GitLab
Explore
Primary navigation
Search or go to…
faust
Manage
Plan
Issue boards
Code
Merge requests
Repository graph
Compare revisions
Build
Pipeline schedules
Artifacts
Deploy
Package registry
Model registry
Operate
Environments
Terraform modules
Monitor
Incidents
Service Desk
Analyze
Value stream analytics
Contributor analytics
CI/CD analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Admin message
GitLab upgrade completed. Current version is 17.11.3.
Show more breadcrumbs
faust group
faust
5d77c102
5d77c102
2 years ago
hhakim
Downloads
Patches
Set priority of CUDA versions in gpu_mod lib loading.
f218a10c
Branches containing commit
Tags containing commit
Pipeline
#834172
skipped
wrapper/python/src/_FaustCorePy.pyx
+3
-3
3 additions, 3 deletions
3 additions
3 deletions
3
3
5d77c102
@@ -88,9 +88,9 @@ def enable_gpu_mod(libpaths=None, backend='cuda', silent=False, fatal=False):
# don't use os.path.join or os.path.sep because anyway
# lib name suffix and prefix depend on OS
libpaths
libpaths
for
gpu_backend
in
-cu
9.2
-cu11.4
# the last one is
for
gpu_backend
in
-cu
12.1
-cu11.4
# the last one is
# for
descendant/backward compatibility
# for
unversioned lib
# (the
backend
are sorted per order of preference)
# (the
versions
if
sys
platform
linux
if
sys
platform
linux
libpaths
pyfaust_path
/lib/libgm
gpu_backend
.so
libpaths
pyfaust_path
/lib/libgm
gpu_backend
.so
elif
sys
platform
darwin
elif
sys
platform
darwin
This diff is collapsed.
Loading
Save comment
