GitLab
Explore
Primary navigation
Search or go to…
why3
Manage
Plan
Issue boards
Code
Merge requests
Repository graph
Compare revisions
Deploy
Container registry
Monitor
Service Desk
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Admin message
GitLab upgrade completed. Current version is 17.11.4.
Show more breadcrumbs
Why3
why3
edbc438b
edbc438b
14 years ago
François Bobot
Downloads
Patches
whybench : memoization don't work??!!?? so precompute....
87b2b7a3
Branches containing commit
Tags containing commit
3
3 changed files
src/bench/whybench.ml
+19
-14
19 additions, 14 deletions
src/core/env.ml
+1
1 addition, 0 deletions
src/core/env.ml
src/core/env.mli
+2
2 additions, 0 deletions
src/core/env.mli
22 additions
14 deletions
19
14
edbc438b
@@ -313,20 +313,25 @@ let () =
let
fold_prob
acc
function
let
fold_prob
acc
function
None
_
acc
None
_
acc
Some
f
_
Some
f
_
let
gen
env
task
let
env
env
in
let
fwhy
let
task
opt_task
in
let
fname
cin
match
f
let
tlist
"stdin"
stdin
let
fname
cin
match
f
f
f
open_in
f
"stdin"
stdin
in
f
f
open_in
f
let
m
Env
read_channel
format
opt_parser
env
fname
cin
in
in
close_in
cin
let
m
Env
read_channel
format
opt_parser
env
fname
cin
in
let
th
Mnm
bindings
m
in
close_in
cin
let
map
name
th
name
Task
split_theory
th
None
task
in
let
th
Mnm
bindings
m
in
let
fold
acc
n
l
let
map
name
th
name
Task
split_theory
th
None
task
in
rev_append
map
fun
v
n
v
l
acc
in
let
fold
acc
n
l
th
map
map
fold_left
fold
in
rev_append
map
fun
v
n
v
l
acc
in
Scheduler
do_why_sync
fwhy
in
th
map
map
fold_left
fold
in
(* let gen = Env.Wenv.memoize 3 (fun env -> *)
(* let memo = Trans.store (fun task -> gen env task) in *)
(* Trans.apply memo) in *)
let
gen
_
_
tlist
in
let
gen
env
task
Scheduler
do_why_sync
gen
env
task
in
B
ptask
gen
B
ptask
gen
ptrans
transl
ptrans
transl
acc
in
acc
in
This diff is collapsed.
src/core/env.ml
edbc438b
@@ -72,6 +72,7 @@ let find_theory env sl s =
let
env_tag
env
env
env_tag
let
env_tag
env
env
env_tag
module
Wenv
Hashweak
Make
struct
type
t
env
let
tag
env_tag
(** Parsers *)
(** Parsers *)
src/core/env.mli
2
edbc438b
@@ -25,6 +25,8 @@ type env
val
env_tag
env
Hashweak
tag
val
env_tag
env
Hashweak
tag
module
Wenv
Hashweak
S
type
key
env
type
retrieve_theory
env
string
list
theory
Mnm
t
type
retrieve_theory
env
string
list
theory
Mnm
t
val
create_env
retrieve_theory
env
val
create_env
retrieve_theory
env
Loading
Save comment
