Commit 5d77c102 authored by hhakim's avatar hhakim
Set priority of CUDA versions in gpu_mod lib loading.
parent f218a10c
Tags 3.38.9
Pipeline #834172 skipped
......@@ -88,9 +88,9 @@ def enable_gpu_mod(libpaths=None, backend='cuda', silent=False, fatal=False):
# don't use os.path.join or os.path.sep because anyway
# lib name suffix and prefix depend on OS
libpaths = []
for gpu_backend in ['-cu9.2', '-cu11.4', '']: # the last one is
# for descendant/backward compatibility
# (the backend are sorted per order of preference)
for gpu_backend in ['-cu12.1', '-cu11.4', '']: # the last one is
# for unversioned lib
# (the versions are sorted per order of preference)
if sys.platform == 'linux':
libpaths += [pyfaust_path+"/lib/libgm"+gpu_backend+".so"]
elif sys.platform == 'darwin':
