Commit a9139a3e authored by BRAMAS Berenger's avatar BRAMAS Berenger
Add a word about the c kernel api in the quick start
parent 7a0e0bd9
...@@ -3,10 +3,19 @@ ...@@ -3,10 +3,19 @@
* In this section, we present the data structure organization and the * In this section, we present the data structure organization and the
* classes design to understand fully ScalFmm and customized it. * classes design to understand fully ScalFmm and customized it.
* Remark : There is a big difference between the version 1.0 and 2.0 * Remark : There is a big difference between the versions 1.0 and 2.0
* since we do not store array of particles anymore but rather several arrays. * since we do not store array of particles anymore but rather several arrays.
* This was needed in order to be able to vectorize the P2P code. * This was needed in order to be able to vectorize the P2P code.
* We would like to inform users that are not familiar with 'C++' and
* who are familiar with 'C' and would like to create a kernel
* (and do not want to work on the parallelization),
* that an C API have been made for them.
* In order to get access to this API, go in Addons/CKernelApi.
* (To compile, enable the addons and then the CKernelApi).
* However, to have access to all the features of ScalFmm it is required to use C++
* as described in this QuickStart.
* \tableofcontents * \tableofcontents
* \section prerequisite Prerequisite * \section prerequisite Prerequisite
