Commit 4c4832c1 authored by Andreas Enge's avatar Andreas Enge
Make ECPP check output conditional on debug variable.
* lib/cm-impl.h (cm_pari_ecpp_check): Add parameter to prototype.
* lib/pari.c (cm_pari_ecpp_check): Add and use parameter.
* lib/pari.c (cm_ecpp): Adapt function call.
parent 5783c89f
Loading
Loading
