…
Chameleon
Manage
Plan
Issue boards
Code
Merge requests
Repository graph
Compare revisions
Build
Pipeline schedules
Artifacts
Deploy
Package Registry
Container Registry
Operate
Environments
Terraform modules
Monitor
Service Desk
Analyze
Value stream analytics
Contributor analytics
CI/CD analytics
Repository analytics
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
solverstack
Chameleon
119abf39
119abf39
7 years ago
PRUVOST Florent
Downloads
Patches
try without -j5
a3619304
.gitlab-ci.yml
+1
-1
1 addition, 1 deletion
.gitlab-ci.yml
1 addition
1 deletion
.gitlab-ci.yml
119abf39
@@ -19,7 +19,7 @@ build_starpu:
mkdir -p build
mkdir -p build
cd build
cd build
cmake .. -DCHAMELEON_USE_MPI=ON -DCMAKE_INSTALL_PREFIX=${PWD}/install -DCMAKE_VERBOSE_MAKEFILE=ON -DMORSE_ENABLE_WARNING=ON -DMORSE_ENABLE_COVERAGE=ON
make
-j5
| tee ../chameleon-build.log
make | tee ../chameleon-build.log
make install | tee -a ../chameleon-build.log
test_starpu
test_starpu
This diff is collapsed.
Loading
Save comment
