Commit a73b4ae7 authored by GACON Florian's avatar GACON Florian
Add docker build job
parent e81b95ac
*.egg-info
......@@ -19,6 +19,7 @@ default:
conda_build:
stage: build
before_script:
- echo skip before_script
script:
- conda update -n base -c defaults conda
- conda install conda-build git anaconda-client conda-verify
......@@ -54,6 +55,7 @@ coverage:
anaconda_master :
stage: deploy
before_script:
script:
- conda update --all
......@@ -70,6 +72,7 @@ anaconda_master :
anaconda_develop :
stage: deploy
before_script:
script:
......@@ -101,3 +104,22 @@ pages:
only:
- develop
- master
docker_build_deploy:
image: docker:latest
stage: deploy
services:
- docker:dind
variables:
IMAGE_TAG: $CI_REGISTRY_IMAGE:$CI_COMMIT_REF_SLUG
script:
- docker login -u $CI_REGISTRY_USER -p $CI_REGISTRY_PASSWORD $CI_REGISTRY
- docker build -t $IMAGE_TAG .
- docker push $IMAGE_TAG
retry:
max: 2
when: runner_system_failure
only:
- develop
- master
# To build:
# docker build -t bvpy .
# To run:
# docker run -it bvpy
# To purge build:
# docker rm $(docker ps -a -q)
# To purge images:
# docker images -a | grep "pattern" | awk '{print $3}' | xargs docker rmi
FROM continuumio/miniconda3
MAINTAINER Florian Gacon <florian.gacon@inria.fr>
USER root
SHELL ["/bin/bash","--login", "-c"]
COPY src /opt/bvpy/src
COPY setup.py /opt/bvpy
COPY README.rst /opt/bvpy
COPY HISTORY.rst /opt/bvpy
COPY conda/env.yaml /opt/bvpy
WORKDIR /home/bvpy
ENV CONDA_DIR=/opt/conda
ENV PATH /opt/conda/envs/bvpy/bin:$PATH
RUN conda init bash && \
conda update -n base -c defaults conda && \
conda env create -f /opt/bvpy/env.yaml && \
echo "source activate bvpy" > ~/.bashrc && \
source /root/.bashrc && \
cd /opt/bvpy && python setup.py install && \
conda clean -afy
CMD ["/bin/bash", "-c""]
