GitLab
Explore
Primary navigation
Search or go to…
S
ScalFMM
Manage
Plan
Issue boards
Code
Repository graph
Compare revisions
Build
Pipeline schedules
Artifacts
Deploy
Package registry
Container registry
Model registry
Operate
Environments
Terraform modules
Monitor
Incidents
Service Desk
Analyze
Value stream analytics
Contributor analytics
CI/CD analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Admin message
GitLab upgrade completed. Current version is 17.11.3.
Show more breadcrumbs
solverstack
ScalFMM
6d0c5b37
6d0c5b37
4 years ago
ESTERIE Pierre
Downloads
Patches
Remove CDash for now
7312230d
Pipeline
#242785
failed
4 years ago
Stage: build
Stage: pages
Stage: test
Stage: sonar
Stage: deploy
CTestConfig.cmake
+37
-37
37 additions, 37 deletions
CTestConfig.cmake
37 additions
37 deletions
CTestConfig.cmake
37
37
6d0c5b37
@@ -4,9 +4,9 @@
@@ -4,9 +4,9 @@
## # The following are required to uses Dart and the Cdash dashboard
## ENABLE_TESTING()
## ENABLE_TESTING()
## INCLUDE(CTest)
## INCLUDE(CTest)
set
CTEST_PROJECT_NAME
"ScalFMM"
set(CTEST_PROJECT_NAME "ScalFMM")
set
CTEST_NIGHTLY_START_TIME
"00:00:00 GMT"
set(CTEST_NIGHTLY_START_TIME "00:00:00 GMT")
set
CTEST_SUBMIT_URL
"http://cdash.inria.fr/CDash/submit.php?project=scalfmm"
set(CTEST_SUBMIT_URL "http://cdash.inria.fr/CDash/submit.php?project=scalfmm")
# BUILDNAME variable construction
@@ -14,37 +14,37 @@ set(CTEST_SUBMIT_URL "http://cdash.inria.fr/CDash/submit.php?project=scalfmm")
# on the Chameleon dashboard http://cdash.inria.fr/CDash/
# Start with the short system name, e.g. "Linux", "FreeBSD" or "Windows"
if
NOT BUILDNAME
if(NOT BUILDNAME)
set
BUILDNAME
CMAKE_SYSTEM_NAME
set(BUILDNAME "${CMAKE_SYSTEM_NAME}")
# Add i386 or amd64
# Add i386 or amd64
if
CMAKE_SIZEOF_VOID_P EQUAL 8
if(CMAKE_SIZEOF_VOID_P EQUAL 8)
set
BUILDNAME
BUILDNAME
-amd64"
set(BUILDNAME "${BUILDNAME}-amd64")
else
else()
set
BUILDNAME
BUILDNAME
-i386"
set(BUILDNAME "${BUILDNAME}-i386")
endif
endif()
# Add compiler name
# Add compiler name
get_filename_component
CMAKE_CXX_COMPILER_NAME
CMAKE_CXX_COMPILER
NAME
get_filename_component(CMAKE_CXX_COMPILER_NAME ${CMAKE_CXX_COMPILER} NAME)
set
BUILDNAME
BUILDNAME
set(BUILDNAME "${BUILDNAME}-${CMAKE_CXX_COMPILER_NAME}")
# Add the build type, e.g. "Debug, Release..."
if
CMAKE_BUILD_TYPE
if(CMAKE_BUILD_TYPE)
set
BUILDNAME
BUILDNAME
CMAKE_BUILD_TYPE
set(BUILDNAME "${BUILDNAME}-${CMAKE_BUILD_TYPE}")
endif
CMAKE_BUILD_TYPE
endif(CMAKE_BUILD_TYPE)
# Specific options of Scalfmm
if
SCALFMM_USE_SSE
if(SCALFMM_USE_SSE)
set
BUILDNAME
BUILDNAME
-sse"
set(BUILDNAME "${BUILDNAME}-sse")
endif
endif()
if
SCALFMM_USE_BLAS
if(SCALFMM_USE_BLAS)
set
BUILDNAME
BUILDNAME
-blas"
set(BUILDNAME "${BUILDNAME}-blas")
endif
endif()
if
SCALFMM_USE_MPI
if(SCALFMM_USE_MPI)
set
BUILDNAME
BUILDNAME
-mpi"
set(BUILDNAME "${BUILDNAME}-mpi")
endif
endif()
endif
endif()
This diff is collapsed.
Loading
Save comment
