Commit 08d209b2 authored by Mathieu Faverge's avatar Mathieu Faverge
testing/param: fix parameters initialization
parent 51736339
1 merge request!374Fix bugs reported by Sonarqube
...@@ -305,7 +305,7 @@ void ...@@ -305,7 +305,7 @@ void
parameters_read( parameter_t *param, parameters_read( parameter_t *param,
const char *values ) const char *values )
int range = ( strchr( values, ':' ) != NULL ); int range = (values != NULL) && ( strchr( values, ':' ) != NULL );
/* If we have a ranged of integer values */ /* If we have a ranged of integer values */
if ( range ) if ( range )
