Commit f0effd27 authored by Mathieu Faverge's avatar Mathieu Faverge
Test
parent b7c8cada
Pipeline #277801 failed
...@@ -26,13 +26,13 @@ ...@@ -26,13 +26,13 @@
<file>interface/img/logo1225.png</file> <file>interface/img/logo1225.png</file>
</qresource> </qresource>
<qresource prefix="window" > <qresource prefix="window" >
<file>interface/settings.ui</file> <file>settings.ui</file>
<file>interface/help_window.ui</file> <file>help_window.ui</file>
<file>interface/info_window.ui</file> <file>info_window.ui</file>
<file>interface/main_window.ui</file> <file>main_window.ui</file>
<file>interface/option_export_window.ui</file> <file>option_export_window.ui</file>
<file>interface/list_of_counter_to_export.ui</file> <file>list_of_counter_to_export.ui</file>
<file>interface/node_select.ui</file> <file>node_select.ui</file>
<file>interface/statistics.ui</file> <file>statistics.ui</file>
</RCC> </RCC>
