Commit c02ce127 authored by Nicolas Perrin's avatar Nicolas Perrin
Revert "Merge branch 'nvidia-docker_debian11' into 'master'"
This reverts commit ba3db175, reversing
changes made to ed35ace2.
parent 763b9b5e
1 merge request!3[g5k-setup-nvidia-docker] Remove Debian 11 temporary workaround
...@@ -28,20 +28,9 @@ def main ...@@ -28,20 +28,9 @@ def main
# (probably because it exists on ubuntu) # (probably because it exists on ubuntu)
ret &= sh('sudo ln -s /sbin/ldconfig /sbin/ldconfig.real').first ret &= sh('sudo ln -s /sbin/ldconfig /sbin/ldconfig.real').first
else else
distrib_codename = `lsb_release -cs`.strip ret &= sh('. /etc/os-release; curl -s -L https://nvidia.github.io/nvidia-docker/$ID$VERSION_ID/nvidia-docker.list | sudo tee /etc/apt/sources.list.d/nvidia-docker.list').first
# Workaround: use Debian 10 image if Debian 11 host (cf. Bug #13532)
if distrib_codename == 'bullseye'
ret &= sh('curl -s -L https://nvidia.github.io/nvidia-docker/debian10/nvidia-docker.list | sudo tee /etc/apt/sources.list.d/nvidia-docker.list').first
puts "Warning: As Nvidia Docker Debian 11 image is not currently released, Nvidia Docker Debian 10 image is used !"
else
end end
ret &= sh('sudo apt-get update && sudo apt-get install -y nvidia-container-toolkit').first ret &= sh('sudo apt-get update && sudo apt-get install -y nvidia-container-toolkit').first
# Workaround if Debian 11 host (cf. Bug #13532)
ret &= sh('sudo sed -i \'s|^#ldconfig.*|ldconfig = "/sbin/ldconfig"|\' /etc/nvidia-container-runtime/config.toml').first
ret &= sh('sudo systemctl restart docker').first ret &= sh('sudo systemctl restart docker').first
ret &= sh('sudo chmod o+rw /var/run/docker.sock').first if !options[:install] ret &= sh('sudo chmod o+rw /var/run/docker.sock').first if !options[:install]
ret ret
