Commit b95060f3 authored by Jérémie Gaidamour's avatar Jérémie Gaidamour
[dev] Command line options + download 'oarnodes -Y' with ssh
parent 5f994c4e
...@@ -92,7 +92,7 @@ def get_node_properties(cluster_uid, cluster, node_uid, node) ...@@ -92,7 +92,7 @@ def get_node_properties(cluster_uid, cluster, node_uid, node)
end end
h['max_walltime'] = node['supported_job_types']['max_walltime'] || 0 h['max_walltime'] = node['supported_job_types']['max_walltime'] || 0
h return h
end end
...@@ -190,11 +190,42 @@ def oarcmd_set_node_properties(host, properties) ...@@ -190,11 +190,42 @@ def oarcmd_set_node_properties(host, properties)
return command return command
end end
# Get the OAR properties from the OAR scheduler
# This is only needed for the -d option
def oarcmd_get_nodelist_properties(site_uid, filename=nil)
oarnodes_yaml = ""
if filename and File.exist?(filename)
# Read oar properties from file
puts "Read 'oarnodes -Y' from #{filename}"
oarnodes_yaml = File.open(filename, 'rb') { |f| f.read }
else
# Download the oar properties from the oar server
puts "Downloading 'oarnodes -Y' from oar.#{site_uid}.g5kadmin ..."
Net::SSH.start("oar.#{site_uid}.g5kadmin", 'g5kadmin', :keys => ['~/.ssh/id_rsa_g5k', '~/.ssh/id_rsa_g5kadmin.pub']) do |ssh|
# capture all stderr and stdout output from a remote process
oarnodes_yaml = ssh.exec!('oarnodes -Y')
# puts output
puts "... done"
def oarcmd_get_nodelist_properties() if filename
# Get the current OAR properties from the OAR scheduler # Cache the file
h = YAML.load_file('../../JG/nancy-oarnodes.yaml') puts "Save 'oarnodes -Y' as #{filename}"
File.write(filename, oarnodes_yaml)
# Load the YAML file into an hashtable
h = YAML.load(oarnodes_yaml)
# Format convertion: use host as keys of the hash (instead of id)
h = h.map {|k, v| v['type'] == 'default' ? [v['host'].split('.').first, v] : [nil, nil] }.to_h h = h.map {|k, v| v['type'] == 'default' ? [v['host'].split('.').first, v] : [nil, nil] }.to_h
return h return h
end end
...@@ -6,180 +6,127 @@ require 'fileutils' ...@@ -6,180 +6,127 @@ require 'fileutils'
require 'pathname' require 'pathname'
require 'json' require 'json'
require 'time' require 'time'
require 'yaml'
require 'hashdiff'
require 'optparse'
require 'net/ssh'
require '../oar-properties/lib/lib-oar-properties'
require '../lib/input_loader' require '../lib/input_loader'
# Output directory options = {}
refapi_path = "/tmp/data" options[:sites] = %w{grenoble lille luxembourg lyon nantes reims rennes sophia}
options[:diff] = false
#global_hash = JSON.parse(STDIN.read) OptionParser.new do |opts|
#global_hash = load_yaml_file_hierarchy("../../input/example/") opts.banner = "Usage: oar-properties.rb [options]"
global_hash = load_yaml_file_hierarchy("../../input/grid5000/")
class Hash opts.separator ""
# sort a hash according to the position of the key in the array opts.separator "Example: ruby oar-properties.rb -v -s nancy -d oarnodes-%s.yaml -o cmd-%s.sh"
def sort_by_array(array)
Hash[sort_by{|key, _| array.index(key) || length}] opts.separator ""
end opts.separator "Filters:"
# Write pretty and sorted JSON files opts.on('-s', '--sites a,b,c', Array, 'Select site(s)',
def write_json(filepath, data) "Default: "+options[:sites].join(", ")) do |s|
def rec_sort(h) options[:sites] = s
case h
when Array
h.map{|v| rec_sort(v)}#.sort_by!{|v| (v.to_s rescue nil) }
when Hash
Hash[Hash[h.map{|k,v| [rec_sort(k),rec_sort(v)]}].sort_by{|k,v| [(k.to_s rescue nil), (v.to_s rescue nil)]}]
else
h
end end
File.open(filepath, 'w') do |f|
f.write(JSON.pretty_generate(rec_sort(data))) opts.on('-c', '--clusters a,b,c', Array, 'Select clusters(s). Default: all') do |s|
options[:clusters] = s
end end
# Parse network equipment description and return switch name and port connected to given node opts.on('-n', '--nodes a,b,c', Array, 'Select nodes(s). Default: all') do |n|
# In the network description, if the node interface is given (using "port" attribute), options[:nodes] = n
# the interface parameter must be used.
def net_switch_port_lookup(site, node_uid, interface='')
site["net-links"].each do |switch_uid, switch| # TODO: rename net-links<->network
#pp switch_uid
switch["linecards"].each do |lc_uid,lc|
lc["ports"].each do |port_uid,port|
if port.is_a?(Hash)
switch_remote_port = port["port"] || lc["port"] || ""
switch_remote_uid = port["uid"]
else
switch_remote_port = lc["port"] || ""
if switch_remote_uid == node_uid and switch_remote_port == interface
# Build port name from snmp_naming_pattern
# Example: '3 2 GigabitEthernet%LINECARD%/%PORT%' -> 'GigabitEthernet3/2'
port_name = lc["snmp_pattern"].sub("%LINECARD%",lc_uid.to_s).sub("%PORT%",port_uid.to_s)
return switch_uid, port_name
end end
return nil
global_hash["sites"].each do |site_uid, site| ###
pp site_uid
# pp site
site["clusters"].each do |cluster_uid, cluster| opts.separator ""
pp cluster_uid opts.separator "Output options:"
cluster_path = Pathname.new(refapi_path).join("sites",site_uid,"clusters",cluster_uid) opts.on('-o', '--output', 'Output oarnodesetting command into a file. Default: stdout') do |o|
cluster_path.join("nodes").mkpath() options[:output] = o
# Write cluster info w/o nodes entries opts.on('-e', '--exec', 'Directly apply the changes to the OAR server') do |e|
cluster["type"] = "cluster" options[:exec] = e
cluster["uid"] = cluster_uid end
# On the previous version of this script, cluster["created_ad"] was generated from a Ruby Time. cluster["created_ad"] is now a Ruby Date at JSON import. opts.on("-d", "--diff [YAML filename]",
# As Date.httpdate and Time.httpdate does not behave the same with timezone, it is converted here as a Ruby time. "Only generates the minimal list of commands needed to update the site configuration",
cluster["created_at"] = Time.parse(cluster["created_at"].to_s).httpdate "The optional YAML file is suppose to be the output of the 'oarnodes -Y' command.",
"If the file does not exist, the script will get the data from the OAR server and save the result on disk for future use.",
write_json(cluster_path.join("#{cluster_uid}.json"), "If no filename is specified, the script will simply connect to the OAR server.",
cluster.reject {|k, v| k == "nodes"}) "You can use the '%s' placeholder for 'site'. Ex: oarnodes-%s.yaml") do |d|
d = true if d == nil
options[:diff] = d
# Write node info # opts.on("-n", "--dry-run", "Perform a trial run with no changes made") do |n|
cluster["nodes"].each do |node_uid, node| # options[:dryrun] = n
pp node_uid # end
# next unless node_uid == "griffon-1" ###
node["uid"] = node_uid
node["type"] = "node" opts.separator ""
if node.key?("processor") opts.separator "Common options:"
node["processor"]["cache_l1"] = nil unless node["processor"].key?("cache_l1")
end opts.on("-v", "--[no-]verbose", "Run verbosely") do |v|
options[:verbose] = v
# Add default keys
node["gpu"] = {} unless node.key?("gpu")
node["gpu"]["gpu"] = false unless node["gpu"].key?("gpu")
node["main_memory"] = {} unless node.key?("main_memory")
node["main_memory"]["virtual_size"] = nil unless node["main_memory"].key?("virtual_size")
# node["monitoring"] = {} unless node.key?("monitoring")
# node["monitoring"]["wattmeter"] = false unless node["monitoring"].key?("wattmeter")
# Rename keys
node["storage_devices"] = node.delete("block_devices")
node["network_adapters"] = node.delete("network_interfaces")
if node.key?("chassis")
node["chassis"]["name"] = node["chassis"].delete("product_name")
node["chassis"]["serial"] = node["chassis"].delete("serial_number")
# Type conversion
node["network_adapters"].each { |key, hash| hash["rate"] = hash["rate"].to_i if hash["rate"].is_a?(Float) }
# Convert hashes to arrays
node["storage_devices"].each { |key, hash| node["storage_devices"][key]["device"] = key; } # Add "device: sdX" within the hash
node["storage_devices"] = node["storage_devices"].sort_by_array(["sda", "sdb", "sdc", "sdd", "sde"]).values
node["network_adapters"].each { |key, hash| node["network_adapters"][key]["device"] = key; } # Add "device: ethX" within the hash
node["network_adapters"] = node["network_adapters"].sort_by_array(["eth0", "eth1", "eth2", "eth3", "ib0", "ib1", "ib2", "ib3", "bmc"]).values
# Populate "network_address", "switch" and "switch_port" from the network equipment description for each network adapters
node["network_adapters"].each { |network_adapter|
# ib properties
network_adapter["ib_switch_card"] = network_adapter.delete("line_card") if network_adapter.key?("line_card")
network_adapter["ib_switch_card_pos"] = network_adapter.delete("position") if network_adapter.key?("position")
next unless network_adapter["enabled"]
# Management network_adapter (bmc)
if network_adapter["management"]
network_adapter["network_address"] = "#{node_uid}-bmc.#{site_uid}.grid5000.fr"
next
# if network_adapter["network_address"] or network_adapter["switch"] or network_adapter["switch_port"]
# pp "Warning: network_address, switch or switch_port defined manually for (#{node_uid}, #{network_adapter["device"]})"
# pp "#{network_adapter["network_address"]}, #{network_adapter["switch"]} or #{network_adapter["switch_port"]}"
# end
if network_adapter["mounted"] and /^eth[0-9]$/.match(network_adapter["device"])
# Primary network_adapter
network_adapter["network_address"] = "#{node_uid}.#{site_uid}.grid5000.fr"
# Interface may not be specified in Network Reference for primary network_adapter
network_adapter["switch"], network_adapter["switch_port"] = net_switch_port_lookup(site, node_uid, network_adapter["device"]) || net_switch_port_lookup(site, node_uid)
# network_adapter["bridged"] = true # TODO?
next
# if network_adapter["bridged"]
# Secondary network_adapter(s)
network_adapter["network_address"] = "#{node_uid}-#{network_adapter["device"]}.#{site_uid}.grid5000.fr"
switch, port = net_switch_port_lookup(site, node_uid, network_adapter["device"])
network_adapter["switch"] = switch if switch
network_adapter["switch_port"] = port if port
# end
if node.key?("sensors") and node.key?("pdu") and node["pdu"].key?("pdu_name")
node["sensors"]["power"] = {} unless node["sensors"].key?("power")
node["sensors"]["power"]["via"] = {} unless node["sensors"]["power"].key?("via")
node["sensors"]["power"]["via"]["pdu"] = [] unless node["sensors"]["power"]["via"].key?("pdu")
node["sensors"]["power"]["via"]["pdu"][0] = {} unless node["sensors"]["power"]["via"]["pdu"].size > 0
node["sensors"]["power"]["via"]["pdu"][0]["uid"] = node["pdu"]["pdu_name"]
node["sensors"]["power"]["via"]["pdu"][0]["port"] = node["pdu"]["pdu_position"] if node["pdu"].key?("pdu_position")
node.delete("pdu")
#pp cluster_path.join("nodes","#{node_uid}.json")
write_json(cluster_path.join("nodes","#{node_uid}.json"), node)
end end
# Print an options summary.
opts.on_tail("-h", "--help", "Show this message") do
puts opts
exit
end.parse!
pp options
# Option
site_uid = 'nancy'
nodelist_properties = {}
# Get the OAR properties from the reference-repo
global_hash = load_yaml_file_hierarchy('../../input/grid5000/')
nodelist_properties["ref"] = get_nodelist_properties(site_uid, global_hash["sites"][site_uid])
nodelist_properties["oar"] = {}
if options[:diff]
filename = options[:diff].is_a?(String) ? options[:diff].gsub("%s", site_uid) : nil
nodelist_properties["oar"] = oarcmd_get_nodelist_properties(site_uid, filename)
end end
# Diff
node_properties = {}
node_properties["ref"] = nodelist_properties["ref"]["graphene-1"]
node_properties["oar"] = nodelist_properties["oar"]["graphene-1"]
diff = diff_node_properties(node_properties["ref"], node_properties["oar"])
diff_keys = diff.map{ |hashdiff_array| hashdiff_array[1] }
node_properties["to_be_updated"] = node_properties["ref"].select { |key, value| diff_keys.include?(key) }
# Example
puts oarcmd_set_node_properties("graphene-1", node_properties["oar"])
puts oarcmd_set_node_properties("graphene-1", node_properties["to_be_updated"])
