Commit a63b703f authored by PRUVOST Florent's avatar PRUVOST Florent
Merge branch 'ci-update' into 'main'
Update ci environment and jobs
See merge request solverstack/ScalFMM!25
parents 6597be39 00d9f606
Pipeline #1101530 passed
stages:
- docker
- build
- test
- deploy
default: default:
tags: ['docker'] image: $CI_REGISTRY_IMAGE
image: registry.gitlab.inria.fr/solverstack/docker/distrib tags: ['ci.inria.fr', 'linux', 'large'] # gitlab instance runner (i.e. docker on linux)
before_script: interruptible: true
- wget https://github.com/Kitware/CMake/releases/download/v3.22.0/cmake-3.22.0-linux-x86_64.tar.gz
- tar xvf cmake-3.22.0-linux-x86_64.tar.gz
- export PATH="$PWD/cmake-3.22.0-linux-x86_64/bin/:$PATH"
variables: variables:
GIT_SUBMODULE_STRATEGY: recursive GIT_SUBMODULE_STRATEGY: recursive
stages: # push event: executed only if the source branch name is main or starts with ci-
- build_main # merge request event: executed if the source branch name does not start with notest-
- test_main # schedule event: not executed
.only-main-mr:
rules:
- if: ($CI_COMMIT_BRANCH =~ /^ci-.*$/)
- if: ($CI_COMMIT_BRANCH == $CI_DEFAULT_BRANCH) &&
(($CI_PROJECT_ROOT_NAMESPACE == "solverstack" ) ||
($CI_PROJECT_ROOT_NAMESPACE == $CI_PROJECT_NAME))
- if: (($CI_PIPELINE_SOURCE == "merge_request_event") &&
($CI_MERGE_REQUEST_SOURCE_BRANCH_NAME !~ /^notest-.*$/))
- if: ($CI_PIPELINE_SOURCE == "schedule" )
when: never
build_main: docker:
stage: build_main stage: docker
interruptible: true image: docker
artifacts: when: manual
name: scalfmm_build_main before_script:
expire_in: 1 day - docker login -u $CI_REGISTRY_USER -p $CI_REGISTRY_PASSWORD $CI_REGISTRY
paths:
- build_main/
script: script:
- mkdir build_main && cd build_main && cmake .. - docker build -f Dockerfile-ci -t $CI_REGISTRY_IMAGE $PWD
- docker push $CI_REGISTRY_IMAGE
build:
stage: build
extends: .only-main-mr
timeout: 2 hours
script:
- cmake -B build -DCMAKE_INSTALL_PREFIX=$PWD/install
-Dscalfmm_USE_MKL=ON
-Dscalfmm_USE_MPI=OFF -Dscalfmm_USE_MPI=OFF
-Dscalfmm_BUILD_EXAMPLES=ON -Dscalfmm_BUILD_EXAMPLES=ON
-Dscalfmm_BUILD_UNITS=ON -Dscalfmm_BUILD_UNITS=ON
-Dscalfmm_BUILD_TOOLS=ON -Dscalfmm_BUILD_TOOLS=ON
-Dscalfmm_BUILD_CHECK=ON -Dscalfmm_BUILD_CHECK=ON
-DCMAKE_VERBOSE_MAKEFILE=ON -DCMAKE_VERBOSE_MAKEFILE=ON
-DCMAKE_C_COMPILER=gcc #-DCMAKE_CXX_FLAGS="-O0 -g -Wall -fPIC -fno-inline --coverage"
-DCMAKE_CXX_COMPILER=g++ - cmake --build build -j 4 > /dev/null
- make -j5 2>&1 |tee scalfmm-main-build.log - cmake --build build -j 4 --target examples > /dev/null
- make examples 2>&1 |tee scalfmm-main-examples-build.log - cmake --build build -j 4 --target units > /dev/null
- make units 2>&1 |tee scalfmm-main-units-build.log - cmake --install build
only: artifacts:
- main name: "$CI_JOB_NAME-$CI_COMMIT_REF_SLUG"
expire_in: 1 week
paths: [build]
untracked: true
test_main: test:
stage: test_main stage: test
interruptible: true extends: .only-main-mr
dependencies: dependencies:
- build_main - build
variables:
OMP_NUM_THREADS: 4
script:
- ctest --test-dir build --output-on-failure --no-compress-output --output-junit $PWD/test.xml
#- gcovr --xml-pretty --exclude-unreachable-branches --print-summary -o coverage.xml --root $PWD
#coverage: /^\s*lines......:\s*\d+.\d+\%/
artifacts: artifacts:
expire_in: 1 day junit: test.xml
paths: #coverage_report:
- build_main/ # coverage_format: cobertura
# path: coverage.xml
pages:
stage: deploy
when: manual
needs: []
script: script:
- (cd build_main && OMP_NUM_THREADS=8 ctest --no-compress-output -VV -j 8 - cmake -B build
-I 16,19,1 --repeat until-fail:10 --output-on-failure --stop-on-failure) -Dscalfmm_USE_MKL=ON
only: -Dscalfmm_BUILD_DOC=ON
- main -DCMAKE_VERBOSE_MAKEFILE=ON
- cmake --build build -j 4 --target doc > /dev/null
- cp -r build/docs/sphinx/ public
artifacts:
paths:
- public
# @file Dockerfile-ci
# @copyright 2025-2025 Bordeaux INP, CNRS (LaBRI UMR 5800), Inria,
# Univ. Bordeaux. All rights reserved.
# @version 3.0.0
# @author Florent Pruvost
# @date 2025-01-21
# This docker image is used to test the package during gitlab-ci pipelines.
# It should be stored in the gitlab's project container registry:
# https://gitlab.inria.fr/solverstack/ScalFMM/container_registry
# solverstack/docker/base docker image is defined here: https://gitlab.inria.fr/solverstack/docker
FROM registry.gitlab.inria.fr/solverstack/docker/base
USER root
RUN apt-get -y update
# ScalFMM dependencies: cpu kernels, mpi, ...
RUN apt-get -y upgrade --no-install-recommends \
libmkl-dev \
sphinx-common \
python3-breathe \
python3-exhale \
python3-recommonmark \
python3-sphinx-rtd-theme
#libopenmpi-dev \
#libstarpu-dev \
#pybind11-dev
# Set some default environment variables
ENV MKLROOT /usr
USER gitlab
...@@ -16,7 +16,7 @@ if(${CMAKE_PROJECT_NAME}_USE_MKL) ...@@ -16,7 +16,7 @@ if(${CMAKE_PROJECT_NAME}_USE_MKL)
set(CBLAS_FOUND TRUE) set(CBLAS_FOUND TRUE)
set_target_properties(MKL::MKL PROPERTIES set_target_properties(MKL::MKL PROPERTIES
INTERFACE_INCLUDE_DIRECTORIES INTERFACE_INCLUDE_DIRECTORIES
"${MKL_ROOT}/include;${MKL_ROOT}/include/fftw" "${MKL_ROOT}/include;${MKL_ROOT}/include/fftw;${MKL_ROOT}/include/mkl/fftw"
list(APPEND CBLAS_TARGET MKL::MKL) list(APPEND CBLAS_TARGET MKL::MKL)
else() else()
...@@ -25,7 +25,7 @@ if(${CMAKE_PROJECT_NAME}_USE_MKL) ...@@ -25,7 +25,7 @@ if(${CMAKE_PROJECT_NAME}_USE_MKL)
if(DEFINED BLAS_FOUND) if(DEFINED BLAS_FOUND)
set_target_properties(BLAS::BLAS PROPERTIES set_target_properties(BLAS::BLAS PROPERTIES
list(APPEND CBLAS_TARGET BLAS::BLAS) list(APPEND CBLAS_TARGET BLAS::BLAS)
list(APPEND FUSE_LIST CBLAS) list(APPEND FUSE_LIST CBLAS)
