GitLab
Explore
Primary navigation
Search or go to…
N
NutriMorph
Manage
Plan
Issue boards
Code
Merge requests
Repository graph
Compare revisions
Deploy
Model registry
Monitor
Incidents
Service Desk
Analyze
Value stream analytics
Contributor analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
DEBREUVE Eric
NutriMorph
e1cccbf8
e1cccbf8
4 years ago
NADAL Morgane
Downloads
Patches
dvpt of algo helping feature selection
9046d6ce
2
2 changed files
features_analysis.py
+131
-17
131 additions, 17 deletions
nutrimorph.py
+3
-73
3 additions, 73 deletions
nutrimorph.py
134 additions
90 deletions
131
17
e1cccbf8
@@ -32,13 +32,14 @@
import
pandas
as
pd_
import
numpy
as
np_
import
matplotlib.pyplot
as
pl_
import
matplotlib.gridspec
as
gs_
from
sklearn.cluster
import
KMeans
from
sklearn.decomposition
import
PCA
from
sklearn.preprocessing
import
StandardScaler
import
scipy
as
si_
import
seaborn
as
sb_
import
os
import
glob
import
sys
as
sy_
from
typing
import
@@ -195,29 +196,133 @@ def RepresentationOnImages(labeled_somas, kmeans, nb_cluster):
pl_
close
def
FeaturesStatistics
df
def
FeaturesStatistics
df
pd_
DataFrame
save_in
str
None
title
str
Return the statistics allowing the user to choose the most relevant features to feed ML algorithms for ex.
# Overview of the basic stats on each columns of df
df
describe
description
df
describe
if
save_in
is
not
None
description
to_csv
f
save_in
df_stat_description.csv
df_scalar
df
drop
duration
condition
axis
df_cond
df
drop
duration
axis
df_groupby_cond
df
drop
duration
axis
groupby
condition
df_groupby_dur
df
groupby
duration
condition
pd_
DataFrame
df
loc
condition
values
columns
condition
# Overview of features distribution and correlation
sb_
pairplot
df
kind
reg
sb_
pairplot
df
kind
reg
hue
Condition
# Statistics for each features
for
column
in
df
columns
print
column
hist
df
column
hist
bins
20
pl_
title
f
column
pl_
savefig
f
D:
MorganeNadal
M2 report
kmeans24
feat_distrib_
column
.png
## /!\ if too many features, error in seaborn display
## Even by splitting the data : too intense!
# Plot heat map with correlation matrix btw features
# Compute the correlation matrix
print
Heat map with correlation matrix btw features
corr_matrix
df_scalar
corr
abs
# Generate a mask for the upper triangle
mask
np_
triu
np_
ones_like
corr_matrix
dtype
np_
bool
# Set up the figure
fig
ax
pl_
subplots
figsize
13
9
# Generate a custom diverging colormap
cmap
sb_
diverging_palette
220
10
as_cmap
True
# Draw the heatmap with the mask and correct aspect ratio
sb_
heatmap
corr_matrix
mask
mask
cmap
cmap
center
square
True
linewidths
5
cbar_kws
shrink
5
xticklabels
False
ax
set_title
f
Features correlation heat map
title
fontsize
20
if
save_in
is
not
None
pl_
savefig
f
save_in
title
.png
pl_
close
# Drop highly correlated features
print
# Select upper triangle of correlation matrix
upper
corr_matrix
where
np_
triu
np_
ones
corr_matrix
shape
k
astype
np_
bool
# Find index of feature columns with correlation greater than 0.9
to_drop
column
for
column
in
upper
columns
if
any
upper
column
0.9
# Drop features
drop_HCF_df
df_scalar
drop
df
to_drop
axis
if
save_in
drop_HCF_df
to_csv
f
save_in
df_drop_highly_corr_feat.csv
print
f
Selection of low correlated features in:
save_in
dict_ks
dict_wx
dict_ks_dur
dict_wx_dur
for
column
in
df_scalar
columns
cond_col_df
pd_
concat
df_scalar
column
df_cond
condition
axis
fig
pl_
figure
constrained_layout
False
gs
fig
add_gridspec
ncols
2
nrows
ax1
fig
add_subplot
gs
ax2
fig
add_subplot
gs
# Plot a histogram and kernel density estimate
print
f
Plot a histogram and kernel density estimate for feature
column
CHO
cond_col_df
loc
cond_col_df
condition
CHO
DIO
cond_col_df
loc
cond_col_df
condition
DIO
sb_
distplot
CHO
column
color
b
ax
ax1
sb_
distplot
DIO
column
color
r
ax
ax1
# Draw a boxplot
print
f
Plot a boxplot for feature
column
sb_
boxplot
df_cond
x
condition
y
column
hue
condition
palette
b
r
ax
ax2
ax1
set_title
f
column
distribution
title
fontsize
11
ax2
set_title
f
column
boxplot
title
fontsize
11
pl_
tight_layout
if
save_in
is
not
None
pl_
savefig
f
save_in
feat_distrib_
column
.png
pl_
close
# Compare distribution between conditions (goodness of fit)
print
f
Kolmogorov-Smirnov between conditions
ks
si_
stats
kstest
CHO
column
DIO
column
dict_ks
column
ks
# Compare median between conditions
print
f
Wilcoxon signed-rank test between conditions
wx
si_
stats
wilcoxon
CHO
column
DIO
column
dict_wx
column
wx
# For each duration between conditions
for
duration
values
in
df_groupby_dur
dict_ks_dur
duration
dict_wx_dur
duration
duration_df
values
drop
duration
CHO_
duration_df
loc
duration_df
condition
CHO
DIO_
duration_df
loc
duration_df
condition
DIO
print
f
ks2
si_
stats
kstest
CHO
column
DIO
column
dict_ks_dur
duration
column
ks2
# Compare median
print
f
wx2
si_
stats
kstest
CHO
column
DIO
column
dict_wx_dur
duration
column
wx2
df_ks
pd_
DataFrame
from_dict
df_wx
pd_
DataFrame
from_dict
df_ks_dur
pd_
DataFrame
from_dict
df_wx_dur
pd_
DataFrame
from_dict
stat_tests_df
pd_
concatenate
df_ks
df_wx
df_ks_dur
df_wx_dur
if
__name__
__main__
# os.chdir("
D:\\MorganeNadal\\2_RESULTS\\Results_wo_erosion
# os.chdir("
path
## If need to concatenate files:
# all_filenames = [i for i in glob.glob('*.{}'.format("csv"))]
@@ -226,10 +331,13 @@ if __name__ == "__main__":
# df.to_csv(".\combined_features.csv")
## If use labeled somas:
# labeled_somas = np_.load("
D:\\MorganeNadal\\Results\\labeled_somas
.npy")
path
.npy")
# df = pd_.read_csv(".\combined_features.csv", index_col=0)
df0
pd_
read_csv
D:
MorganeNadal
2_RESULTS
Results_wo_erosion
all_features.csv
# path = sy_.argv[1]
path
D:
MorganeNadal
2_RESULTS
Results_wo_erosion
df0
pd_
read_csv
path
# index_col=0,
df
df0
drop
Unnamed: 0
axis
@@ -295,9 +403,15 @@ if __name__ == "__main__":
# title=f" - {duration} Sample",
## -- Select Discriminant features by statistical analysis
# TODO filtered_df = SelectFeatures(concatenated_features_df)
## -- Various plots to analyse the data and find discriminant features by statistical analysis
FeaturesStatistics
df
save_in
D:
MorganeNadal
2_RESULTS
Results_wo_erosion
Features_analysis
## TODO: Enter selected features here
# selected_features = []
# selected_df = df[selected_features]
# # -- PCA with selected features
# # Between the two conditions, regardless the duration of experiment (2 conditions, all durations)
# df_all = df.drop(["duration"], axis=1)
This diff is collapsed.
nutrimorph.py
3
73
e1cccbf8
@@ -660,79 +660,9 @@ if __name__ == '__main__':
else
to_csv
f
save_csv
features.csv
# --- TODO Clustering with this df and module features_analysis.py
# if statistical_analysis:
## For the moment drop the columns with non scalar values, and un-useful values
## - TO BE CHANGED (use distance metrics such as bhattacharyya coef, etc)
# df = concatenated_features_df.drop(["soma uid",
# "spherical_angles_eva",
# "spherical_angles_evb",
# "hist_lengths",
# "hist_lengths_P",
# "hist_lengths_S",
# "hist_curvature",
# "hist_curvature_P",
# "hist_curvature_S"],
# axis=1)
## -- PCA with all the features
## Separating the features from their conditions and durations
# all_target = concatenated_features_df.loc[:, ['Condition']].values
# all_features_df = concatenated_features_df.drop(["Duration"], axis=1)
## Between the two conditions, regardless the duration of experiment (2 conditions, all durations)
# TODO pca = fa_.PCAOnDF(concatenated_features_df)
## Between the two conditions, for each duration (2 conditions, 3 durations)
# groupby_duration = concatenated_features_df.groupby("Duration")
# for duration, values in groupby_duration:
##TODO find the condition to print it on PCA
# print(duration)
# duration_features_df = concatenated_features_df.drop(["Duration"], axis=1)
# pca = fa_.PCAOnDF(values)
## -- K-means with all the features (2 conditions)
# kmeans = fa_.KmeansOnDF(concatenated_features_df, nb_clusters=(2,), elbow=True, intracluster_var=True)
# kmeans = fa_.KmeansOnDF(values, nb_clusters=(2,), elbow=True, intracluster_var=True)
## -- PCA with all the features with the cluster as label
## -- PCA with selected features
# TODO pca = fa_.PCAOnDF(filtered_df)
# filtered_groupby_duration = filtered_df.groupby("Duration")
# for duration, values in filtered_groupby_duration:
## -- K-means with selected features
# filtered_kmeans = fa_.KmeansOnDF(filtered_df, nb_clusters=(2,), elbow=True, intracluster_var=True)
# filtered_kmeans = fa_.KmeansOnDF(values, nb_clusters=(2,), elbow=True, intracluster_var=True)
# Clustering with this df and module features_analysis.py
if
os_
system
f
feature_analysis.py
save_csv
features.csv
else
raise
ImportError
Not a valid data path!
Loading
Save comment
