Commit 0f922f58 authored by PRUVOST Florent's avatar PRUVOST Florent
declarations should appear on top of functions
parent 57a4eb0f
...@@ -200,13 +200,14 @@ static void cl_zgemm_cuda_func(void *descr[], void *cl_arg) ...@@ -200,13 +200,14 @@ static void cl_zgemm_cuda_func(void *descr[], void *cl_arg)
cuDoubleComplex beta; cuDoubleComplex beta;
cuDoubleComplex *C; cuDoubleComplex *C;
int ldc; int ldc;
CUstream stream;
A = (cuDoubleComplex *)STARPU_MATRIX_GET_PTR(descr[0]); A = (cuDoubleComplex *)STARPU_MATRIX_GET_PTR(descr[0]);
B = (cuDoubleComplex *)STARPU_MATRIX_GET_PTR(descr[1]); B = (cuDoubleComplex *)STARPU_MATRIX_GET_PTR(descr[1]);
C = (cuDoubleComplex *)STARPU_MATRIX_GET_PTR(descr[2]); C = (cuDoubleComplex *)STARPU_MATRIX_GET_PTR(descr[2]);
starpu_codelet_unpack_args(cl_arg, &transA, &transB, &m, &n, &k, &alpha, &lda, &ldb, &beta, &ldc); starpu_codelet_unpack_args(cl_arg, &transA, &transB, &m, &n, &k, &alpha, &lda, &ldb, &beta, &ldc);
CUstream stream = starpu_cuda_get_local_stream(); stream = starpu_cuda_get_local_stream();
cublasSetKernelStream( stream ); cublasSetKernelStream( stream );
cublasZgemm( cublasZgemm(
