GitLab
Explore
Primary navigation
Search or go to…
A
Alignment API
Manage
Plan
Issue boards
Code
Repository graph
Compare revisions
Build
Pipeline schedules
Artifacts
Deploy
Package Registry
Model registry
Operate
Environments
Terraform modules
Monitor
Incidents
Service Desk
Analyze
Value stream analytics
Contributor analytics
CI/CD analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
moex
Alignment API
643b9478
643b9478
15 years ago
Jérôme Euzenat
Downloads
Patches
- Moved to Properties instead of Parameters
1fd4d726
Branches containing commit
Tags containing commit
html/tutorial/tutorial3/NewMatcher.java
+49
-60
49 additions, 60 deletions
49 additions
60 deletions
49
60
643b9478
* $Id
: Skeleton.java 1106 2010-01-20 11:00 euzenat
* $Id$
* Copyright (C) 2006-2010, INRIA
Rhône-Alpes
* Modifications to the initial code base are copyright of their
* respective authors, or their employers as appropriate. Authorship
@@ -27,13 +27,13 @@
@@ -27,13 +27,13 @@
// Alignment API classes
import
org.semanticweb.owl.align.Alignment
import
import
org.semanticweb.owl.align.AlignmentProcess
import
import
org.semanticweb.owl.align.Parameters
import
org.semanticweb.owl.align.AlignmentException
import
// Alignment API implementation classes
import
fr.inrialpes.exmo.align.impl.ObjectAlignment
import
import
java.net.URI
import
java.net.URI
import
java.util.Properties
* The Skeleton of code for extending the alignment API
@@ -42,63 +42,52 @@ import java.net.URI;
public
class
NewMatcher
extends
ObjectAlignment
implements
AlignmentProcess
public
class
NewMatcher
extends
ObjectAlignment
implements
AlignmentProcess
public
NewMatcher
public
NewMatcher
/* The only method to implement is align.
All the resources for reading the ontologies and rendering the alignment are from ObjectAlignment and its superclasses:
* All the resources for reading the ontologies and rendering the alignment are from ObjectAlignment and its superclasses:
* - ontology1() and ontology2() returns objects LoadedOntology
* - addAlignCell adds a new mapping in the alignment object
public
void
align
Alignment
alignment
Properties
param
throws
AlignmentException
try
// Match classes
for
Object
cl2:
ontology2
getClasses
for
Object
cl1:
ontology1
getClasses
// add mapping into alignment object
addAlignCell
cl1
cl2
match
cl1
cl2
// Match dataProperties
for
Object
p2:
ontology2
getDataProperties
for
Object
p1:
ontology1
getDataProperties
addAlignCell
p1
p2
match
p1
p2
// Match objectProperties
for
Object
p2:
ontology2
getObjectProperties
for
Object
p1:
ontology1
getObjectProperties
addAlignCell
p1
p2
match
p1
p2
catch
Exception
e
e
printStackTrace
* *Very* simple matcher, based on equality of names (in the example, only classes and properties)
public
double
match
Object
o1
Object
o2
throws
AlignmentException
String
s1
ontology1
getEntityName
o1
public
void
align
Alignment
alignment
Parameters
param
throws
AlignmentException
String
s2
ontology2
getEntityName
o2
if
s1
null
s2
null
return
try
if
s1
toLowerCase
equals
s2
toLowerCase
// Match classes
return
1.0
for
Object
cl2:
ontology2
getClasses
else
for
Object
cl1:
ontology1
getClasses
return
addAlignCell
cl1
cl2
match
cl1
cl2
for
Object
p2:
ontology2
getDataProperties
for
Object
p1:
ontology1
getDataProperties
addAlignCell
p1
p2
match
p1
p2
for
Object
p2:
ontology2
getObjectProperties
for
Object
p1:
ontology1
getObjectProperties
addAlignCell
p1
p2
match
p1
p2
catch
Exception
e
e
printStackTrace
public
double
match
Object
o1
Object
o2
throws
AlignmentException
String
s1
ontology1
getEntityName
o1
String
s2
ontology2
getEntityName
o2
if
s1
null
s2
null
return
if
s1
toLowerCase
equals
s2
toLowerCase
return
1.0
else
return
This diff is collapsed.
Loading
Save comment
