GitLab
Explore
Primary navigation
Search or go to…
A
aevol-eukaryotes
Manage
Plan
Issue boards
Code
Merge requests
Repository graph
Compare revisions
Deploy
Model registry
Monitor
Incidents
Service Desk
Analyze
Value stream analytics
Contributor analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
LUISELLI Juliette
aevol-eukaryotes
676384c4
676384c4
1 year ago
David Parsons
Downloads
Patches
remove stale conditional
4a4d39ac
src/aevol_create.cpp
+1
-5
1 addition, 5 deletions
1 addition
5 deletions
5
676384c4
@@ -95,11 +95,7 @@ int main(int argc, char* argv[]) {
if
param_file_name
nullptr
if
param_file_name
nullptr
if
chromosomes
size
ParamLoader
load
param_values
exp_manager
chromosomes
true
ParamLoader
load
param_values
exp_manager
chromosomes
true
else
ParamLoader
load
param_values
exp_manager
true
// 8) Save the experiment
This diff is collapsed.
Loading
Save comment
