Commit 498ebadf authored by AUTERNAUD Alex's avatar AUTERNAUD Alex
path update
parent abcbfcce
......@@ -68,33 +68,40 @@ class PathPlanner():
x, y = self.ssn.x_coordinates, self.ssn.y_coordinates
dx = 1/self.state_config.global_map_scale
target_dist = np.linalg.norm(np.array(pos[:2]) - np.array(self.target[:2]))
xl, yl, vxl, vyl, dl = utils.optimal_path_2d(
ret = utils.optimal_path_2d(
self.distance, pos[:2],
dx=self.max_d,
dx=dx,
coords=(x, y),
max_distance=self.max_d,
goal=np.array(self.target[:2]))
# max_distance=self.max_d_orientation)
goal=np.array(self.target[:2]),
max_d_orientation=self.max_d_orientation)
if ret:
xl, yl, vxl, vyl, dl = ret
else :
return []
if len(xl) == 0 or len(yl) == 0 or len(vxl) == 0 or len(vyl) == 0:
return []
self.waypoints_path[0, :] = [pos[0], pos[1]]
for i, (x, y) in enumerate(zip(xl, yl)):
self.waypoints_path[i+1, :] = [x, y]
self.waypoints_path[i+2, :] = [self.target[0], self.target[1]]
d_angle = utils.constraint_angle(np.arctan2(yl[0] - pos[1], xl[0] - pos[0]) - pos[2])
if target_dist < self.max_d_orientation: # if within range, set waypoint = target
wpt_pos = [self.target[0], self.target[1], self.target[2]]
elif target_dist < self.max_d:
self.target[1],
np.arctan2(yl[0] - pos[1], xl[0] - pos[0])]
elif np.abs(d_angle) > self.max_target_angle:
wpt_pos = [pos[0], pos[1], np.arctan2(yl[0] - pos[1], xl[0] - pos[0])]
else: # else, point on shortest path with orientation towards target
wpt_pos = [xl[0], yl[0], np.arctan2(yl[0] - pos[1], xl[0] - pos[0])]
waypoint_index = min(int(self.max_d / dx), len(dl)-1) # get the index of the next waypoint at max_d with dx step
if target_dist < self.max_d_orientation: # if we are near the target, we only turn on ourself
wpt_pos = [pos[0], pos[1], self.target[2]]
else :
angle=np.abs(utils.constraint_angle(np.arctan2(yl[waypoint_index] - pos[1], xl[waypoint_index] - pos[0]) - pos[2]))
# if the angle to the next point is too big, also first turn on ourself to its direction
if angle > self.max_target_angle:
wpt_pos = [pos[0], pos[1], np.arctan2(yl[waypoint_index] - pos[1], xl[waypoint_index] - pos[0])]
else :
if target_dist < self.max_d: # we are near the target
self.target[1],
np.arctan2(yl[-1] - pos[1], xl[-1] - pos[0])]
else: # nominal case else, point on shortest path with orientation towards target
wpt_pos = [xl[waypoint_index], yl[waypoint_index], np.arctan2(yl[waypoint_index] - pos[1], xl[waypoint_index] - pos[0])]
return wpt_pos
def run(self,
