Commit aa9d181f authored by GUILLEVIC Aurore's avatar GUILLEVIC Aurore
FST 6.7 k=12 D=2 rho=1.75, Fotiadis Martindale ePrint 2018/969, for Jolijn Cottaar
parent 307e5e1e
...@@ -220,6 +220,8 @@ elif curve == KSS: ...@@ -220,6 +220,8 @@ elif curve == KSS:
elif curve == FotiadisMartindale: elif curve == FotiadisMartindale:
if code == 17: if code == 17:
from tnfs.param.testvector_other_sparseseed import test_vector_sparse_fm12_17 as test_vector from tnfs.param.testvector_other_sparseseed import test_vector_sparse_fm12_17 as test_vector
if code == 18:
from tnfs.param.testvector_other_sparseseed import test_vector_sparse_fm12_18 as test_vector
elif code == 23: elif code == 23:
from tnfs.param.testvector_other_sparseseed import test_vector_sparse_fm16_23 as test_vector from tnfs.param.testvector_other_sparseseed import test_vector_sparse_fm16_23 as test_vector
elif code == 25: elif code == 25:
...@@ -7,6 +7,22 @@ test_vector_sparse_fm12_17 = [ # family 17 in eprint 2019/555 ...@@ -7,6 +7,22 @@ test_vector_sparse_fm12_17 = [ # family 17 in eprint 2019/555
{'u':-0x43ffbfffffffe000, 'b':-2, 'pnbits':384, 'rnbits':254, 'deg_h_S':6,'cost_S':129, 'label':"-2^62-2^58+2^46+2^13 Hw2naf 4"}, {'u':-0x43ffbfffffffe000, 'b':-2, 'pnbits':384, 'rnbits':254, 'deg_h_S':6,'cost_S':129, 'label':"-2^62-2^58+2^46+2^13 Hw2naf 4"},
{'u':-0x47ffffffe0000002, 'b': 2, 'pnbits':384, 'rnbits':254, 'deg_h_S':6,'cost_S':129, 'label':"-2^62-2^59+2^29-2 Hw2naf 4"}, {'u':-0x47ffffffe0000002, 'b': 2, 'pnbits':384, 'rnbits':254, 'deg_h_S':6,'cost_S':129, 'label':"-2^62-2^59+2^29-2 Hw2naf 4"},
# FM12 curves with sparse seed u = [1] mod 2 of 32--33 bits Hw2naf 5
test_vector_sparse_fm12_18 = [
{'u': 0x87e00001, 'u_mod_6':3, 'a':-30, 'b':56, 'pnbits':433, 'rnbits':249, 'cost_S':133, 'deg_h_S':12, 'label':"2^31+2^27-2^21+1 Hw2naf 4"},
{'u':0x100024001, 'u_mod_6':5, 'a':-30, 'b':56, 'pnbits':446, 'rnbits':257, 'cost_S':134, 'deg_h_S':12, 'label':"2^32+2^17+2^14+1 Hw2naf 4, u=4295114753 for Family 8 p.27 in ePrint 2018/969, Fotiadis-Martindale"},
{'u':0x10087ffff, 'u_mod_6':1, 'a':-30, 'b':56, 'pnbits':446, 'rnbits':257, 'cost_S':134, 'deg_h_S':12, 'label':"2^32+2^23+2^19-1 Hw2naf 4"},
{'u':0x104000011, 'u_mod_6':1, 'a':-30, 'b':56, 'pnbits':446, 'rnbits':257, 'cost_S':134, 'deg_h_S':12, 'label':"2^32+2^26+2^4+1 Hw2naf 4"},
# Hamming weight 5, r of 256 bits.
{'u': 0xfffff817, 'u_mod_6':1, 'a':-30, 'b':56, 'pnbits':445, 'rnbits':256, 'cost_S':134, 'deg_h_S':12, 'label':"+2^32-2^11+2^5-2^3-1 Hw2naf 5"},
{'u': 0xc07ffeff, 'u_mod_6':3, 'a':-30, 'b':56, 'pnbits':440, 'rnbits':253, 'cost_S':134, 'deg_h_S':12, 'label':"+2^32-2^30+2^23-2^8-1 Hw2naf 5"},
{'u': 0x80060041, 'u_mod_6':1, 'a':-30, 'b':56, 'pnbits':432, 'rnbits':249, 'cost_S':133, 'deg_h_S':12, 'label':"+2^31+2^18+2^17+2^6+1 Hw2naf 5"},
{'u': 0x88400401, 'u_mod_6':1, 'a':-30, 'b':56, 'pnbits':433, 'rnbits':249, 'cost_S':133, 'deg_h_S':12, 'label':"+2^31+2^27+2^22+2^10+1 Hw2naf 5"},
test_vector_sparse_fst67_k12 = test_vector_sparse_fm12_18
test_vector_sparse_fm16_23 = [ # family 23 in eprint 2019/555 test_vector_sparse_fm16_23 = [ # family 23 in eprint 2019/555
{'u':0x1000014000000, 'a': 1, 'pnbits':767, 'rnbits':385, 'deg_h_S':16,'cost_S':196, 'deg_h_C':4,'cost_C':209, 'label':"+2^48+2^28+2^26 Hw2naf 3"}, {'u':0x1000014000000, 'a': 1, 'pnbits':767, 'rnbits':385, 'deg_h_S':16,'cost_S':196, 'deg_h_C':4,'cost_C':209, 'label':"+2^48+2^28+2^26 Hw2naf 3"},
{'u':-0xfffffffd7ff8, 'a': 1, 'pnbits':766, 'rnbits':384, 'deg_h_S':16,'cost_S':196, 'deg_h_C':4,'cost_C':209, 'label':"-2^48+2^17+2^15+2^3 Hw2naf 4"}, {'u':-0xfffffffd7ff8, 'a': 1, 'pnbits':766, 'rnbits':384, 'deg_h_S':16,'cost_S':196, 'deg_h_C':4,'cost_C':209, 'label':"-2^48+2^17+2^15+2^3 Hw2naf 4"},
