{"mtxfmt","Change the way the matrix is stored (0: global, 1: tiles, 2: OOC)",-32,PARAM_OPTION|PARAM_INPUT|PARAM_OUTPUT,1,6,TestValInt,{0},NULL,pread_int,sprint_int},
{"profile","Display the kernel profiling",-33,PARAM_OPTION,0,0,TestValInt,{0},NULL,pread_int,sprint_int},
{"forcegpu","Force kernels on GPU",-34,PARAM_OPTION,0,0,TestValInt,{0},NULL,pread_int,sprint_int},
{"splitsub","Wait for whole graph submission before execution",'S',PARAM_OPTION,0,0,TestValInt,{0},NULL,pread_int,sprint_int},
{"hlvl","Tree used for high level reduction between nodes",-23,PARAM_OPTION|PARAM_INPUT|PARAM_OUTPUT,2,4,TestValInt,{0},NULL,pread_int,sprint_int},
{"domino","Enable/Disable the domino between upper and lower trees",-24,PARAM_OPTION|PARAM_INPUT|PARAM_OUTPUT,2,6,TestValInt,{0},NULL,pread_int,sprint_int},
{"tsub","Graph submission time in s",999,PARAM_OUTPUT,2,13,TestValFixdbl,{0},NULL,pread_fixdbl,sprint_fixdbl},
{"time","Time in s",1000,PARAM_OUTPUT,2,13,TestValFixdbl,{0},NULL,pread_fixdbl,sprint_fixdbl},
