GitLab
Explore
Primary navigation
Search or go to…
E
eScriptorium
Manage
Plan
Issue boards
Code
Merge requests
Repository graph
Compare revisions
Deploy
Container registry
Model registry
Monitor
Incidents
Service Desk
Analyze
Value stream analytics
Contributor analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
scripta
eScriptorium
c2514d25
c2514d25
4 years ago
Olivier Masson
Downloads
Patches
Update DiploLine.vue
48c706b7
OM_dilopanel__background_colouring_according_specified_linked_regions
1 merge request
!79
feature: background colouring in diplomatic panel according to specific regions
front/vue/components/DiploLine.vue
+207
-1
207 additions, 1 deletion
207 additions
1 deletion
207
c2514d25
@@ -25,6 +25,21 @@ export default Vue.extend({
this
$parent
appendLine
this
$parent
appendLine
if
this
line
currentTrans
this
setElContent
this
line
currentTrans
content
if
this
line
currentTrans
this
setElContent
this
line
currentTrans
content
bind
this
bind
this
// load colors, regarding user profile and/or region types
let
beSettings
userProfile
get
baseline-editor-
this
$store
state
document
id
this
regionColors
beSettings
color-regions
// if a coloring attribute exists, will use it
this
regionTypes
this
$store
state
document
types
regions
map
t
t
name
// or, create region colors using the same algorithm than for segmentation panel for regions:
let
basicColor
#11FF76
// same value used from baseline-editor.js
for
let
index
in
this
regionTypes
let
type
this
regionTypes
index
if
this
regionColors
type
null
this
regionColors
type
this
changeHue
basicColor
3
index
beforeDestroy
beforeDestroy
let
el
this
getEl
let
el
this
getEl
@@ -54,13 +69,204 @@ export default Vue.extend({
setElContent
content
setElContent
content
let
line
this
getEl
let
line
this
getEl
if
line
line
textContent
content
if
line
line
textContent
content
// additional code to set/display background-colors when some lines are linked to some specific region type:
let
regionType
this
getRegionType
// return the string of the type / null when no region linked
if
regionType
null
let
rgb
this
regionColors
regionType
let
r
rgb
let
g
rgb
let
b
rgb
2
let
hexa
this
rgb2hex
r
g
b
let
cmyk
this
rgb2cmyk
r
g
b
cmyk
cmyk(
cmyk
c
cmyk
m
cmyk
y
cmyk
k
// would give better results and nearest to svg colors but not working
rgb
rgb(
r
g
b
// desaturate colors: more suitable for backgrounuds when reading
let
sat
0.6
var
gray
r
0.3086
g
0.6094
b
0.0820
r
Math
round
r
sat
gray
sat
g
Math
round
g
sat
gray
sat
b
Math
round
b
sat
gray
sat
let
rgba
rgba(
r
g
b
, 0.2)
line
style
backgroundColor
rgba
// possible values: hexa,rgb,rgba (allows opacity),(cmyk)
// to display the region type by the nav when mouseoverring: -
// - could next do this in a more accurate way:
// maybe display a semi-transparent fixed div, disappearing after few second and reappearing when scrolling, for example -
line
title
regionType
getRegion
getRegion
return
this
$store
state
regions
all
findIndex
r
r
pk
this
line
region
return
this
$store
state
regions
all
findIndex
r
r
pk
this
line
region
getRegionType
let
regions
this
$store
state
regions
all
for
var
i
i
regions
length
i
var
r
regions
i
if
r
pk
this
line
region
return
r
type
return
null
// no linked region type has been found
// coloring computation methods (one sample from basline-editor methods):
changeHue
rgb
degree
// exepcts a string and returns an object
function
rgbToHSL
rgb
// strip the leading # if it's there
rgb
rgb
replace
\s
\s
*$/g
// convert 3 char codes --> 6, e.g. `E0F` --> `EE00FF`
if
rgb
length
3
rgb
rgb
replace
/g
$1$1
var
r
parseInt
rgb
substr
16
255
g
parseInt
rgb
substr
2
2
16
255
b
parseInt
rgb
substr
4
2
16
255
cMax
Math
max
r
g
b
cMin
Math
min
r
g
b
delta
cMax
cMin
l
cMax
cMin
2
h
s
if
delta
h
else
if
cMax
r
h
60
g
b
delta
6
else
if
cMax
g
h
60
b
r
delta
2
else
h
60
r
g
delta
4
if
delta
s
else
s
delta
Math
abs
2
l
return
h
h
s
s
l
l
// expects an object and returns a string
function
hslToRGB
hsl
var
h
hsl
h
s
hsl
s
l
hsl
l
c
Math
abs
2
l
s
x
c
Math
abs
h
60
2
m
l
c
2
r
g
b
if
h
60
r
c
g
x
b
else
if
h
120
r
x
g
c
b
else
if
h
180
r
g
c
b
x
else
if
h
240
r
g
x
b
c
else
if
h
300
r
x
g
b
c
else
r
c
g
b
x
r
normalize_rgb_value
r
m
g
normalize_rgb_value
g
m
b
normalize_rgb_value
b
m
// return rgb2hex(r,g,b);
return
r
g
b
function
normalize_rgb_value
color
m
color
Math
floor
color
m
255
if
color
color
return
color
var
hsl
rgbToHSL
rgb
hsl
h
degree
if
hsl
h
360
hsl
h
360
else
if
hsl
h
hsl
h
360
return
hslToRGB
hsl
rgb2hex
r
g
b
return
24
r
16
g
8
b
toString
16
slice
rgb2cmyk
r
g
b
normalized
var
c
r
255
var
m
g
255
var
y
b
255
var
k
Math
min
c
Math
min
m
y
c
c
k
k
m
m
k
k
y
y
k
k
if
normalized
c
Math
round
c
10000
100
m
Math
round
m
10000
100
y
Math
round
y
10000
100
k
Math
round
k
10000
100
c
isNaN
c
c
m
isNaN
m
m
y
isNaN
y
y
k
isNaN
k
k
return
c
Math
round
c
m
Math
round
m
y
Math
round
y
k
Math
round
k
script
script
style
scoped
style
scoped
style
style
\ No newline at end of file
This diff is collapsed.
Loading
Save comment
