Commit 0e7d394a authored by TAVERNIER Vincent's avatar TAVERNIER Vincent
Add default parameter to GetBufferByName
parent 911b156e
libshadertoy (0.1.7) unstable; urgency=medium
* Add default parameter for buffer query from context
-- Vincent Tavernier <vincent.tavernier@inria.fr> Thu, 08 Feb 2018 13:15:00 +0200
libshadertoy (0.1.6) unstable; urgency=medium libshadertoy (0.1.6) unstable; urgency=medium
* Add fragment shader execution time query support (iTimeDelta) * Add fragment shader execution time query support (iTimeDelta)
...@@ -127,7 +127,7 @@ int parseOptions(string &shaderId, string &shaderApiKey, bool &dump, int argc, c ...@@ -127,7 +127,7 @@ int parseOptions(string &shaderId, string &shaderApiKey, bool &dump, int argc, c
int loadRemote(const string &shaderId, const string &shaderApiKey, int loadRemote(const string &shaderId, const string &shaderApiKey,
shadertoy::ContextConfig &contextConfig, string &imageBufferName) shadertoy::ContextConfig &contextConfig)
// Init CURL // Init CURL
curl_global_init(CURL_GLOBAL_DEFAULT); curl_global_init(CURL_GLOBAL_DEFAULT);
...@@ -281,9 +281,6 @@ int loadRemote(const string &shaderId, const string &shaderApiKey, ...@@ -281,9 +281,6 @@ int loadRemote(const string &shaderId, const string &shaderApiKey,
pair<string, shadertoy::BufferConfig> imagebuf(*contextConfig.bufferConfigs.begin()); pair<string, shadertoy::BufferConfig> imagebuf(*contextConfig.bufferConfigs.begin());
contextConfig.bufferConfigs.erase(contextConfig.bufferConfigs.begin()); contextConfig.bufferConfigs.erase(contextConfig.bufferConfigs.begin());
contextConfig.bufferConfigs.insert(imagebuf); contextConfig.bufferConfigs.insert(imagebuf);
// Fetch image buffer name
imageBufferName = imagebuf.first;
catch (exception &ex) catch (exception &ex)
...@@ -298,9 +295,7 @@ int loadRemote(const string &shaderId, const string &shaderApiKey, ...@@ -298,9 +295,7 @@ int loadRemote(const string &shaderId, const string &shaderApiKey,
return code; return code;
int render(GLFWwindow* window, int render(GLFWwindow* window, shadertoy::ContextConfig &contextConfig)
const string &imageBufferName)
int code = 0; int code = 0;
...@@ -388,15 +383,15 @@ int render(GLFWwindow* window, ...@@ -388,15 +383,15 @@ int render(GLFWwindow* window,
context.RenderScreenQuad(); context.RenderScreenQuad();
// Print execution time // Print execution time
auto buffer = context.GetBufferByName(imageBufferName); auto buffer = context.GetBufferByName();
if (buffer) if (buffer)
auto renderTime = buffer->GetElapsedTime(); auto renderTime = buffer->GetElapsedTime();
std:cerr << imageBufferName << " time: " << renderTime std::cerr << "frame time: " << renderTime
<< "ns fps: " << (1e9 / renderTime) << "ns fps: " << (1e9 / renderTime)
<< " mpx/s: " << (contextConfig.width * contextConfig.height / (renderTime / 1e3)) << " mpx/s: " << (contextConfig.width * contextConfig.height / (renderTime / 1e3))
<< std::endl; << std::endl;
// Buffer swapping // Buffer swapping
...@@ -410,7 +405,7 @@ int render(GLFWwindow* window, ...@@ -410,7 +405,7 @@ int render(GLFWwindow* window,
int performRender(shadertoy::ContextConfig &contextConfig, const string &imageBufferName) int performRender(shadertoy::ContextConfig &contextConfig)
...@@ -437,7 +432,7 @@ int performRender(shadertoy::ContextConfig &contextConfig, const string &imageBu ...@@ -437,7 +432,7 @@ int performRender(shadertoy::ContextConfig &contextConfig, const string &imageBu
glfwMakeContextCurrent(window); glfwMakeContextCurrent(window);
glfwSwapInterval(1); glfwSwapInterval(1);
code = render(window, contextConfig, imageBufferName); code = render(window, contextConfig);
glfwDestroyWindow(window); glfwDestroyWindow(window);
glfwTerminate(); glfwTerminate();
...@@ -465,13 +460,12 @@ int main(int argc, char *argv[]) ...@@ -465,13 +460,12 @@ int main(int argc, char *argv[])
contextConfig.dumpShaders = dumpShaders; contextConfig.dumpShaders = dumpShaders;
// Fetch shader code // Fetch shader code
string imageBufferName; code = loadRemote(shaderId, shaderApiKey, contextConfig);
code = loadRemote(shaderId, shaderApiKey, contextConfig, imageBufferName);
if (code > 0) if (code > 0)
// Render // Render
code = performRender(contextConfig, imageBufferName); code = performRender(contextConfig);
...@@ -256,11 +256,12 @@ public: ...@@ -256,11 +256,12 @@ public:
* Obtains the buffer object for the given name. * Obtains the buffer object for the given name.
* @param name Name of the buffer object to obtain * @param name [optional] Name of the buffer object to obtain. If empty,
* returns the image buffer.
* @return Pointer to the buffer object, or a null pointer if no such * @return Pointer to the buffer object, or a null pointer if no such
* buffer exists. * buffer exists.
std::shared_ptr<ToyBuffer> GetBufferByName(const std::string &name); std::shared_ptr<ToyBuffer> GetBufferByName(const std::string &name = std::string());
...@@ -398,11 +398,23 @@ OpenGL::Shader &RenderContext::GetScreenQuadVertexShader() ...@@ -398,11 +398,23 @@ OpenGL::Shader &RenderContext::GetScreenQuadVertexShader()
shared_ptr<ToyBuffer> RenderContext::GetBufferByName(const string &name) shared_ptr<ToyBuffer> RenderContext::GetBufferByName(const string &name)
auto it = buffers.find(name); if (name.empty())
if (it == buffers.end())
return shared_ptr<ToyBuffer>(); if (buffers.empty())
return buffers.rbegin()->second;
else
return it->second; return it->second;
