Commit b928a0d4 authored by Léo Ackermann's avatar Léo Ackermann
:pencil: Add doc on float formatting
parent 8de54a62
......@@ -11,7 +11,7 @@ USAGE
nwk2phy -h/--help
⟹ Display this message
nwk2phy <newick file> --out=<outfile> [--ord=<order>]
nwk2phy <newick file> --out=<outfile> [--ord=<order>, --sn=<prec>, --ssn=<prec>]
⟹ Convert the input Newick file into a Phylip distance matrix
<order> is the order of the matrix rows, the leftmost being the smallest
......@@ -19,3 +19,7 @@ USAGE
LEAVES is the left-to-right leaves order of the tree (default)
LEXICO is the lexicographic order
RANDOM is a random order
<prec> is the either
- the number of digits after the coma in the scientif notation (--sn)
- the smallest significative number (--ssn)
