Unverified Commit cd5a1a09 authored by Henry Schreiner's avatar Henry Schreiner Committed by GitHub
chore: remove uneeded file
parent 79628ba7
import sys
try:
from skbuild import setup
except ImportError as err:
msg = (
"Please update pip, you need pip 10 or greater,\n"
" or you need to install the PEP 518 requirements in pyproject.toml yourself"
if sys.version_info < (3, 11):
print(msg, file=sys.stderr)
else:
err.add_note(msg)
raise
from setuptools import find_packages
setup(
name="scikit_build_example",
version="0.0.1",
description="a minimal example package (with pybind11)",
author="Henry Schreiner",
license="MIT",
packages=find_packages(where="src"),
package_dir={"": "src"},
cmake_install_dir="src/scikit_build_example",
include_package_data=True,
extras_require={"test": ["pytest"]},
python_requires=">=3.7",
