Commit 2a178ddb authored by Pierre Neyron's avatar Pierre Neyron :bicyclist:
graffiti gpu removed OAR updated gpu re added OAR updated
parent 07b652ca
1 merge request!10311903 set the chassis property
Downloading resources properties from https://api.grid5000.fr/stable/sites/fakesite/internal/oarapi/resources/details.json?limit=999999 ...
... done
Output format: [ '-', 'key', 'value'] for missing, [ '+', 'key', 'value'] for added, ['~', 'key', 'old value', 'new value'] for changed
clustera-1: OK
clustera-2: OK
clustera-3: OK
clustera-4: OK
clustera-5: OK
clustera-6: OK
clustera-7: OK
clustera-8: OK
clustera-9: OK
clustera-10: OK
clustera-11: OK
clustera-12: OK
clustera-13: OK
clustera-1:
["~", "chassis", nil, "Dell Inc. PowerEdge T640 FL1CBX2"]
clustera-2:
["~", "chassis", nil, "Dell Inc. PowerEdge T640 9L1CBX2"]
clustera-3:
["~", "chassis", nil, "Dell Inc. PowerEdge T640 BL1CBX2"]
clustera-4:
["~", "chassis", nil, "Dell Inc. PowerEdge T640 DL1CBX2"]
clustera-5:
["~", "chassis", nil, "Dell Inc. PowerEdge T640 CL1CBX2"]
clustera-6:
["~", "chassis", nil, "Dell Inc. PowerEdge T640 8K1CBX2"]
clustera-7:
["~", "chassis", nil, "Dell Inc. PowerEdge T640 BK1CBX2"]
clustera-8:
["~", "chassis", nil, "Dell Inc. PowerEdge T640 CK1CBX2"]
clustera-9:
["~", "chassis", nil, "Dell Inc. PowerEdge T640 9K1CBX2"]
clustera-10:
["~", "chassis", nil, "Dell Inc. PowerEdge T640 GL1CBX2"]
clustera-11:
["~", "chassis", nil, "Dell Inc. PowerEdge T640 JL1CBX2"]
clustera-12:
["~", "chassis", nil, "Dell Inc. PowerEdge T640 HL1CBX2"]
clustera-13:
["~", "chassis", nil, "Dell Inc. PowerEdge T640 7K1CBX2"]
Properties that need to be created on the fakesite server: chassis
Properties existing on the fakesite server but not managed/known by the generator: disk, diskpath.
Hint: you can delete properties with 'oarproperty -d <property>' or add them to the ignore list in lib/lib-oar-properties.rb.
