Commit 643b9478 authored by Jérôme Euzenat's avatar Jérôme Euzenat
- Moved to Properties instead of Parameters
parent 1fd4d726
* $Id: Skeleton.java 1106 2010-01-20 11:00 euzenat $
* $Id$
* Copyright (C) 2006-2010, INRIA Rhône-Alpes
* Modifications to the initial code base are copyright of their
* respective authors, or their employers as appropriate. Authorship
......@@ -27,13 +27,13 @@
// Alignment API classes
import org.semanticweb.owl.align.Alignment;
import org.semanticweb.owl.align.AlignmentProcess;
import org.semanticweb.owl.align.Parameters;
import org.semanticweb.owl.align.AlignmentException;
// Alignment API implementation classes
import fr.inrialpes.exmo.align.impl.ObjectAlignment;
import java.net.URI;
import java.util.Properties;
* The Skeleton of code for extending the alignment API
......@@ -42,63 +42,52 @@ import java.net.URI;
public class NewMatcher extends ObjectAlignment implements AlignmentProcess{
public NewMatcher() {
/* The only method to implement is align.
All the resources for reading the ontologies and rendering the alignment are from ObjectAlignment and its superclasses:
* All the resources for reading the ontologies and rendering the alignment are from ObjectAlignment and its superclasses:
* - ontology1() and ontology2() returns objects LoadedOntology
* - addAlignCell adds a new mapping in the alignment object
public void align( Alignment alignment, Properties param ) throws AlignmentException {
try {
// Match classes
for ( Object cl2: ontology2().getClasses() ){
for ( Object cl1: ontology1().getClasses() ){
// add mapping into alignment object
addAlignCell(cl1,cl2,"=",match(cl1,cl2));
// Match dataProperties
for ( Object p2: ontology2().getDataProperties() ){
for ( Object p1: ontology1().getDataProperties() ){
addAlignCell(p1,p2,"=",match(p1,p2));
// Match objectProperties
for ( Object p2: ontology2().getObjectProperties() ){
for ( Object p1: ontology1().getObjectProperties() ){
} catch (Exception e) { e.printStackTrace(); }
public void align( Alignment alignment, Parameters param ) throws AlignmentException {
try {
// Match classes
*Very* simple matcher, based on equality of names (in the example, only classes and properties)
public double match(Object o1, Object o2) throws AlignmentException {
String s1 = ontology1().getEntityName(o1);
String s2 = ontology2().getEntityName(o2);
if (s1 == null || s2 == null) return 0.;
if (s1.toLowerCase().equals(s2.toLowerCase())) {
return 1.0;
} else {
return 0.;
* *Very* simple matcher, based on equality of names (in the example, only classes and properties)
return 1.0;
} else {
return 0.;
