GitLab
Explore
Primary navigation
Search or go to…
vite
Manage
Plan
Issue boards
Code
Merge requests
Repository graph
Compare revisions
Build
Pipeline schedules
Artifacts
Deploy
Package registry
Container registry
Operate
Terraform modules
Monitor
Service Desk
Analyze
Contributor analytics
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
solverstack
vite
e686453b
e686453b
7 years ago
Mathieu Faverge
Downloads
Patches
First patch to fix issue with colors out of the range [0.,1.]
a482a34e
1 merge request
!2
3
3 changed files
src/common/Tools.cpp
+60
-61
60 additions, 61 deletions
src/trace/values/Color.cpp
+36
-8
36 additions, 8 deletions
src/trace/values/Color.hpp
+2
2 additions, 0 deletions
98 additions
69 deletions
60
61
e686453b
** This file is part of the ViTE project.
** This software is governed by the CeCILL-A license under French law
** and abiding by the rules of distribution of free software. You can
** use, modify and/or redistribute the software under the terms of the
** CeCILL-A license as circulated by CEA, CNRS and INRIA at the following
** URL: "http://www.cecill.info".
** As a counterpart to the access to the source code and rights to copy,
** modify and redistribute granted by the license, users are provided
** only with a limited warranty and the software's author, the holder of
** the economic rights, and the successive licensors have only limited
** liability.
** liability.
** In this respect, the user's attention is drawn to the risks associated
** with loading, using, modifying and/or developing or reproducing the
** software by the user in light of its specific status of free software,
** that may mean that it is complicated to manipulate, and that also
** therefore means that it is reserved for developers and experienced
** professionals having in-depth computer knowledge. Users are therefore
** encouraged to load and test the software's suitability as regards
** their requirements in conditions enabling the security of their
** systems and/or data to be ensured and, more generally, to use and
** operate it in the same conditions as regards security.
** The fact that you are presently reading this means that you have had
** knowledge of the CeCILL-A license and that you accept its terms.
** ViTE developers are (for version 0.* to 1.0):
** - COULOMB Kevin
** - COULOMB Kevin
** - FAVERGE Mathieu
** - JAZEIX Johnny
** - JAZEIX Johnny
** - LAGRASSE Olivier
** - MARCOUEILLE Jule
** - NOISETTE Pascal
** - REDONDY Arthur
** - REDONDY Arthur
** - VUCHENER Clément
#include
<cstdio>
#include
<cstdio>
#include
<iostream>
#include
<iostream>
@@ -66,27 +66,27 @@ bool convert_to_double(const std::string &arg, double *val) {
else
// We change the locale to test
else
bool
is_english_system_needed
false
// We have dot as separator of decimal and integer.
bool
false
if
arg
find
string
npos
if
arg
find
string
npos
true
true
// We had dots initially, we need to have the english system
if
if
if
setlocale
LC_NUMERIC
"C"
NULL
if
setlocale
LC_NUMERIC
"C"
NULL
setlocale
LC_NUMERIC
"en_GB.UTF-8"
NULL
setlocale
LC_NUMERIC
"en_GB.UTF-8"
NULL
vite_warning
"The locale en_GB.UTF-8 is unavailable so the decimal pointed will not be printed"
vite_warning
else
// It is comma separated
else
if
setlocale
LC_NUMERIC
"fr_FR.UTF-8"
NULL
if
setlocale
LC_NUMERIC
"fr_FR.UTF-8"
NULL
setlocale
LC_NUMERIC
"French"
NULL
setlocale
LC_NUMERIC
"French"
NULL
vite_warning
"The locale fr_FR.UTF-8 is unavailable so the decimal with comma will not be printed"
vite_warning
// Reads the value in the new locale
sscanf
arg
c_str
"%lf%n"
val
nb_read
sscanf
arg
c_str
"%lf%n"
val
nb_read
return
nb_read
arg
size
return
nb_read
arg
size
@@ -99,17 +99,16 @@ double clockGet (void)
// TODO
// TODO
return
0.
return
0.
#elif (defined X_ARCHalpha_compaq_osf1) || (defined X_ARCHi686_mac)
struct
rusage
struct
rusage
getrusage
RUSAGE_SELF
getrusage
RUSAGE_SELF
return
double
ru_utime
tv_sec
double
ru_stime
tv_sec
return
double
ru_utime
tv_sec
double
ru_stime
tv_sec
double
ru_utime
tv_usec
double
ru_stime
tv_usec
double
ru_utime
tv_usec
double
ru_stime
tv_usec
1.0e-6L
1.0e-6L
#elif defined _POSIX_TIMERS && defined CLOCK_REALTIME
struct
timespec
tp
struct
timespec
tp
clock_gettime
CLOCK_REALTIME
tp
/* Elapsed time */
clock_gettime
CLOCK_REALTIME
tp
/* Elapsed time */
return
double
tp
tv_sec
double
tp
tv_nsec
double
1.0e-9L
return
double
tp
tv_sec
double
tp
tv_nsec
double
1.0e-9L
#endif
#endif
This diff is collapsed.
36
8
e686453b
@@ -42,6 +42,7 @@
@@ -42,6 +42,7 @@
#include
<string>
#include
<string>
#include
<iostream>
#include
<sstream>
#include
<sstream>
#include
<iomanip>
// For std::setprecision
#include
<iomanip>
#include
<cstdlib>
#include
<cstdlib>
@@ -53,14 +54,35 @@
@@ -53,14 +54,35 @@
using
namespace
std
using
namespace
std
Color
Color
_r
rand
256
256
double
_g
rand
256
256
Color
check_value
double
v
const
string
spectrum
_b
rand
256
256
if
v
0.
cerr
"Invalid value for "
spectrum
" color "
v
" (must be between 0. and 1.)"
endl
v
0.
/* Extra Test for StarPU bug in state color values */
if
v
1.
v
v
255.
if
v
1.
cerr
spectrum
" color "
v
endl
v
1.
return
v
Color
Color
_r
rand
256
255
_g
rand
256
255
_b
rand
256
255
_is_correct
true
_is_correct
true
Color
Color
double
r
double
g
double
b
_r
r
_g
g
_b
b
Color
Color
double
r
double
g
double
b
_r
Color
check_value
r
"red"
_g
Color
check_value
g
"green"
_b
Color
check_value
b
"blue"
_is_correct
true
_is_correct
true
@@ -72,7 +94,9 @@ Color::Color(const Color *c) : Value(*c), _r(c->_r), _g(c->_g), _b(c->_b) {
_is_correct
c
_is_correct
_is_correct
c
_is_correct
Color
Color
const
std
string
in
Color
Color
const
std
string
in
double
r
g
b
string
separated_color
3
string
separated_color
3
string
temp
in
string
temp
in
@@ -82,9 +106,13 @@ Color::Color(const std::string &in) {
temp
temp
substr
position_of_space
temp
temp
substr
position_of_space
_is_correct
convert_to_double
separated_color
_r
_is_correct
convert_to_double
separated_color
r
convert_to_double
separated_color
_g
convert_to_double
separated_color
g
convert_to_double
separated_color
2
_b
convert_to_double
separated_color
2
b
_r
Color
check_value
r
"red"
_g
Color
check_value
g
"green"
_b
Color
check_value
b
"blue"
std
string
Color
to_string
const
std
string
Color
to_string
const
2
e686453b
@@ -63,6 +63,8 @@ private :
/*! blue value */
/*! blue value */
double
_b
double
_b
static
double
check_value
double
const
std
string
public:
public:
* \brief Constructor
Loading
Save comment
