Commit 0fe141f4 authored by Mathieu Faverge's avatar Mathieu Faverge
Merge branch 'documentation/guix_packaging' into 'master'
doc installing: add guix and spack recipes
See merge request solverstack/chameleon!184
parents efd04f4d 5b2125b6
...@@ -72,9 +72,9 @@ we encourage users to use [[sec:spack][Spack]]. ...@@ -72,9 +72,9 @@ we encourage users to use [[sec:spack][Spack]].
# Install StarPU (with MPI and FxT enabled) # Install StarPU (with MPI and FxT enabled)
mkdir -p $HOME/install mkdir -p $HOME/install
cd $HOME/install cd $HOME/install
wget http://starpu.gforge.inria.fr/files/starpu-1.2.6/starpu-1.2.6.tar.gz wget http://starpu.gforge.inria.fr/files/starpu-1.3.3/starpu-1.3.3.tar.gz
tar xvzf starpu-1.2.6.tar.gz tar xvzf starpu-1.3.3.tar.gz
cd starpu-1.2.6/ cd starpu-1.3.3/
./configure --prefix=/usr/local --with-fxt=/usr/lib/x86_64-linux-gnu/ ./configure --prefix=/usr/local --with-fxt=/usr/lib/x86_64-linux-gnu/
make -j5 make -j5
sudo make install sudo make install
...@@ -262,25 +262,231 @@ we encourage users to use [[sec:spack][Spack]]. ...@@ -262,25 +262,231 @@ we encourage users to use [[sec:spack][Spack]].
with CUDA releases from versions 4 to 7.5. Your compiler must be with CUDA releases from versions 4 to 7.5. Your compiler must be
compatible with CUDA. compatible with CUDA.
** Distribution of Chameleon using GNU Guix
<<sec:guix>>
We provide [[http://guix.gnu.org/][Guix]] packages to install Chameleon with its dependencies
in a reproducible way on GNU/Linux systems. For MacOSX please refer
to the next section about Spack packaging.
If you are "root" on the system you can install Guix and directly
use it to install the libraries. On supercomputers your are not
root on you may still be able to use it if Docker or Singularity
are available on the machine because Chameleon can be packaged as
Docker/Singularity images with Guix.
*** Installing Guix
Guix requires a running GNU/Linux system, GNU tar and Xz.
#+begin_src sh
gpg --keyserver pgp.mit.edu --recv-keys 3CE464558A84FDC69DB40CFB090B11993D9AEBB5
wget https://git.savannah.gnu.org/cgit/guix.git/plain/etc/guix-install.sh
chmod +x guix-install.sh
sudo ./guix-install.sh
The Chameleon packages are not official Guix packages. It is then
necessary to add a channel to get additional packages. Create a
~/.config/guix/channels.scm file with the following snippet:
(cons (channel
(name 'guix-hpc-non-free)
(url "https://gitlab.inria.fr/guix-hpc/guix-hpc-non-free.git"))
%default-channels)
Update guix package definition
#+begin_src sh
guix pull
Update new guix in the path
#+begin_src sh
PATH="$HOME/.config/guix/current/bin${PATH:+:}$PATH"
hash guix
For further shell sessions, add this to the ~/.bash_profile file
export PATH="$HOME/.config/guix/current/bin${PATH:+:}$PATH"
export GUIX_LOCPATH="$HOME/.guix-profile/lib/locale"
Chameleon packages are now available
#+begin_src sh
guix search ^chameleon
Refer to the [[https://guix.gnu.org/manual/en/guix.html#Invoking-guix-package][official documentation of Guix]] to learn the basic
commands.
*** Installing Chameleon with Guix
Standard Chameleon, last release
#+begin_src sh
guix install chameleon
Notice that there exist several build variants
- chameleon (default) : with starpu - with mpi
- chameleon-cuda : with starpu - with mpi - with cuda
- chameleon-fxt : with starpu - with mpi - with fxt
- chameleon-simgrid : with starpu - with mpi - with simgrid
- chameleon-openmp : with openmp - without mpi
- chameleon-parsec : with parsec - without mpi
- chameleon-quark : with quark - without mpi
Change the version
#+begin_src sh
guix install chameleon --with-branch=chameleon=master
guix install chameleon --with-commit=chameleon=b31d7575fb7d9c0e1ba2d8ec633e16cb83778e8b
guix install chameleon --with-git-url=chameleon=https://gitlab.inria.fr/fpruvost/chameleon.git
guix install chameleon --with-git-url=chameleon=$HOME/git/chameleon
Notice also that default mpi is OpenMPI and default blas/lapack is
Openblas. This can be changed with a [[https://guix.gnu.org/manual/en/guix.html#Package-Transformation-Options][transformation option]].
Change some dependencies
#+begin_src sh
# install chameleon with intel mkl to replace openblas and nmad to replace openmpi
guix install chameleon --with-input=openblas=mkl --with-input=openmpi=nmad
*** Generate a Chameleon Docker image with Guix
To install Chameleon and its dependencies within a docker image
(OpenMPI stack)
#+begin_src sh
docker_chameleon=`guix pack -f docker chameleon chameleon --with-branch=chameleon=master --with-input=openblas=mkl mkl starpu hwloc openmpi openssh slurm bash coreutils inetutils util-linux procps git grep tar sed gzip which gawk perl emacs-minimal vim gcc-toolchain make cmake pkg-config -S /bin=bin --entry-point=/bin/bash`
# Load the generated tarball as a docker image
docker_chameleon_tag=`docker load --input $docker_chameleon | grep "Loaded image: " | cut -d " " -f 3-`
# Change tag name, see the existing image name with "docker images" command, then change to a more simple name
docker tag $docker_chameleon_tag guix/chameleon-tmp
Create a Dockerfile inheriting from the image (renamed
=guix/chameleon= here):
#+begin_src sh :eval no :tangle Dockerfile :export none
FROM guix/chameleon-tmp
# Create a directory for user 1000
RUN mkdir -p /builds
RUN chown -R 1000 /builds
ENTRYPOINT ["/bin/bash", "-l"]
# Enter the image as user 1000 in /builds
USER 1000
WORKDIR /builds
ENV HOME /builds
Then create the final docker image from this docker file.
#+begin_src sh
docker build -t guix/chameleon .
Test the image
#+begin_src sh
docker run -it guix/chameleon
# test starpu
STARPU=`pkg-config --variable=prefix libstarpu`
mpiexec -np 4 $STARPU/lib/starpu/mpi/comm
# test chameleon
CHAMELEON=`pkg-config --variable=prefix chameleon`
mpiexec -np 2 $CHAMELEON/bin/new-testing/snew-testing -H -o gemm -P 2 -t 2 -m 2000 -n 2000 -k 2000
*** Generate a Chameleon Singularity image with Guix
To package Chameleon and its dependencies within a singularity image
(OpenMPI stack)
#+begin_src sh
singularity_chameleon=`guix pack -f squashfs chameleon --with-branch=chameleon=master --with-input=openblas=mkl mkl starpu hwloc openmpi openssh slurm hdf5 zlib bash coreutils inetutils util-linux procps git grep tar sed gzip which gawk perl emacs-minimal vim gcc-toolchain make cmake pkg-config -S /bin=bin --entry-point=/bin/bash`
cp $singularity_chameleon chameleon-pack.gz.squashfs
# copy the singularity image on the supercomputer, e.g. 'supercomputer'
scp chameleon-pack.gz.squashfs supercomputer:
On a machine where Singularity is installed Chameleon can then be
called as follows
#+begin_src sh
# at least openmpi and singularity are required here, e.g. module add openmpi singularity
mpiexec -np 2 singularity exec chameleon-pack.gz.squashfs /bin/new-testing/snew-testing -H -o gemm -P 2 -t 2 -m 2000 -n 2000 -k 2000
** Distribution of Chameleon using Spack ** Distribution of Chameleon using Spack
<<sec:spack>> <<sec:spack>>
To get support to install a full distribution (Chameleon + *** Installing Spack
dependencies) we encourage users to use *Spack*. Please refer to our
[[https://gitlab.inria.fr/solverstack/spack-repo/blob/master/README.org][Spack Repository]]. To get support to install a full distribution, Chameleon plus
dependencies, we encourage users to use [[https://spack.io/][Spack]]. Please refer to our
*** Usage example for a simple distribution of Chameleon
#+begin_src sh #+begin_src sh
git clone https://github.com/llnl/spack.git git clone https://github.com/llnl/spack.git
export SPACK_ROOT=$PWD/spack export SPACK_ROOT=$PWD/spack
cd spack/
git checkout v0.13.2
. $SPACK_ROOT/share/spack/setup-env.sh . $SPACK_ROOT/share/spack/setup-env.sh
git clone https://gitlab.inria.fr/solverstack/spack-repo.git git clone https://gitlab.inria.fr/solverstack/spack-repo.git ./var/spack/repos/solverstack
spack repo add spack-repo spack repo add ./var/spack/repos/solverstack
Chameleon is then available
#+begin_src sh
spack info chameleon
spack spec chameleon
Refer to te [[https://spack.readthedocs.io/en/latest/basic_usage.html][official documentation of Spack]] to learn the basic
commands.
*** Installing Chameleon with Spack
Standard Chameleon, last state on the 'master' branch
#+begin_src sh
spack install -v chameleon spack install -v chameleon
# chameleon is installed here: # chameleon is installed here:
`spack location -i chameleon` `spack location -i chameleon`
#+end_src #+end_src
- tune the build type (CMake) with build_type=RelWithDebInfo|Debug|Release
- enable/disable shared libraries with +/- shared
- enable/disable mpi with +/- mpi
- enable/disable cuda with +/- cuda
- enable/disable fxt with +/- fxt
- enable/disable simgrid with +/- simgrid
- +openmp~starpu : with openmp - without starpu
- +quark~starpu : with quark - without starpu
Change the version
#+begin_src sh
spack install -v chameleon@0.9.2
Openblas. This can be changed by adding some [[https://spack.readthedocs.io/en/latest/basic_usage.html#constraining-virtual-packages][constraints on
virtual packages]].
#+begin_src sh
# see lapack providers
spack providers lapack
# see mpi providers
spack providers mpi
spack install -v chameleon ^intel-mkl
# install chameleon with nmad to replace openmpi
spack install -v chameleon ^nmad
** Build and install Chameleon with CMake ** Build and install Chameleon with CMake
Compilation of Chameleon libraries and executables are done with Compilation of Chameleon libraries and executables are done with
CMake (http://www.cmake.org/). This version has been tested with CMake (http://www.cmake.org/). This version has been tested with
