Commit 79a80464 authored by BRAMAS Berenger's avatar BRAMAS Berenger
compile all hmat by make hmat
parent 79ac022c
...@@ -49,6 +49,7 @@ if(SCALFMM_ADDON_HMAT) ...@@ -49,6 +49,7 @@ if(SCALFMM_ADDON_HMAT)
INCLUDE_DIRECTORIES( ${CMAKE_BINARY_DIR}/Src ) INCLUDE_DIRECTORIES( ${CMAKE_BINARY_DIR}/Src )
# Then build test files # Then build test files
SET(hmat_list_execs "")
foreach(exec ${source_tests_files}) foreach(exec ${source_tests_files})
get_filename_component( get_filename_component(
execname ${exec} execname ${exec}
...@@ -79,6 +80,9 @@ if(SCALFMM_ADDON_HMAT) ...@@ -79,6 +80,9 @@ if(SCALFMM_ADDON_HMAT)
# ${LAPACK_LIBRARIES} # ${LAPACK_LIBRARIES}
${SCALFMM_LIBRARIES} ${SCALFMM_LIBRARIES}
LIST(APPEND hmat_list_execs ${execname})
endif() endif()
endforeach(exec) endforeach(exec)
add_custom_target(hmat DEPENDS ${hmat_list_execs})
endif() endif()
