GitLab
Explore
Primary navigation
Search or go to…
Chameleon
Manage
Plan
Issue boards
Code
Merge requests
Repository graph
Compare revisions
Build
Pipeline schedules
Artifacts
Deploy
Package Registry
Container Registry
Operate
Environments
Terraform modules
Monitor
Service Desk
Analyze
Value stream analytics
Contributor analytics
CI/CD analytics
Repository analytics
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
solverstack
Chameleon
0957930c
0957930c
7 years ago
PRUVOST Florent
Downloads
Patches
try to combine coverage data
9ccd8a44
Branches containing commit
Tags containing commit
.gitlab-ci.yml
+19
-9
19 additions, 9 deletions
.gitlab-ci.yml
19 additions
9 deletions
.gitlab-ci.yml
19
9
0957930c
@@ -82,12 +82,14 @@ test_starpu_mpi:
name
starpu_test
name
starpu_test
expire_in
48 hours
expire_in
48 hours
paths
paths
coverage_starpu_mpi.tar.bz2
#- coverage_starpu_mpi.tar.bz2
chameleon_starpu_mpi.lcov
script
script
source .gitlab-ci-env.sh
git submodule update --init --recursive
(cd build && STARPU_SILENT=1 ctest --no-compress-output -R test_shm_s || /usr/bin/true && ctest --no-compress-output -R mpi_s || /usr/bin/true)
find -name "*.gcda" | xargs tar cvjf coverage_starpu_mpi.tar.bz2
lcov --directory build --capture --output-file chameleon_starpu_mpi.lcov
#- find -name "*.gcda" | xargs tar cvjf coverage_starpu_mpi.tar.bz2
test_starpu_simgrid
test_starpu_simgrid
stage
test
stage
test
@@ -97,12 +99,14 @@ test_starpu_simgrid:
name
starpu_test
name
starpu_test
expire_in
48 hours
expire_in
48 hours
paths
paths
coverage_starpu_simgrid.tar.bz2
#- coverage_starpu_simgrid.tar.bz2
chameleon_starpu_simgrid.lcov
script
script
source .gitlab-ci-env.sh simu
(cd build && STARPU_SILENT=1 ctest --no-compress-output -V || /usr/bin/true)
find -name "*.gcda" | xargs tar cvjf coverage_starpu_simgrid.tar.bz2
lcov --directory build --capture --output-file chameleon_starpu_simgrid.lcov
#- find -name "*.gcda" | xargs tar cvjf coverage_starpu_simgrid.tar.bz2
test_quark
test_quark
stage
test
stage
test
@@ -112,12 +116,14 @@ test_quark:
name
quark_test
name
quark_test
expire_in
48 hours
expire_in
48 hours
paths
paths
coverage_quark.tar.bz2
#- coverage_quark.tar.bz2
chameleon_quark.lcov
script
script
(cd build && ctest --no-compress-output -R test_shm_s)
find -name "*.gcda" | xargs tar cvjf coverage_quark.tar.bz2
lcov --directory build --capture --output-file chameleon_quark.lcov
#- find -name "*.gcda" | xargs tar cvjf coverage_quark.tar.bz2
sonar
sonar
stage
analysis
stage
analysis
@@ -139,12 +145,16 @@ sonar:
sonar.log
sonar.log
script
script
tar xvjf coverage_starpu_mpi.tar.bz2
#- tar xvjf coverage_starpu_mpi.tar.bz2
tar xvjf coverage_starpu_simgrid.tar.bz2
#- tar xvjf coverage_starpu_simgrid.tar.bz2
tar xvjf coverage_quark.tar.bz2
#- tar xvjf coverage_quark.tar.bz2
lcov -a chameleon_starpu_mpi.lcov -a chameleon_starpu_simgrid.lcov -a chameleon_quark.lcov -o chameleon.lcov
genhtml -o coverage chameleon.lcov
cov_cobertura.py chameleon.lcov --output chameleon-coverage.xml
./tools/analysis.sh
./tools/analysis.sh
only
only
master
master
issue53/fix-ci
doc
doc
stage
doc
stage
doc
This diff is collapsed.
Loading
Save comment
