Commit 38e40e88 authored by Quentin Khan's avatar Quentin Khan
Add unit tests for variadic_container
parent ddb98f21
#define VARIADIC_VECTOR_DEBUG
#include "Utils/variadic_container.hpp"
#include "../../Serializable/checker.hpp"
class utest_variadic_vector {
using vector_t = variadic_vector<std::allocator<char>, char, int, float, double>;
using value_t = typename vector_t::value_type;
checker_t check;
template<std::size_t I, std::size_t J, class Vec>
static unsigned long get_byte_offset(const Vec& v) {
return (unsigned long)(((char*)std::get<J>(v._data_tuple))
- ((char*)std::get<I>(v._data_tuple)));
void test_standard_allocation() {
std::size_t v_cap = 10;
vector_t v = vector_t();
v.reserve(v_cap);
check.equal(v._capacity, v_cap, LOCUS);
check.equal(get_byte_offset<0,1>(v), v_cap * sizeof(char), LOCUS);
check.equal(get_byte_offset<1,2>(v), v_cap * sizeof(int), LOCUS);
check.equal(get_byte_offset<2,3>(v), v_cap * sizeof(float), LOCUS);
void test_constructor() {
// Test default constructor
check.equal(v.size(), 0u, LOCUS);
check.equal(v.capacity(), 0u, LOCUS);
// Test constructor, multiple default constructions
std::size_t v_size = 10;
vector_t v(v_size);
check.equal (v.size(), v_size, LOCUS);
check.greater_eq(v.capacity(), v_size, LOCUS);
for(std::size_t i = 0; i < v_size; ++i) {
check.equal(v[i], value_t{}, LOCUS);
// Test constructor from duplicated value
std::size_t v_size = 5;
value_t ref{'a', 1, 3.14, 1e-5};
vector_t v(v_size, ref);
check.equal(v[i], ref, LOCUS);
// Test constructor from range
std::initializer_list<value_t> l = {{'b',1,3.14,1e-5}, {'c',2,2.71,2e-6}};
vector_t v(std::begin(l), std::end(l));
std::size_t i = 0;
for(auto ref : l) {
++i;
// Test copy constructor
vector_t v_ref(5, ref);
vector_t v(v_ref);
check.equal(v.size(), v_ref.size(), LOCUS);
for(std::size_t i = 0; i < v.size(); ++i) {
check.equal(v[i], v_ref[i], LOCUS);
// Test move constructor
vector_t v_source(5, ref);
auto v_source_data = v_source.data();
std::size_t v_source_size = v_source.size();
std::size_t v_source_capacity = v_source.capacity();
vector_t v(std::move(v_source));
check.equal(v.data(), v_source_data, LOCUS);
check.equal(v.size(), v_source_size, LOCUS);
check.equal(v.capacity(), v_source_capacity, LOCUS);
check.equal(v_source.size(), 0u, LOCUS);
check.equal(v_source.capacity(), 0u, LOCUS);
void test_assignment_operator() {
// Test copy assignment
const vector_t v_source(5, ref);
v = v_source;
check.different(v.data(), v_source.data(), LOCUS);
check.equal(v.size(), v_source.size(), LOCUS);
check.equal(v.capacity(), v_source.capacity(), LOCUS);
public:
bool run() {
test_standard_allocation();
test_constructor();
check.print_summary();
return check.ok();
int main() {
return utest_variadic_vector{}.run() ? EXIT_SUCCESS : EXIT_FAILURE;
