GitLab
Explore
Primary navigation
Search or go to…
why3
Manage
Plan
Issue boards
Code
Merge requests
Repository graph
Compare revisions
Deploy
Container registry
Monitor
Service Desk
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
Why3
why3
e82f52e2
e82f52e2
15 years ago
Jean-Christophe Filliâtre
Downloads
Patches
programs: no quantification over variables of type arrow _ _
f355a645
src/programs/pgm_wp.ml
+19
-13
19 additions, 13 deletions
19 additions
13 deletions
19
13
e82f52e2
@@ -47,7 +47,17 @@ let wp_ands ?(sym=false) fl =
fold_left
wp_and
sym
f_true
fl
fold_left
wp_and
sym
f_true
fl
let
wp_implies
f_implies_simp
let
wp_implies
f_implies_simp
let
wp_forall
f_forall_simp
let
is_ref_ty
env
ty
match
ty
ty_node
Tyapp
ts
_
ts_equal
ts
env
ts_ref
_
false
let
is_arrow_ty
env
ty
match
ty
ty_node
Tyapp
ts
_
ts_equal
ts
env
ts_arrow
_
false
let
wp_forall
env
v
f
if
is_arrow_ty
env
v
vs_ty
then
f
else
f_forall_simp
v
f
(* utility functions for building WPs *)
@@ -55,11 +65,11 @@ let fresh_label env =
let
ty
ty_app
env
ts_label
in
let
ty
ty_app
env
ts_label
in
create_vsymbol
id_fresh
"label"
ty
create_vsymbol
id_fresh
"label"
ty
let
wp_binder
x
tv
f
match
tv
let
wp_binder
env
x
tv
f
match
tv
Tpure
_
wp_forall
x
f
Tpure
_
wp_forall
env
x
f
Tarrow
_
f
Tarrow
_
f
let
wp_binders
fold_right
wp_binder
let
wp_binders
env
fold_right
wp_binder
env
(* replace old(t) with at(t,lab) everywhere in formula f *)
let
rec
old_label
env
lab
f
let
rec
old_label
env
lab
f
@@ -87,10 +97,6 @@ let unref_ty env ty = match ty.ty_node with
Tyapp
ts
ty
when
ts_equal
ts
env
ts_ref
ty
Tyapp
ts
ty
when
ts_equal
ts
env
ts_ref
ty
_
assert
false
_
assert
false
let
is_ref_ty
env
ty
match
ty
ty_node
Tyapp
ts
_
ts_equal
ts
env
ts_ref
_
false
(* replace !r by v everywhere in formula f *)
let
rec
unref
env
r
v
f
let
rec
unref
env
r
v
f
f_map
unref_term
env
r
v
unref
env
r
v
f
f_map
unref_term
env
r
v
unref
env
r
v
f
@@ -113,7 +119,7 @@ let quantify ?(all=false) env ef f =
let
ty
unref_ty
env
E
type_of_reference
r
in
let
ty
unref_ty
env
E
type_of_reference
r
in
let
v
create_vsymbol
id_clone
E
name_of_reference
r
ty
in
let
v
create_vsymbol
id_clone
E
name_of_reference
r
ty
in
let
f
unref
env
r
v
f
in
let
f
unref
env
r
v
f
in
wp_forall
v
f
wp_forall
env
v
f
in
in
let
s
ef
E
writes
in
let
s
ef
E
writes
in
let
s
if
all
then
E
Sref
union
ef
E
reads
s
else
s
in
let
s
if
all
then
E
Sref
union
ef
E
reads
s
else
s
in
@@ -126,9 +132,9 @@ let abstract_wp env ef (q',ql') (q,ql) =
let
f
match
res
let
f
match
res
Some
v
when
is_ref_ty
env
v
vs_ty
Some
v
when
is_ref_ty
env
v
vs_ty
let
v'
create_vsymbol
id_clone
v
vs_name
unref_ty
env
v
vs_ty
in
let
v'
create_vsymbol
id_clone
v
vs_name
unref_ty
env
v
vs_ty
in
wp_forall
v'
unref
env
E
Rlocal
v
v'
f
wp_forall
env
v'
unref
env
E
Rlocal
v
v'
f
Some
v
Some
v
wp_forall
v
f
wp_forall
env
v
f
None
None
f
f
in
in
@@ -255,7 +261,7 @@ and wp_desc env e q = match e.expr_desc with
Efun
bl
t
Efun
bl
t
let
_
q
_
q
in
let
_
q
_
q
in
let
f
wp_triple
env
t
in
let
f
wp_triple
env
t
in
wp_and
q
wp_binders
bl
f
wp_and
q
wp_binders
env
bl
f
Elet
x
e1
e2
Elet
x
e1
e2
let
w2
wp_expr
env
e2
filter_post
e2
expr_effect
q
in
let
w2
wp_expr
env
e2
filter_post
e2
expr_effect
q
in
let
result
v_result
e1
expr_type
in
let
result
v_result
e1
expr_type
in
@@ -364,7 +370,7 @@ and wp_triple env (p, e, q) =
wp_recfun
env
_
bl
_var
t
wp_recfun
env
_
bl
_var
t
let
f
wp_triple
env
t
in
let
f
wp_triple
env
t
in
wp_binders
bl
f
wp_binders
env
bl
f
let
wp
env
e
let
wp
env
e
wp_expr
env
e
default_post
e
expr_type
e
expr_effect
wp_expr
env
e
default_post
e
expr_type
e
expr_effect
This diff is collapsed.
Loading
Save comment
