Commit 91e7b832 authored by Mathieu Faverge's avatar Mathieu Faverge
Rearrange setting UI
parent 7ef73f3d
...@@ -9,10 +9,16 @@ ...@@ -9,10 +9,16 @@
<rect> <rect>
<x>0</x> <x>0</x>
<y>0</y> <y>0</y>
<width>457</width> <width>467</width>
<height>414</height> <height>665</height>
</rect> </rect>
</property> </property>
<property name="sizePolicy">
<sizepolicy hsizetype="Preferred" vsizetype="Expanding">
<horstretch>0</horstretch>
<verstretch>0</verstretch>
</sizepolicy>
</property>
<property name="windowTitle"> <property name="windowTitle">
<string>Preferences</string> <string>Preferences</string>
...@@ -20,383 +26,293 @@ ...@@ -20,383 +26,293 @@
<iconset resource="vite.qrc"> <iconset resource="vite.qrc">
<normaloff>:/icon/icon/vite.png</normaloff>:/icon/icon/vite.png</iconset> <normaloff>:/icon/icon/vite.png</normaloff>:/icon/icon/vite.png</iconset>
<widget class="QTabWidget" name="tabWidget"> <layout class="QVBoxLayout" name="verticalLayout_9">
<property name="geometry"> <item>
<rect> <widget class="QTabWidget" name="tabWidget">
<x>9</x> <property name="sizePolicy">
<y>9</y> <sizepolicy hsizetype="Preferred" vsizetype="Preferred">
<width>431</width> <horstretch>0</horstretch>
<height>351</height> <verstretch>100</verstretch>
</rect> </sizepolicy>
<property name="currentIndex"> <property name="currentIndex">
<number>0</number> <number>5</number>
<widget class="QWidget" name="tab_2"> <widget class="QWidget" name="tab_2">
<attribute name="title"> <attribute name="title">
<string>General</string> <string>General</string>
</attribute> </attribute>
<layout class="QVBoxLayout" name="verticalLayout_6"> <layout class="QVBoxLayout" name="verticalLayout_6">
<item>
<widget class="QGroupBox" name="groupBox_2">
<property name="title">
<string>Geometry</string>
</property>
</widget>
</item>
<item>
<widget class="QGroupBox" name="groupBox">
<string>Filters</string>
</property>
<layout class="QVBoxLayout" name="verticalLayout_7">
<item>
<widget class="QCheckBox" name="use_palette_cb">
<property name="text">
<string>Use palettes</string>
</property>
</widget>
</item>
<item>
<widget class="QCheckBox" name="checkBox_2">
<string>No links</string>
</property>
</widget>
</item>
<item>
<widget class="QCheckBox" name="checkBox_3">
<string>No events</string>
</property>
</widget>
</item>
</layout>
</widget>
</item>
</layout>
</widget>
<widget class="QWidget" name="tab_3">
<string>States</string>
</attribute>
<layout class="QVBoxLayout" name="verticalLayout_8">
<item>
<layout class="QHBoxLayout" name="horizontalLayout_7">
<item>
<widget class="QComboBox" name="palette_list"/>
</item>
<item>
<spacer name="horizontalSpacer_3">
<property name="orientation">
<enum>Qt::Horizontal</enum>
</property>
<property name="sizeHint" stdset="0">
<size>
<width>40</width>
<height>20</height>
</size>
</property>
</spacer>
</item>
<item>
<widget class="QPushButton" name="add_palette_btn">
<string>Add</string>
</property>
</widget>
</item>
<item> <item>
<widget class="QPushButton" name="copy_palette_btn"> <widget class="QGroupBox" name="groupBox">
<property name="text"> <property name="sizePolicy">
<string>Copy</string> <sizepolicy hsizetype="Preferred" vsizetype="Fixed">
</sizepolicy>
</widget> <property name="layoutDirection">
</item> <enum>Qt::LeftToRight</enum>
<item>
<widget class="QPushButton" name="rm_palette_btn">
<string>Remove</string>
</widget> <property name="title">
</item> <string>Filters</string>
</layout>
</item>
<item>
<widget class="QTableWidget" name="states_table">
<column>
<string>State name</string>
</property>
</column>
<column>
<string>Color</string>
</property>
</column>
<column>
<string>Visible</string>
</property>
</column>
</widget>
</item>
<item>
<layout class="QHBoxLayout" name="horizontalLayout_16">
<item>
<widget class="QLabel" name="label_9">
<string>State:</string>
<property name="sizeConstraint">
<enum>QLayout::SetDefaultConstraint</enum>
</property>
<property name="topMargin">
<number>9</number>
</property>
<item>
</property>
</widget>
</item>
<item>
</property>
</widget>
</item>
<item>
</property>
</widget>
</item>
</layout>
</widget> </widget>
</item> </item>
<item> <item>
<spacer name="horizontalSpacer_4"> <spacer name="verticalSpacer_8">
<property name="orientation"> <property name="orientation">
<enum>Qt::Horizontal</enum> <enum>Qt::Vertical</enum>
<property name="sizeHint" stdset="0"> <property name="sizeHint" stdset="0">
<size> <size>
<width>40</width> <width>20</width>
<height>20</height> <height>40</height>
</size> </size>
</spacer> </spacer>
</item> </item>
</layout>
</widget>
</attribute>
<item> <item>
<widget class="QPushButton" name="reload_states_btn"> <layout class="QHBoxLayout" name="horizontalLayout_7">
<property name="toolTip"> <item>
<string>Reload all the states types from the displayed trace</string> <widget class="QComboBox" name="palette_list"/>
</property> </item>
<property name="text"> <item>
<string>Reload All</string> <spacer name="horizontalSpacer_3">
</property> <property name="orientation">
</widget> <enum>Qt::Horizontal</enum>
</property>
<size>
<width>40</width>
<height>20</height>
</size>
</property>
</spacer>
</item>
<item>
</property>
</widget>
</item>
<item>
</property>
</widget>
</item>
<item>
</property>
</widget>
</item>
</layout>
</item> </item>
<item> <item>
<widget class="QPushButton" name="add_state_btn"> <widget class="QTableWidget" name="states_table">
<string>Add</string> <sizepolicy hsizetype="Expanding" vsizetype="Expanding">
<horstretch>100</horstretch>
</sizepolicy>
<column>
</property>
</column>
<column>
</property>
</column>
<column>
</property>
</column>
</widget> </widget>
</item> </item>
<item> <item>
<widget class="QPushButton" name="rm_state_btn"> <layout class="QHBoxLayout" name="horizontalLayout_16">
<string>Remove</string> <widget class="QLabel" name="label_9">
</property> <property name="text">
</widget> <string>State:</string>
</property>
</widget>
</item>
<item>
</property>
<size>
<width>40</width>
<height>20</height>
</size>
</property>
</spacer>
</item>
<item>
</property>
</property>
</widget>
</item>
<item>
</property>
</widget>
</item>
<item>
</property>
</widget>
</item>
</layout>
</item> </item>
</layout> </layout>
</item> </widget>
</layout> <widget class="QWidget" name="tab_4">
</widget> <attribute name="title">
<widget class="QWidget" name="tab_4"> <string>Event Types</string>
<attribute name="title"> </attribute>
<string>Event Types</string> <layout class="QVBoxLayout" name="verticalLayout_4">
</attribute>
<widget class="QWidget" name="layoutWidget">
<rect>
<x>10</x>
<y>10</y>
<width>411</width>
<height>29</height>
</rect>
</property>
<layout class="QHBoxLayout" name="horizontalLayout_14">
<item>
<widget class="QComboBox" name="event_types_palette_list"/>
</item>
<item>
<spacer name="horizontalSpacer_5">
</property>
<size>
<width>40</width>
<height>20</height>
</size>
</property>
</spacer>
</item>
<item>
<widget class="QPushButton" name="reload_event_types_palette_btn">
<string>Reload</string>
</property>
</widget>
</item>
<item>
<widget class="QPushButton" name="copy_event_types_palette_btn">
</property>
</widget>
</item>
<item>
<widget class="QPushButton" name="rm_event_types_palette_btn">
</property>
</widget>
</item>
</layout>
</widget>
<widget class="QWidget" name="layoutWidget_1">
<rect>
<x>10</x>
<y>43</y>
<width>411</width>
<height>271</height>
</rect>
</property>
<layout class="QHBoxLayout" name="horizontalLayout_10">
<item>
<widget class="QTableWidget" name="event_types_table">
<column>
<string>Event Type</string>
</property>
</column>
<column>
</property>
</column>
<column>
</property>
</column>
</widget>
</item>
</layout>
</widget>
</widget>
<widget class="QWidget" name="tab_5">
<string>Link Types</string>
</attribute>
<widget class="QWidget" name="layoutWidget_2">
<rect>
<x>10</x>
<y>10</y>
<width>411</width>
<height>29</height>
</rect>
</property>
<layout class="QHBoxLayout" name="horizontalLayout_12">
<item>
<widget class="QComboBox" name="link_types_palette_list"/>
</item>
<item>
<spacer name="horizontalSpacer_6">
</property>
<size>
<width>40</width>
<height>20</height>
</size>
</property>
</spacer>
</item>
<item>
<widget class="QPushButton" name="reload_link_types_palette_btn">
<sizepolicy hsizetype="Fixed" vsizetype="Fixed">
</sizepolicy>
</property>
</property>
</widget>
</item>
<item>
<widget class="QPushButton" name="copy_link_types_palette_btn">
</property>
</widget>
</item>
<item>
<widget class="QPushButton" name="rm_link_types_palette_btn">
</property>
</widget>
</item>
</layout>
</widget>
<widget class="QWidget" name="layoutWidget_3">
<rect>
<x>10</x>
<y>40</y>
<width>411</width>
</rect>
</property>
<layout class="QHBoxLayout" name="horizontalLayout_15">
<item>
<widget class="QTableWidget" name="link_types_table">
</sizepolicy>
</property>
<property name="cornerButtonEnabled">
<bool>true</bool>
</property>
<column>
<string>Link Type</string>
</property>
</column>
<column>
</property>
</column>
<column>
</property>
</column>
</widget>
</item>
</layout>
</widget>
</widget>
<widget class="QWidget" name="tab">
<string>Plugin</string>
</attribute>
<layout class="QHBoxLayout" name="horizontalLayout_8">
<item>
<widget class="QLabel" name="label_8">
<string>Directory list:</string>
</property>
</widget>
</item>
<item>
<layout class="QVBoxLayout" name="verticalLayout_5">
<item> <item>
<widget class="QListWidget" name="dir_list"/> <layout class="QHBoxLayout" name="horizontalLayout_14">
<item>
</item>
<item>
</property>
<size>
<width>40</width>
<height>20</height>
</size>
</property>
</spacer>
</item>
<item>
</property>
</widget>
</item>
<item>
</property>
</widget>
</item>
<item>
</property>
</widget>
</item>
</layout>
</item> </item>
<item> <item>
<layout class="QHBoxLayout" name="horizontalLayout_9"> <layout class="QHBoxLayout" name="horizontalLayout_10">
<item> <item>
<spacer name="horizontalSpacer"> <widget class="QTableWidget" name="event_types_table">
</sizepolicy>
</property>
<column>
</property>
</column>
<column>
</property>
</column>
<column>
</property>
</column>
</widget>
</item>
</layout>
</item>
</layout>
</widget>
</attribute>
<layout class="QVBoxLayout" name="verticalLayout_10">
<item>
<item>
</item>
<item>
<enum>Qt::Horizontal</enum> <enum>Qt::Horizontal</enum>
...@@ -409,111 +325,239 @@ ...@@ -409,111 +325,239 @@
</spacer> </spacer>
</item> </item>
<item> <item>
<widget class="QPushButton" name="rm_dir_btn"> <widget class="QPushButton" name="reload_link_types_palette_btn">
</sizepolicy>
</property>
</property>
</widget>
</item>
<item>
<property name="text"> <property name="text">
<string>-</string> <string>Copy</string>
</widget> </widget>
</item> </item>
<item> <item>
<widget class="QPushButton" name="add_dir_btn"> <widget class="QPushButton" name="rm_link_types_palette_btn">
<string>+</string> <string>Remove</string>
</widget> </widget>
</item> </item>
</layout> </layout>
</item> </item>
<item>
<item>
</sizepolicy>
</property>
<bool>true</bool>
</property>
<column>
</property>
</column>
<column>
</property>
</column>
<column>
</property>
</column>
</widget>
</item>
</layout>
</item>
</layout> </layout>
</item> </widget>
</layout> <widget class="QWidget" name="tab">
<widget class="QWidget" name="map_tab"> <string>Plugin</string>
<string>Minimap</string> <layout class="QHBoxLayout" name="horizontalLayout_8">
</attribute>
<layout class="QHBoxLayout" name="horizontalLayout_13">
<item>
<layout class="QVBoxLayout" name="verticalLayout_3">
<item> <item>
<widget class="QCheckBox" name="minimap_hide_cb"> <widget class="QLabel" name="label_8">
<string>hidden on start</string> <string>Directory list:</string>
</widget> </widget>
</item> </item>
<item> <item>
<layout class="QHBoxLayout" name="horizontalLayout_6"> <layout class="QVBoxLayout" name="verticalLayout_5">
<item> <item>
<layout class="QVBoxLayout" name="verticalLayout"> <widget class="QListWidget" name="dir_list"/>
</item>
<item>
<item> <item>
<spacer name="verticalSpacer_4"> <spacer name="horizontalSpacer">
<enum>Qt::Vertical</enum> <enum>Qt::Horizontal</enum>
</property>
<property name="sizeType">
<enum>QSizePolicy::MinimumExpanding</enum>
<size> <size>
<width>20</width> <width>40</width>
<height>20</height> <height>20</height>
</size> </size>
</spacer> </spacer>
</item> </item>
<item> <item>
<widget class="QLabel" name="label_3"> <widget class="QPushButton" name="rm_dir_btn">
<string>Position</string> <string>-</string>
</widget> </widget>
</item> </item>
<item> <item>
<layout class="QHBoxLayout" name="horizontalLayout"> <widget class="QPushButton" name="add_dir_btn">
<string>+</string>
</property>
</widget>
</item>
</layout>
</item>
</layout>
</item>
</layout>
</widget>
</attribute>
<layout class="QVBoxLayout" name="verticalLayout_11">
<item>
<item>
</property>
</widget>
</item>
<item>
<item>
<item> <item>
<widget class="QLabel" name="label"> <widget class="QLabel" name="label_3">
<string>x</string> <string>Position</string>
</widget> </widget>
</item> </item>
<item> <item>
<widget class="QSpinBox" name="minimap_x_sb"> <layout class="QHBoxLayout" name="horizontalLayout">
<property name="maximum"> <item>
<number>1000</number> <widget class="QLabel" name="label">
</widget> <string>x</string>
</property>
</widget>
</item>
<item>
</property>
</widget>
</item>
</layout>
</item>
<item>
<layout class="QHBoxLayout" name="horizontalLayout_2">
<item>
<widget class="QLabel" name="label_2">
<string>y</string>
</property>
</widget>
</item>
<item>
<widget class="QSpinBox" name="minimap_y_sb">
</property>
</widget>
</item>
</layout>
</item> </item>
</layout> </layout>
</item> </item>
<item> <item>
<layout class="QHBoxLayout" name="horizontalLayout_2"> <layout class="QVBoxLayout" name="verticalLayout_2">
<item> <item>
<widget class="QLabel" name="label_2"> <widget class="QLabel" name="label_4">
<string>y</string> <string>Dimension</string>
</widget> </widget>
</item> </item>
<item> <item>
<widget class="QSpinBox" name="minimap_y_sb"> <layout class="QHBoxLayout" name="horizontalLayout_3">
<number>1000</number> <widget class="QLabel" name="label_5">
</widget> <string>width</string>
</property>
</widget>
</item>
<item>
<widget class="QSpinBox" name="minimap_w_sb">
</property>
</widget>
</item>
</layout>
</item>
<item>
<layout class="QHBoxLayout" name="horizontalLayout_4">
<item>
<widget class="QLabel" name="label_6">
<string>height</string>
</property>
</widget>
</item>
<item>
<widget class="QSpinBox" name="minimap_h_sb">
</property>
</widget>
</item>
</layout>
</item> </item>
</layout> </layout>
</item> </item>
<item> <item>
<spacer name="verticalSpacer_6"> <spacer name="horizontalSpacer_8">
<size> <size>
<width>10</width> <width>40</width>
<height>10</height> <height>20</height>
</size> </size>
</spacer> </spacer>
...@@ -521,91 +565,29 @@ ...@@ -521,91 +565,29 @@
</layout> </layout>
</item> </item>
<item> <item>
<spacer name="verticalSpacer_2"> <layout class="QHBoxLayout" name="horizontalLayout_5">
<property name="orientation"> <property name="sizeConstraint">
<enum>Qt::Vertical</enum> <enum>QLayout::SetDefaultConstraint</enum>
</property>
</property>
<size>
<width>20</width>
<height>40</height>
</size>
</spacer>
</item>
<item>
<item>
<spacer name="verticalSpacer_5">
</property>
</property>
<size>
<width>20</width>
<height>20</height>
</size>
</property>
</spacer>
</item>
<item> <item>
<widget class="QLabel" name="label_4"> <widget class="QLabel" name="label_7">
<string>Dimension</string> <string>square border size</string>
</widget> </widget>
</item> </item>
<item> <item>
<layout class="QHBoxLayout" name="horizontalLayout_3"> <widget class="QSpinBox" name="spinBox_5"/>
<item>
</property>
</widget>
</item>
<item>
</property>
</widget>
</item>
</layout>
</item> </item>
<item> <item>
<layout class="QHBoxLayout" name="horizontalLayout_4"> <spacer name="horizontalSpacer_7">
<item>
</property>
</widget>
</item>
<item>
</property>
</widget>
</item>
</layout>
</item>
<item>
<spacer name="verticalSpacer_7">
<size> <size>
<height>40</height> <height>20</height>
</size> </size>
</spacer> </spacer>
...@@ -615,105 +597,64 @@ ...@@ -615,105 +597,64 @@
</layout> </layout>
</item> </item>
<item> <item>
<spacer name="verticalSpacer_3"> <spacer name="verticalSpacer">
<enum>Qt::Vertical</enum> <enum>Qt::Vertical</enum>
<enum>QSizePolicy::Fixed</enum>
</property>
<size> <size>
<width>20</width> <width>20</width>
<height>30</height> <height>40</height>
</size> </size>
</spacer> </spacer>
</item> </item>
<item>
</property>
<item>
</property>
</widget>
</item>
<item>
</property>
</property>
<size>
<width>20</width>
<height>40</height>
</size>
</property>
</spacer>
</item>
<item>
</item>
</layout>
</item>
</layout> </layout>
</widget>
</widget>
</item>
<item>
<layout class="QHBoxLayout" name="horizontalLayout_11">
</property>
<item>
<spacer name="horizontalSpacer_2">
</property>
<size>
<width>40</width>
<height>20</height>
</size>
</property>
</spacer>
</item>
<item>
<widget class="QPushButton" name="cancel">
<string>Cancel</string>
</property>
</widget>
</item>
<item>
<widget class="QPushButton" name="apply">
<string>Apply</string>
</property>
</widget>
</item>
<item>
<widget class="QPushButton" name="ok">
<string>OK</string>
</property>
</widget>
</item> </item>
</layout> </layout>
</widget> </item>
</widget> </layout>
<widget class="QWidget" name="">
<rect>
<x>10</x>
<y>377</y>
<width>421</width>
<height>29</height>
</rect>
</property>
<item>
</property>
<size>
<width>40</width>
<height>20</height>
</size>
</property>
</spacer>
</item>
<item>
</property>
</widget>
</item>
<item>
</property>
</widget>
</item>
<item>
<string>OK</string>
</property>
</widget>
</item>
</layout>
</widget>
</widget> </widget>
<resources> <resources>
<include location="vite.qrc"/> <include location="vite.qrc"/>
