Commit 6039d3c1 authored by Olivier COULAUD's avatar Olivier COULAUD
Remove old leaf
parent 6e04bf06
// See LICENCE file at project root
// File : scalfmm/tree/leaf.hpp
#ifndef SCALFMM_TREE_LEAF_HPP
#define SCALFMM_TREE_LEAF_HPP
#warning("Do not use this file - old leaf format")
#include "scalfmm/container/particle_container.hpp"
#include "scalfmm/container/point.hpp"
#include "scalfmm/container/variadic_adaptor.hpp"
#include "scalfmm/meta/traits.hpp"
#include "scalfmm/meta/type_pack.hpp"
#include "scalfmm/meta/utils.hpp"
#include "scalfmm/tags/tags.hpp"
#include "scalfmm/tree/group.hpp"
#include "scalfmm/tree/header.hpp"
#include "scalfmm/tree/utils.hpp"
#include "scalfmm/utils/massert.hpp"
#include "scalfmm/utils/math.hpp"
#include <algorithm>
#include <any>
#include <array>
#include <cmath>
#include <cstddef>
#include <iterator>
#include <tuple>
#include <type_traits>
#include <utility>
#include <vector>
namespace scalfmm::component
* @brief This is the leaf type stored at the bottom of the tree.
* Its stores the particle container and some symbolics informations.
* @tparam Particle : the type of particle to store.
* @tparam D
template<typename Particle, typename D = void>
class leaf
public:
* @brief Static dimension of the space.
static constexpr std::size_t dimension = Particle::dimension;
// self type
using self_type = leaf<Particle>;
// Symbolic types : the type storing informations about the leaf component
using symbolics_type = symbolics_data<std::conditional_t<std::is_void_v<D>, self_type, D>>;
// the particle type stored in the container
using particle_type = Particle;
using proxy_type = typename Particle::proxy_type;
using const_proxy_type = typename Particle::const_proxy_type;
// the position type extract from the symbolic information
using position_type = typename Particle::position_type;
// symbolics_type::position_type;
// the position value type
using value_type = typename position_type::value_type;
// the particle container type
using particle_container_type = container::particle_container<particle_type>;
// rule of five generated by the compiler
* @brief Construct a new leaf object
leaf() = default;
leaf(leaf const&) = default;
leaf(leaf&&) noexcept = default;
* @brief
* @return leaf&
inline auto operator=(leaf const&) -> leaf& = default;
* @brief
* @return leaf&
inline auto operator=(leaf&&) noexcept -> leaf& = default;
* @brief Destroy the leaf object
~leaf() = default;
* @brief Constructors from center and width
* @param center : the center of the leaf
* @param width : the width of the leaf
leaf(position_type const& center, value_type width)
: m_center(center)
, m_width(width)
* @brief Constructors from number of particles, center, width and a morton index
* @param nb_particles : number of particles in the container
* @param morton_index : the morton index of the leaf
leaf(std::size_t nb_particles, position_type const& center, value_type width, std::size_t morton_index)
: m_particles(nb_particles)
, m_symbolics{morton_index}
, m_nb_particles(nb_particles)
, m_center(center)
, m_width(width)
m_symbolics.morton_index = morton_index;
* Constructors from a container of particles, center, width and a morton index
* It takes an rvalue reference to the container allowing you to move the container inside the leaf.
* @param container : rvalue ref to the container
leaf(particle_container_type&& container, std::size_t nb_particles, position_type const& center,
: m_particles(container)
, m_center(center)
, m_width(width)
* @brief Constructors from a container of particles with iterators, center, width and a morton index
* @param begin : iterator on the begin of the particle container to copy
* @param end : iterator on the end of the particle container to copy
leaf(typename particle_container_type::const_iterator begin,
typename particle_container_type::const_iterator end, std::size_t nb_particles,
, m_center(center)
, m_width(width)
std::copy(begin, end, std::begin(m_particles));
* @brief Returns the center of the leaf.
* @return position_type const&
[[nodiscard]] inline auto center() const noexcept -> position_type const& { return m_center; }
* @brief Returns the width of the leaf.
* @return value_type
[[nodiscard]] inline auto width() const noexcept -> value_type { return m_width; }
* @brief Returns the number of particles
* @return std::size_t
[[nodiscard]] inline auto size() const noexcept -> std::size_t { return m_nb_particles; }
* @brief Non-const accessor on the container
* @return particle_container_type&
[[nodiscard]] inline auto particles() -> particle_container_type& { return m_particles; }
* @brief Const accessor on the container.
* @return particle_container_type const&
[[nodiscard]] inline auto particles() const -> particle_container_type const& { return m_particles; }
[[nodiscard]] inline auto cparticles() const -> particle_container_type const& { return m_particles; }
* @brief Indexed accessor on the particle container.
* @param i the index at which the access is performed.
* @return particle_type&
[[nodiscard]] inline auto particles(std::size_t i) -> particle_type& { return m_particles.at(i); }
[[nodiscard]] inline auto particle(std::size_t i) -> particle_type& { return m_particles.at(i); }
* @return particle_type const&
[[nodiscard]] inline auto particles(std::size_t i) const -> particle_type const& { return m_particles.at(i); }
[[nodiscard]] inline auto particle(std::size_t i) const -> particle_type const& { return m_particles.at(i); }
* @brief
* @return particle_container_type::iterator
[[nodiscard]] inline auto begin() -> typename particle_container_type::iterator { return m_particles.begin(); }
* @brief
* @return particle_container_type::const_iterator
[[nodiscard]] inline auto begin() const -> typename particle_container_type::const_iterator
* @brief
[[nodiscard]] inline auto cbegin() const -> typename particle_container_type::const_iterator
return m_particles.cbegin();
* @brief
[[nodiscard]] inline auto end() -> typename particle_container_type::iterator { return m_particles.end(); }
* @brief
[[nodiscard]] inline auto end() const -> typename particle_container_type::const_iterator
* @brief
[[nodiscard]] inline auto cend() const -> typename particle_container_type::const_iterator
return m_particles.cend();
* @brief Access to the symbolic type.
* @return symbolics_type&
[[nodiscard]] inline auto symbolics() -> symbolics_type& { return m_symbolics; }
* @return symbolics_type const&
[[nodiscard]] inline auto symbolics() const -> symbolics_type const& { return m_symbolics; }
[[nodiscard]] inline auto csymbolics() const -> symbolics_type const& { return m_symbolics; }
* @brief Returns the morton index of the leaf.
[[nodiscard]] inline auto index() const noexcept -> std::size_t { return m_symbolics.morton_index; }
* @brief Insert a particle at the index.
* @param part the particle to insert.
* @param index the position to insert the particle.
inline auto insert_particle(particle_type const& part, std::size_t index) -> void
assertm(index < m_nb_particles, "Inserting particle out of range in leaf.");
auto it = std::begin(m_particles) + index;
*it = part.as_tuple();
* @tparam Types
* @param part the tuple corresponding to the particle to insert.
template<typename... Types>
inline auto insert_particle(std::tuple<Types...> const& part, std::size_t index) -> void
auto it = std::begin(m_particles);
std::advance(it, index);
*it = part;
* @brief Resets the positions of the leaves.
inline auto reset_positions() -> void { m_particles.reset_positions(); }
* @brief Resets the inputs of the leaves.
inline auto reset_inputs() -> void { m_particles.reset_inputs(); }
* @brief Resets the outputs of the leaves.
inline auto reset_outputs() -> void { m_particles.reset_outputs(); }
* @brief Resets the variables of the leaves.
inline auto reset_variables() -> void { m_particles.reset_variables(); }
* @brief Resets the particles of the leaves.
inline auto reset_particles() -> void { m_particles.reset_particles(); }
private:
* @brief The particle container.
particle_container_type m_particles{};
* @brief The symbolic data.
symbolics_type m_symbolics{};
* @brief The number of particles.
std::size_t m_nb_particles{};
* @brief Position of the center.
position_type m_center{};
* @brief The width of the leaf.
value_type m_width{};
* @brief The symbolics type stores information about the leaf
* It represents a generic that also exists on the cells
* @tparam P
template<typename P>
struct symbolics_data<leaf<P>>
// the leaf type
using component_type = leaf<P>;
// the group type
using group_type = group<component_type>;
typename component_type::particle_type::position_type; // container::point<position_value_type,
// P::dimension>;
// the coordinate type to store the coordinate in the tree
using coordinate_type =
decltype(index::get_coordinate_from_morton_index<position_type::dimension>(std::size_t{}));
// the number of interactions of the leaf
static constexpr std::size_t number_of_interactions{int(math::pow(3, position_type::dimension))};
// type of the array storing the indexes of the theoretical interaction list
using interaction_index_array_type = std::array<std::size_t, number_of_interactions>;
// type of the array storing the iterators of the interacting leaves available in the current group
using iterator_array_type = std::array<typename group_type::iterator_type, number_of_interactions>;
using iterator_type = typename iterator_array_type::value_type;
* @brief The morton index of the leaf.
std::size_t morton_index{0};
* @brief The array storing the indices of the theoritical interaction list.
interaction_index_array_type interaction_indexes{};
* @brief The array storing the iterators of the interacting leaves available in the current group.
iterator_array_type interaction_iterators{};
* @brief The theoritical number of neighbors of the number of morton indices available (in the mutual algorithm).
std::size_t number_of_neighbors{0};
* @brief The number of morton indices available in the group of the leaf.
std::size_t existing_neighbors_in_group{0};
* @brief
* @param counter
* @param idx
* @param leaf_iter
inline auto set(int counter, std::size_t const& idx, const iterator_type& leaf_iter) -> void
interaction_iterators.at(counter) = leaf_iter;
* @brief
* @param done
* @param counter_existing_component
inline auto finalize(bool done, std::size_t const& counter_existing_component) -> void
number_of_neighbors = counter_existing_component;
* @brief The symbolics type that stores information about the group of leaves.
* @tparam P
struct symbolics_data<group<leaf<P>>>
// the leaf type
// the group type
using group_type = group<leaf<P>>;
// the particle type is also P
using particle_type = typename component_type::particle_type;
using iterator_type = typename group_type::iterator_type;
using seq_iterator_type =
std::conditional_t<meta::exist_v<meta::inject<group_type>>, meta::exist_t<meta::inject<group_type>>,
std::tuple<typename group_type::iterator_type, group_type>>;
using iterator_source_type = std::tuple_element_t<0, seq_iterator_type>;
// using iterator_array_type = std::array<iterator_source_type, number_of_interactions>;
using out_of_block_interaction_type = out_of_block_interaction<iterator_type, std::size_t>;
* @brief The starting morton index in the group.
std::size_t starting_index{0};
* @brief The ending morton index in the group.
std::size_t ending_index{0};
* @brief The number of leaves in the group.
std::size_t number_of_component_in_group{0};
* @brief The number of particles in the group.
std::size_t number_of_particles_in_group{0};
* @brief The index of the group.
std::size_t idx_global{0};
* @brief
bool is_mine{false};
* @brief Vector storing the out_of_block_interaction structure to handle the outside interactions.
std::vector<out_of_block_interaction_type> outside_interactions{};
* @brief Flag if the vector is constructed.
bool outside_interactions_exists{false};
* @brief Flag if the vector is sorted.
bool outside_interactions_sorted{false};
#if _OPENMP
* @brief the dependencies are set on the pointer on the leaf group (same as particle container).
std::vector<group_type*> group_dependencies{};
#endif
* @brief Construct a new symbolics data object
* @param starting_morton_idx
* @param ending_morton_idx
* @param number_of_component
* @param in_index_global
* @param in_is_mine
symbolics_data(size_t starting_morton_idx, size_t ending_morton_idx, size_t number_of_component,
size_t in_index_global, bool in_is_mine)
: starting_index(starting_morton_idx)
, ending_index(ending_morton_idx)
, number_of_component_in_group(number_of_component)
, number_of_particles_in_group(0)
, idx_global(in_index_global)
, is_mine(in_is_mine)
} // namespace scalfmm::component
#endif // SCALFMM_TREE_TREE_HPP
