Commit 7bb5e46c authored by Thierry Martinez's avatar Thierry Martinez
Update for new clangml
parent ec170644
Pipeline #94975 failed
......@@ -18,7 +18,9 @@ let declare_tmp qual_type =
let tmp = fresh_var_name () in
let decl_tmp = Clang.Ast.node ~qual_type (Clang.Ast.Decl [
Clang.Ast.node ~qual_type (Clang.Ast.Var (Clang.Ast.var tmp qual_type))]) in
let tmp_var = Clang.Ast.node ~qual_type (Clang.Ast.DeclRef (Clang.Ast.identifier_name tmp)) in
let tmp_var =
tmp_var, decl_tmp
let assign_to_tmp ?qual_type expr =
......@@ -29,7 +31,7 @@ let assign_to_tmp ?qual_type expr =
let tmp_var, decl_tmp = declare_tmp qual_type in
let assign_tmp = Clang.Ast.node ~qual_type (Clang.Ast.Expr (
bin_op qual_type tmp_var Assign expr)) in
tmp_var, [decl_tmp; assign_tmp]
type transform_env = {
statement_root : bool;
......@@ -87,17 +89,20 @@ let close_node ((stmt, _stmts) as node) =
let rec name_anonymous_fields (decl : Clang.Ast.decl list) =
match decl with
| { desc = RecordDecl ({ keyword; name = ""; _ } as record_decl); _} as record ::
as record ::
({ desc = Field { name; qual_type = { desc =
Elaborated ({ keyword = keyword';
named_type = { desc = Record { name = IdentifierName ""; _ }; _ } as named_type; _ } as elaborated); _}
as qual_type; bitwidth; init }; _} as field)
:: tail when keyword = keyword' ->
{ record with
desc = Clang.Ast.RecordDecl { record_decl with name = "anon" }} ::
{ field with desc = Field { name; bitwidth; init;
qual_type = { qual_type with desc = Elaborated { elaborated with
named_type = { named_type with desc = Record (Clang.Ast.identifier_name "anon") }}}}} ::
name_anonymous_fields tail
| hd :: tl -> hd :: name_anonymous_fields tl
......@@ -217,7 +222,8 @@ let transform = object (self)
self#visit_expr { env with in_condition = true } cond in
let cond, delayed_stmts = make_condition delayed_stmts cond in
let tmp_var, stmts = assign_to_tmp ~qual_type:int cond in
[close_stmt (Free_monoid.plus delayed_stmts (Free_monoid.of_list stmts))
[{ stmt with desc = Return (Some tmp_var) }]]
| { desc = Expr ({ desc = Call _; _ } as expr); _}
when (Clang.Type.of_node expr).desc <> BuiltinType Void ->
......@@ -315,7 +321,8 @@ let transform = object (self)
qual_type = { desc = Pointer { desc = BuiltinType Void; _ }; _};
operand = { desc = IntegerLiteral (Int 0); _ }} ->
expr, monoid#zero
| Cast { operand; _ } -> self#visit_expr env { expr with desc = operand.desc }
(* liftConditionals *)
| ConditionalOperator { cond; then_branch; else_branch } ->
let then_branch =
......@@ -327,7 +334,8 @@ let transform = object (self)
let else_branch =
self#visit_expr { env with assign_rhs = true } else_branch in
let qual_type = Clang.Type.of_node expr in
make_conditional_operator qual_type monoid#zero cond then_branch else_branch
else_branch
| _ ->
let expr, delayed_stmts =
super#visit_expr { env with statement_root = false; assign_rhs = false }
......@@ -56,6 +56,8 @@
Clang__.Clang__bindings.clang_ext_stringkind [@opaque] [@@rewrite] [@@remove]
type clang_ext_overloadedoperatorkind =
Clang__.Clang__bindings.clang_ext_overloadedoperatorkind [@opaque] [@@rewrite] [@@remove]
type clang_ext_exceptionspecificationtype =
Clang__.Clang__bindings.clang_ext_exceptionspecificationtype [@opaque] [@@rewrite] [@@remove]
module%import Clang__types = struct
type language = language [@opaque] [@@rewrite] [@@remove]
