GitLab
Explore
Primary navigation
Search or go to…
S
ScalFMM
Manage
Plan
Issue boards
Code
Repository graph
Compare revisions
Build
Pipeline schedules
Artifacts
Deploy
Package registry
Container registry
Model registry
Operate
Environments
Terraform modules
Monitor
Incidents
Service Desk
Analyze
Value stream analytics
Contributor analytics
CI/CD analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
solverstack
ScalFMM
93b0c92e
93b0c92e
11 years ago
Olivier COULAUD
Downloads
Patches
Fix bug in package name
80e346f9
CMakeLists.txt
+8
-6
8 additions, 6 deletions
CMakeLists.txt
8 additions
6 deletions
CMakeLists.txt
8
6
93b0c92e
@@ -305,25 +305,27 @@ INSTALL(FILES
# build a CPack driven installer package
set
CPACK_RESOURCE_FILE_LICENSE
CMAKE_CURRENT_SOURCE_DIR
/Licence.txt"
SET
CPACK_PACKAGE_VERSION_MAJOR
ScalFMM_MAJOR_VERSION
SET
CPACK_PACKAGE_VERSION_NINOR
ScalFMM_MINOR_VERSION
# Use git commit number as CPACK_PACKAGE_VERSION_PATCH
execute_process
execute_process
COMMAND git rev-list HEAD --count
OUTPUT_VARIABLE CPACK_PACKAGE_VERSION_PATCH
RESULT_VARIABLE RET
RESULT_VARIABLE RET
ERROR_QUIET
ERROR_QUIET
OUTPUT_STRIP_TRAILING_WHITESPACE
# STRING_TRIM(PATCH1 PATCH)
SET
CPACK_INCLUDE_TOPLEVEL_DIRECTORY
"ON"
SET
"ON"
set
/Licence.txt"
SET
SET
SET
CPACK_SOURCE_GENERATOR
"TGZ"
SET
"TGZ"
SET
CPACK_SOURCE_PACKAGE_FILE_NAME
"ScalFMM-
ScalFMM_VERSION
SET
"ScalFMM-
ScalFMM_
MAJOR_
VERSION
SET
CPACK_SOURCE_IGNORE_FILES
.git;.DS_Store;.*~;/*.aux;/*.idx;/*.log;/*.out;/*.toc;/*.ilg;/*.ind;scalfmm.pro*;org.eclipse.core.resources.prefs;.cproject;.project"
SET
LIST
APPEND CPACK_SOURCE_IGNORE_FILES
CMAKE_BINARY_DIR
CMAKE_SOURCE_DIR
/Utils/;Notes;Deprecated;Build*"
LIST
CMAKE_BINARY_DIR
CMAKE_SOURCE_DIR
message
"CPACK_SOURCE_IGNORE_FILES =
message
message
"CPACK_SOURCE_PACKAGE_FILE_NAME =
INCLUDE
CPack
INCLUDE
CPack
This diff is collapsed.
Loading
Save comment
