GitLab
Explore
Primary navigation
Search or go to…
vite
Manage
Plan
Issue boards
Code
Merge requests
Repository graph
Compare revisions
Build
Pipeline schedules
Artifacts
Deploy
Package registry
Container registry
Operate
Terraform modules
Monitor
Service Desk
Analyze
Contributor analytics
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
solverstack
vite
e0a0610a
e0a0610a
11 years ago
Thibault Soucarre
Downloads
Patches
avoid paintGL to be executed before rendering the trace
079ed283
2
2 changed files
src/render/Render_alternate.cpp
+16
-17
16 additions, 17 deletions
src/render/vbo.cpp
+0
-3
0 additions, 3 deletions
src/render/vbo.cpp
16 additions
20 deletions
16
17
e0a0610a
@@ -44,7 +44,6 @@
@@ -44,7 +44,6 @@
*\file Render_alternate.cpp
#include
"common/common.hpp"
#include
"common/common.hpp"
#include
"common/Info.hpp"
#include
"common/Info.hpp"
#include
"common/Message.hpp"
#include
@@ -172,7 +171,11 @@ void Render_alternate::resizeGL(int width, int height) {
void
Render_alternate
paintGL
void
Render_alternate
paintGL
/*Do not call paintGL before rendering the trace*/
if
DRAWING_STATE_WAITING
_state
return
//glClearColor(0.0, 1.0, 0.0, 1.0);
resizeGL
Render_alternate
QGLWidget
width
Render_alternate
QGLWidget
height
resizeGL
Render_alternate
QGLWidget
width
Render_alternate
QGLWidget
height
@@ -193,9 +196,6 @@ void Render_alternate::paintGL(){
glDrawArrays
GL_QUADS
glDrawArrays
GL_QUADS
glDrawArrays
GL_LINES
8
_ruler
getNbVertex
glDrawArrays
GL_LINES
8
_ruler
getNbVertex
_ruler
unlock
_ruler
unlock
/* drawing containers*/
_containers
lock
_containers
lock
//_modelview = glm::translate(_modelview, glm::vec3(0.0f, _ruler_y + _ruler_height -_y_state_translate, _z_container));
@@ -245,6 +245,7 @@ void Render_alternate::paintGL(){
//restore matrix
//restore matrix
_modelview
tmp
_modelview
tmp
/*draw selection if necessary*/
if
_mouse_pressed
Info
Render
_key_ctrl
false
_mouse_pressed_inside_container
if
_mouse_pressed
Info
Render
_key_ctrl
false
Element_pos
x0
x1
y0
y1
Element_pos
x0
x1
y0
y1
@@ -268,7 +269,7 @@ void Render_alternate::paintGL(){
glDisableVertexAttribArray
_modelview
tmp
_modelview
tmp
// _containers.display(_modelview);
//rendu
//rendu
@@ -314,16 +315,16 @@ void Render_alternate::paintGL(){
if
it
it_end
render_to_screen_y
trace_to_render_y
_texts
i
y
render_to_screen_y
trace_to_render_y
it
second
height
if
it
it_end
render_to_screen_y
trace_to_render_y
_texts
i
y
render_to_screen_y
trace_to_render_y
it
second
height
const
QString
text_elided
metric
elidedText
_texts
i
value
c_str
Qt
ElideRight
_x_scale_container_state
Info
Screen
width
Info
Trace
depth
1.
const
QString
text_elided
metric
elidedText
_texts
i
value
c_str
Qt
ElideRight
Info
Screen
width
Info
Trace
depth
1.
renderText
render_to_screen_x
_texts
i
x
0.20
renderText
render_to_screen_x
_texts
i
x
0.20
render_to_screen_y
trace_to_render_y
_texts
i
y
0.5
render_to_screen_y
trace_to_render_y
_texts
i
y
0.5
text_elided
text_elided
arial_font
arial_font
//push only displayed values in the map
previous_by_column
_texts
i
x
_texts
i
y
previous_by_column
_texts
i
x
_texts
i
y
//displayed++;
//displayed++;
//else{skipped++;}
//else{skipped++;}
/* Draw ruler text */
std
ostringstream
buf_txt
std
ostringstream
buf_txt
Element_pos
graduation_diff
Element_pos
graduation_diff
Element_pos
coeff_prefix
Element_pos
coeff_prefix
@@ -371,9 +372,7 @@ void Render_alternate::paintGL(){
buf_txt
str
c_str
buf_txt
str
c_str
arial_font
arial_font
// Render_alternate::QGLWidget::setFocus(Qt::ActiveWindowFocusReason);/* give the focus to the render area for mouse and keyboard events */
@@ -754,14 +753,14 @@ GLuint Render_alternate::draw_wait() {
void
Render_alternate
call_ruler
void
Render_alternate
call_ruler
_ruler
setNbVertex
_ruler
setNbVertex
Element_pos
graduation_diff
Element_pos
graduation_diff
Element_pos
coeff_prefix
Element_pos coeff_prefix;
const
Element_pos
offset_x
_default_entity_x_translate
const
Element_pos
offset_x
const
Element_pos
offset_y
_ruler_y
_ruler_height
3.5
const
Element_pos
offset_y
_ruler_y
_ruler_height
3.5
update_visible_interval_value
graduation_diff
Ruler
get_graduation_diff
Info
Render
_x_min_visible
Info
Render
_x_max_visible
graduation_diff
Ruler
get_graduation_diff
Info
Render
_x_min_visible
Info
Render
_x_max_visible
coeff_prefix
Ruler
get_coeff_for_common_prefix
Info
Render
_x_min_visible
Info
Render
_x_max_visible
coeff_prefix = Ruler::get_coeff_for_common_prefix(Info::Render::_x_min_visible, Info::Render::_x_max_visible);
//draw quads
//draw quads
set_color
0.0
0.0
1.0
set_color
0.0
0.0
1.0
_ruler
add
trace_to_render_x
Info
Render
_x_min_visible
_r
_g
_b
_ruler
add
trace_to_render_x
Info
Render
_x_min_visible
_r
_g
_b
@@ -788,7 +787,7 @@ void Render_alternate::call_ruler(){
trace_to_render_x
i
offset_x
4
offset_y
_z_ruler
trace_to_render_x
i
offset_x
4
offset_y
_z_ruler
return
return
@@ -1035,7 +1034,7 @@ void Render_alternate::start_ruler(){
void
Render_alternate
end_ruler
void
Render_alternate
end_ruler
_draw_ruler
false
_draw_ruler
false
std
cout
"end_ruler"
std
endl
std::cout << "end_ruler" << std::endl;
void
Render_alternate
end_draw
void
Render_alternate
end_draw
This diff is collapsed.
src/render/vbo.cpp
e0a0610a
@@ -158,10 +158,7 @@ int Vbo::get_remaining_size() const{
void
Vbo
config
void
Vbo
config
std
cout
"Configuration du vbo, "
_nbVertex
" vertices"
std
endl
int
vertex_size
_vertex
size
sizeof
Element_pos
int
vertex_size
_vertex
size
sizeof
Element_pos
std
cout
_vertex
size
std
endl
std
cout
_colors
size
std
endl
int
colors_size
_colors
size
sizeof
Element_col
int
colors_size
_colors
size
sizeof
Element_col
Element_pos
vertex
_vertex
Element_pos
vertex
_vertex
Element_col
colors
_colors
Element_col
colors
_colors
Loading
Save comment
