- Downloads
Updating the `Core` class, so that in can draw several traces on the main window at a time.
Many changes have been brought outside `src/core/Core.(cpp|hpp)`, so that the program compiles. So many uses of `Core` have to be corrected (in method `Core::launch_action` for example).
- src/common/Errors.cpp 1 addition, 1 deletionsrc/common/Errors.cpp
- src/common/Info.cpp 0 additions, 9 deletionssrc/common/Info.cpp
- src/common/Info.hpp 0 additions, 20 deletionssrc/common/Info.hpp
- src/core/Core.cpp 221 additions, 134 deletionssrc/core/Core.cpp
- src/core/Core.hpp 15 additions, 6 deletionssrc/core/Core.hpp
- src/interface/Interface.hpp 3 additions, 1 deletionsrc/interface/Interface.hpp
- src/interface/Interface_graphic.cpp 151 additions, 67 deletionssrc/interface/Interface_graphic.cpp
- src/interface/Interface_graphic.hpp 41 additions, 20 deletionssrc/interface/Interface_graphic.hpp
- src/interface/Interval_select.cpp 18 additions, 17 deletionssrc/interface/Interval_select.cpp
- src/interface/Node_select.cpp 6 additions, 6 deletionssrc/interface/Node_select.cpp
- src/interface/multirender_window.cpp 17 additions, 5 deletionssrc/interface/multirender_window.cpp
- src/interface/multirender_window.hpp 27 additions, 4 deletionssrc/interface/multirender_window.hpp
- src/plugin/Command_window.cpp 1 addition, 1 deletionsrc/plugin/Command_window.cpp
- src/render/GanttDiagram.hpp 11 additions, 11 deletionssrc/render/GanttDiagram.hpp
- src/render/Geometry.cpp 6 additions, 6 deletionssrc/render/Geometry.cpp
- src/render/Geometry.hpp 9 additions, 1 deletionsrc/render/Geometry.hpp
- src/render/Render.hpp 30 additions, 0 deletionssrc/render/Render.hpp
- src/render/Render_abstract.cpp 4 additions, 4 deletionssrc/render/Render_abstract.cpp
- src/render/Render_svg.cpp 10 additions, 10 deletionssrc/render/Render_svg.cpp
- src/render/opengl/Render_opengl.cpp 24 additions, 24 deletionssrc/render/opengl/Render_opengl.cpp
Loading
