Commit 3a712236 authored by Olivier COULAUD's avatar Olivier COULAUD
Update sonarQube token
parent 49255d7a
Pipeline #
...@@ -37,5 +37,5 @@ test: ...@@ -37,5 +37,5 @@ test:
script: script:
- source ./Utils/scripts/analysis.sh - source ./Utils/scripts/analysis.sh
- if [[ $CI_REPOSITORY_URL = *"solverstack/ScalFMM"* ]] && [[ $CI_COMMIT_REF_NAME = *"develop"* ]]; then - if [[ $CI_REPOSITORY_URL = *"solverstack/ScalFMM"* ]] && [[ $CI_COMMIT_REF_NAME = *"develop"* ]]; then
sonar-scanner -X -Dsonar.login=7555e3ab0432d5402409aafd3800f99d300215a4 > sonar.log; sonar-scanner -X -Dsonar.login=9bdc3ada672c00725b1921657234b25c24be7bdc > sonar.log;
fi fi
