GitLab
Explore
Primary navigation
Search or go to…
G
grid5000-code
Manage
Plan
Code
Merge requests
Repository graph
Compare revisions
Build
Pipeline schedules
Artifacts
Deploy
Model registry
Operate
Environments
Analyze
Value stream analytics
Contributor analytics
CI/CD analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
grid5000
grid5000-code
c02ce127
c02ce127
3 years ago
Nicolas Perrin
Downloads
Patches
Revert "Merge branch 'nvidia-docker_debian11' into 'master'"
This reverts commit
ba3db175
, reversing changes made to
ed35ace2
763b9b5e
Branches containing commit
Tags containing commit
1 merge request
!3
[g5k-setup-nvidia-docker] Remove Debian 11 temporary workaround
bin/g5k-setup-nvidia-docker
+1
-12
1 addition, 12 deletions
1 addition
12 deletions
12
c02ce127
@@ -28,20 +28,9 @@ def main
# (probably because it exists on ubuntu)
ret
sh
'sudo ln -s /sbin/ldconfig /sbin/ldconfig.real'
first
else
distrib_codename
`lsb_release -cs`
strip
# Workaround: use Debian 10 image if Debian 11 host (cf. Bug #13532)
if
distrib_codename
'bullseye'
ret
sh
'curl -s -L https://nvidia.github.io/nvidia-docker/debian10/nvidia-docker.list | sudo tee /etc/apt/sources.list.d/nvidia-docker.list'
first
puts
"Warning: As Nvidia Docker Debian 11 image is not currently released, Nvidia Docker Debian 10 image is used !"
else
ret
sh
'. /etc/os-release; curl -s -L https://nvidia.github.io/nvidia-docker/$ID$VERSION_ID/nvidia-docker.list | sudo tee /etc/apt/sources.list.d/nvidia-docker.list'
first
ret
sh
first
ret
sh
'sudo apt-get update && sudo apt-get install -y nvidia-container-toolkit'
first
# Workaround if Debian 11 host (cf. Bug #13532)
if
distrib_codename
'bullseye'
ret
sh
'sudo sed -i \'s|^#ldconfig.*|ldconfig = "/sbin/ldconfig"|\' /etc/nvidia-container-runtime/config.toml'
first
ret
sh
'sudo systemctl restart docker'
first
ret
sh
'sudo chmod o+rw /var/run/docker.sock'
first
if
options
:install
ret
This diff is collapsed.
Loading
Save comment
