GitLab
Explore
Primary navigation
Search or go to…
R
reference-repository
Manage
Plan
Code
Merge requests
Repository graph
Compare revisions
Build
Pipeline schedules
Artifacts
Deploy
Model registry
Operate
Environments
Analyze
Value stream analytics
Contributor analytics
CI/CD analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
grid5000
5b446743
5b446743
4 years ago
Pierre Neyron
Downloads
Patches
graffiti all gpus
85d215d5
1 merge request
!103
11903 set the chassis property
2
Expand all
2 changed files
spec/output/graffiti-all-gpus_diff_stdout.txt
+27
-13
27 additions, 13 deletions
spec/output/graffiti-all-gpus_print_stdout.txt
+14
-13
14 additions, 13 deletions
41 additions
26 deletions
27
13
5b446743
Downloading resources properties from https://api.grid5000.fr/stable/sites/fakesite/internal/oarapi/resources/details.json?limit=999999 ...
... done
... done
Output format: [ '-', 'key', 'value'] for missing, [ '+', 'key', 'value'] for added, ['~', 'key', 'old value', 'new value'] for changed
clustera-1: OK
clustera-1:
clustera-2: OK
["~", "chassis", nil, "Dell Inc. PowerEdge T640 FL1CBX2"]
clustera-3: OK
clustera-2:
clustera-4: OK
["~", "chassis", nil, "Dell Inc. PowerEdge T640 9L1CBX2"]
clustera-5: OK
clustera-3:
clustera-6: OK
["~", "chassis", nil, "Dell Inc. PowerEdge T640 BL1CBX2"]
clustera-7: OK
clustera-4:
clustera-8: OK
["~", "chassis", nil, "Dell Inc. PowerEdge T640 DL1CBX2"]
clustera-9: OK
clustera-5:
clustera-10: OK
["~", "chassis", nil, "Dell Inc. PowerEdge T640 CL1CBX2"]
clustera-11: OK
clustera-6:
clustera-12: OK
["~", "chassis", nil, "Dell Inc. PowerEdge T640 8K1CBX2"]
clustera-13: OK
clustera-7:
["~", "chassis", nil, "Dell Inc. PowerEdge T640 BK1CBX2"]
clustera-8:
["~", "chassis", nil, "Dell Inc. PowerEdge T640 CK1CBX2"]
clustera-9:
["~", "chassis", nil, "Dell Inc. PowerEdge T640 9K1CBX2"]
clustera-10:
["~", "chassis", nil, "Dell Inc. PowerEdge T640 GL1CBX2"]
clustera-11:
["~", "chassis", nil, "Dell Inc. PowerEdge T640 JL1CBX2"]
clustera-12:
["~", "chassis", nil, "Dell Inc. PowerEdge T640 HL1CBX2"]
clustera-13:
["~", "chassis", nil, "Dell Inc. PowerEdge T640 7K1CBX2"]
Properties that need to be created on the fakesite server: chassis
Properties existing on the fakesite server but not managed/known by the generator: disk, diskpath.
Hint: you can delete properties with 'oarproperty -d <property>' or add them to the ignore list in lib/lib-oar-properties.rb.
This diff is collapsed.
14
13
5b446743
Loading
Save comment
