Commit a0056374 authored by Mathieu Faverge's avatar Mathieu Faverge
Update map calls
parent 906d73c7
...@@ -133,7 +133,7 @@ CHAM_desc_t **descA ) ...@@ -133,7 +133,7 @@ CHAM_desc_t **descA )
CHKERRQ(ierr); CHKERRQ(ierr);
// Assembly driven by chameleon and using the callback CHAMELEON_build_callback_FEMBEM() defined above // Assembly driven by chameleon and using the callback CHAMELEON_build_callback_FEMBEM() defined above
ierr = CHAMELEON_map_Tile( uplo, *descA, ierr = CHAMELEON_map_Tile( ChamW, uplo, *descA,
CHAMELEON_build_callback_FEMBEM, myCtx ); CHAMELEON_build_callback_FEMBEM, myCtx );
...@@ -191,7 +191,7 @@ hmat_interface_t *hi ) ...@@ -191,7 +191,7 @@ hmat_interface_t *hi )
#if 1 #if 1
cham_uplo_t uplo = symMatSolver ? ChamLower : ChamUpperLower; cham_uplo_t uplo = symMatSolver ? ChamLower : ChamUpperLower;
ierr = CHAMELEON_map_Tile( uplo, descA, ierr = CHAMELEON_map_Tile( ChamW, uplo, descA,
HCHAMELEON_build_callback_FEMBEM, hdescA ); HCHAMELEON_build_callback_FEMBEM, hdescA );
#else #else
tile = descA->tiles; tile = descA->tiles;
...@@ -403,7 +403,7 @@ hmat_info_t HCHAMELEON_getinfo( HCHAM_desc_t *hdesc ) ...@@ -403,7 +403,7 @@ hmat_info_t HCHAMELEON_getinfo( HCHAM_desc_t *hdesc )
CHAMELEON_map_Tile( uplo, hdesc->super, CHAMELEON_map_Tile( ChamR, uplo, hdesc->super,
HCHAMELEON_map_getinfo, &op_args ); HCHAMELEON_map_getinfo, &op_args );
MPI_Allreduce( &(op_args.compress_size), &ginfo.compressed_size, 1, MPI_Allreduce( &(op_args.compress_size), &ginfo.compressed_size, 1,
