Commit fdb9228a authored by Mathieu Faverge's avatar Mathieu Faverge
Add confirgutaion files
parent 896e0297
...@@ -8,19 +8,75 @@ ...@@ -8,19 +8,75 @@
# @date 2013-06-24 # @date 2013-06-24
cmake_minimum_required (VERSION 3.0)
project (SPM C)
# Check if compiled independently or within another project
if ( ${CMAKE_SOURCE_DIR} STREQUAL ${CMAKE_CURRENT_SOURCE_DIR})
set( BUILD_SUBPROJECT OFF )
option(BUILD_SHARED_LIBS
"Build shared libraries" OFF)
if(NOT CMAKE_BUILD_TYPE)
set(CMAKE_BUILD_TYPE RelWithDebInfo CACHE STRING "Choose the type of build, options are None, Debug, Release, RelWithDebInfo and MinSizeRel." FORCE)
endif(NOT CMAKE_BUILD_TYPE)
if (IS_DIRECTORY ${CMAKE_SOURCE_DIR}/cmake_modules/morse_cmake/modules)
set( MORSE_CMAKE_MODULE_PATH ${CMAKE_SOURCE_DIR}/cmake_modules/morse_cmake/modules )
list(APPEND CMAKE_MODULE_PATH ${MORSE_CMAKE_MODULE_PATH})
include(MorseInit)
else()
message(FATAL_ERROR "Submodule cmake_morse not initialized - run `git submodule update --init`")
endif()
else()
set( BUILD_SUBPROJECT ON )
endif()
list(APPEND CMAKE_MODULE_PATH "${CMAKE_CURRENT_SOURCE_DIR}/cmake_modules")
include(GenSPMPkgConfig)
# The current version number
set (SPM_VERSION_MAJOR 0)
set (SPM_VERSION_MINOR 1)
set (SPM_VERSION_MICRO 0)
set( SPM_VERSION "${SPM_VERSION_MAJOR}.${SPM_VERSION_MINOR}.${SPM_VERSION_MICRO}" )
# Define precision supported by MAGMA_MORSE
set( RP_SPM_DICTIONNARY ${MORSE_CMAKE_MODULE_PATH}/precision_generator/subs.py )
set( RP_SPM_PRECISIONS "s;d;c;z" )
include(RulesPrecisions)
include(RulesPrecisions) include(RulesPrecisions)
include(AddSourceFiles) include(AddSourceFiles)
# PaStiX depends on CBLAS
find_package(CBLAS) # Should be REQUIRED for BLAS sequential only
if(CBLAS_FOUND)
message(STATUS "cblas: ${CBLAS_INCLUDE_DIRS}")
include_directories(${CBLAS_INCLUDE_DIRS})
endif()
find_package(LAPACKE) # Should be also REQUIRED
if(LAPACKE_FOUND)
message(STATUS "lapacke: ${LAPACKE_INCLUDE_DIRS}")
include_directories(${LAPACKE_INCLUDE_DIRS})
endif()
include_directories(include)
include_directories("${CMAKE_CURRENT_BINARY_DIR}/src")
include_directories("${CMAKE_CURRENT_SOURCE_DIR}/drivers")
### reset variables ### reset variables
set(generated_sources "") set(generated_sources "")
set(generated_headers "") set(generated_headers "")
include_directories("${CMAKE_CURRENT_BINARY_DIR}")
### Generate the headers in all precisions ### Generate the headers in all precisions
set(HEADERS set(HEADERS
z_spm.h src/z_spm.h
precisions_rules_py(generated_headers precisions_rules_py(generated_headers
...@@ -29,8 +85,8 @@ precisions_rules_py(generated_headers ...@@ -29,8 +85,8 @@ precisions_rules_py(generated_headers
set(spm_headers set(spm_headers
${generated_headers} ${generated_headers}
spm.h include/spm.h
spm_drivers.h include/spm_drivers.h
add_custom_target(spm_headers_tgt add_custom_target(spm_headers_tgt
...@@ -38,21 +94,21 @@ add_custom_target(spm_headers_tgt ...@@ -38,21 +94,21 @@ add_custom_target(spm_headers_tgt
### Generate the sources in all precisions ### Generate the sources in all precisions
set(SOURCES set(SOURCES
z_spm.c src/z_spm.c
z_spm_2dense.c src/z_spm_2dense.c
z_spm_dof_extend.c src/z_spm_dof_extend.c
z_spm_norm.c src/z_spm_norm.c
z_spm_scal.c src/z_spm_scal.c
z_spm_convert_to_csc.c src/z_spm_convert_to_csc.c
z_spm_convert_to_csr.c src/z_spm_convert_to_csr.c
z_spm_convert_to_ijv.c src/z_spm_convert_to_ijv.c
z_spm_expand.c src/z_spm_expand.c
z_spm_genrhs.c src/z_spm_genrhs.c
z_spm_integer.c src/z_spm_integer.c
z_spm_laplacian.c src/z_spm_laplacian.c
z_spm_matrixvector.c src/z_spm_matrixvector.c
z_spm_print.c src/z_spm_print.c
precisions_rules_py(generated_sources precisions_rules_py(generated_sources
...@@ -61,56 +117,56 @@ precisions_rules_py(generated_sources ...@@ -61,56 +117,56 @@ precisions_rules_py(generated_sources
set(spm_sources set(spm_sources
${generated_sources} ${generated_sources}
spm.c src/spm.c
spm_io.c src/spm_io.c
spm_integers.c src/spm_integers.c
spm_dof_extend.c src/spm_dof_extend.c
spm_read_driver.c src/spm_read_driver.c
spm_gen_fake_values.c src/spm_gen_fake_values.c
drivers/iohb.c src/drivers/iohb.c
drivers/mmio.c src/drivers/mmio.c
drivers/laplacian.c src/drivers/laplacian.c
drivers/readhb.c src/drivers/readhb.c
drivers/readijv.c src/drivers/readijv.c
drivers/readmm.c src/drivers/readmm.c
if (PASTIX_WITH_FORTRAN) if (SPM_WITH_FORTRAN)
${spm_sources} ${spm_sources}
drivers/skitf.f src/drivers/skitf.f
drivers/readrsa.c src/drivers/readrsa.c
endif() endif()
add_library(pastix_spm add_library(spm
target_link_libraries(pastix_spm target_link_libraries(spm
${LAPACKE_LIBRARIES} ${LAPACKE_LIBRARIES}
${LAPACK_SEQ_LIBRARIES} ${LAPACK_SEQ_LIBRARIES}
${CBLAS_LIBRARIES} ${CBLAS_LIBRARIES}
${BLAS_SEQ_LIBRARIES} ${BLAS_SEQ_LIBRARIES}
add_dependencies(pastix_spm add_dependencies(spm
spm_headers_tgt spm_headers_tgt
### Generate the lib ### Generate the lib
if (MPI_C_FOUND) if (MPI_C_FOUND)
set_target_properties(pastix_spm PROPERTIES COMPILE_FLAGS "${MPI_COMPILE_FLAGS}") set_target_properties(spm PROPERTIES COMPILE_FLAGS "${MPI_COMPILE_FLAGS}")
${MPI_C_LIBRARIES} ${MPI_C_LIBRARIES}
endif (MPI_C_FOUND) endif (MPI_C_FOUND)
install(TARGETS pastix_spm install(TARGETS spm
ARCHIVE DESTINATION lib ARCHIVE DESTINATION lib
LIBRARY DESTINATION lib) LIBRARY DESTINATION lib)
install(FILES spm.h install(FILES include/spm.h
DESTINATION include ) DESTINATION include )
### Add documented files to the global property ### Add documented files to the global property
...@@ -122,12 +178,12 @@ add_documented_files( ...@@ -122,12 +178,12 @@ add_documented_files(
add_documented_files( add_documented_files(
# Headers # Headers
spm.h include/spm.h
#spm_drivers.h #spm_drivers.h
# Source files # Source files
spm.c src/spm.c
# See https://cmake.org/pipermail/cmake/2010-March/035992.html
function(add_source_files)
set(oneValueArgs PROJECT_NAME DIRECTORY)
cmake_parse_arguments(add_source_files "" "${oneValueArgs}" "" ${ARGN})
get_property(is_defined GLOBAL PROPERTY ${PROJECT_NAME}_LIB_SRCS2 DEFINED)
if(NOT is_defined)
define_property(GLOBAL PROPERTY ${PROJECT_NAME}_LIB_SRCS2
BRIEF_DOCS "List of source files included in the PaStiX library"
FULL_DOCS "List of source files included in the PaStiX library")
endif()
if(NOT ${add_source_files_DIRECTORY} STREQUAL "")
set(_dir "${add_source_files_DIRECTORY}/")
else()
set(_dir "")
endif()
set(ARGN ${add_source_files_UNPARSED_ARGUMENTS})
# make absolute paths
set(SRCS)
foreach(s IN LISTS ARGN)
set(s "${_dir}${s}")
if(NOT IS_ABSOLUTE "${s}")
get_filename_component(s "${s}" ABSOLUTE)
endif()
list(APPEND SRCS "${s}")
endforeach()
# append to global list
set_property(GLOBAL APPEND PROPERTY ${PROJECT_NAME}_LIB_SRCS2 "${SRCS}")
endfunction(add_source_files)
function(add_documented_files)
cmake_parse_arguments(add_documented_files "" "${oneValueArgs}" "" ${ARGN})
get_property(is_defined GLOBAL PROPERTY ${PROJECT_NAME}_DOX_SRCS DEFINED)
if(NOT is_defined)
define_property(GLOBAL PROPERTY ${PROJECT_NAME}_DOX_SRCS
BRIEF_DOCS "List of documented source files"
FULL_DOCS "List of source files to be included into the in-code documentation")
endif()
if(NOT ${add_documented_files_DIRECTORY} STREQUAL "")
set(_dir "${add_documented_files_DIRECTORY}/")
else()
set(_dir "")
endif()
set(ARGN ${add_documented_files_UNPARSED_ARGUMENTS})
set(SRCS)
endif()
endforeach()
set_property(GLOBAL APPEND PROPERTY ${PROJECT_NAME}_DOX_SRCS "${SRCS}")
endfunction(add_documented_files)
# @copyright (c) 2009-2014 The University of Tennessee and The University
# of Tennessee Research Foundation.
# All rights reserved.
# @copyright (c) 2012-2017 Inria. All rights reserved.
# @copyright (c) 2012-2014 Bordeaux INP, CNRS (LaBRI UMR 5800), Inria, Univ. Bordeaux. All rights reserved.
# @file GenPkgConfig.cmake
# @project MORSE
# MORSE is a software package provided by:
# Inria Bordeaux - Sud-Ouest,
# Univ. of Tennessee,
# King Abdullah Univesity of Science and Technology
# Univ. of California Berkeley,
# Univ. of Colorado Denver.
# @version 0.9.1
# @author Cedric Castagnede
# @author Emmanuel Agullo
# @author Mathieu Faverge
# @author Florent Pruvost
# @date 10-11-2014
# CONVERT_LIBSTYLE_TO_PKGCONFIG: convert a libraries list to follow the pkg-config style
# used in CLEAN_LIB_LIST
# macro(CONVERT_LIBSTYLE_TO_PKGCONFIG _liblist)
# set(${_liblist}_CPY "${${_liblist}}")
# set(${_liblist} "")
# foreach(_dep ${${_liblist}_CPY})
# if (${_dep} MATCHES "^/")
# get_filename_component(dep_libname ${_dep} NAME)
# get_filename_component(dep_libdir ${_dep} DIRECTORY)
# string(REPLACE "lib" "" dep_libname "${dep_libname}")
# string(REPLACE ".so" "" dep_libname "${dep_libname}")
# string(REPLACE ".a" "" dep_libname "${dep_libname}")
# string(REPLACE ".dylib" "" dep_libname "${dep_libname}")
# string(REPLACE ".dll" "" dep_libname "${dep_libname}")
# list(APPEND ${_liblist} -L${dep_libdir} -l${dep_libname})
# elseif(NOT ${_dep} MATCHES "^-")
# list(APPEND ${_liblist} "-l${_dep}")
# else()
# list(APPEND ${_liblist} ${_dep})
# endif()
# endforeach()
# endmacro(CONVERT_LIBSTYLE_TO_PKGCONFIG)
# CLEAN_LIB_LIST: clean libraries lists to follow the pkg-config style
# used in GENERATE_PKGCONFIG_FILE
#macro(CLEAN_LIB_LIST _package)
# list(REMOVE_DUPLICATES ${_package}_PKGCONFIG_LIBS)
# list(REMOVE_DUPLICATES ${_package}_PKGCONFIG_LIBS_PRIVATE)
# list(REMOVE_DUPLICATES ${_package}_PKGCONFIG_REQUIRED)
# list(REMOVE_DUPLICATES ${_package}_PKGCONFIG_REQUIRED_PRIVATE)
# convert_libstyle_to_pkgconfig(${_package}_PKGCONFIG_LIBS)
# convert_libstyle_to_pkgconfig(${_package}_PKGCONFIG_LIBS_PRIVATE)
# string(REPLACE ";" " " ${_package}_PKGCONFIG_LIBS "${${_package}_PKGCONFIG_LIBS}")
# string(REPLACE ";" " " ${_package}_PKGCONFIG_LIBS_PRIVATE "${${_package}_PKGCONFIG_LIBS_PRIVATE}")
# string(REPLACE ";" " " ${_package}_PKGCONFIG_REQUIRED "${${_package}_PKGCONFIG_REQUIRED}")
# string(REPLACE ";" " " ${_package}_PKGCONFIG_REQUIRED_PRIVATE "${${_package}_PKGCONFIG_REQUIRED_PRIVATE}")
#endmacro(CLEAN_LIB_LIST)
# GENERATE_PKGCONFIG_FILE: generate files spm.pc
macro(GENERATE_SPM_PKGCONFIG_FILE)
set(SPM_PKGCONFIG_LIBS "-lspm")
set(SPM_PKGCONFIG_LIBS_PRIVATE "-lm")
set(SPM_PKGCONFIG_REQUIRED "")
set(SPM_PKGCONFIG_REQUIRED_PRIVATE "")
#clean_lib_list(SPM)
set(_output_spm_file "${CMAKE_BINARY_DIR}/spm.pc")
configure_file(
"${CMAKE_CURRENT_SOURCE_DIR}/lib/pkgconfig/spm.pc.in"
"${_output_spm_file}"
@ONLY
install(
FILES ${_output_spm_file}
DESTINATION lib/pkgconfig
endmacro(GENERATE_SPM_PKGCONFIG_FILE)
# generate_env_file: generate files pastix.pc
macro(generate_env_file)
# Create .sh file
configure_file(
"${CMAKE_CURRENT_SOURCE_DIR}/spm_env.sh.in"
"${CMAKE_BINARY_DIR}/bin/spm_env.sh" @ONLY)
# installation
install(FILES "${CMAKE_BINARY_DIR}/bin/spm_env.sh"
DESTINATION bin)
endmacro(generate_env_file)
## @end file GenPkgConfig.cmake
...@@ -3,11 +3,11 @@ exec_prefix=${prefix} ...@@ -3,11 +3,11 @@ exec_prefix=${prefix}
libdir=${exec_prefix}/lib libdir=${exec_prefix}/lib
includedir=${exec_prefix}/include includedir=${exec_prefix}/include
Name: HQR Name: SPM
Description: Build and Visualize Trees for Hierachical QR Factorizations Description: SParse Matrix package
Version: @HQR_VERSION_MAJOR@.@HQR_VERSION_MINOR@.@HQR_VERSION_MICRO@ Version: @SPM_VERSION_MAJOR@.@SPM_VERSION_MINOR@.@SPM_VERSION_MICRO@
Cflags: -I${includedir} Cflags: -I${includedir}
Libs: -L${libdir} @HQR_PKGCONFIG_LIBS@ Libs: -L${libdir} @SPM_PKGCONFIG_LIBS@
Libs.private: @HQR_PKGCONFIG_LIBS_PRIVATE@ Libs.private: @SPM_PKGCONFIG_LIBS_PRIVATE@
Requires: @HQR_PKGCONFIG_REQUIRED@ Requires: @SPM_PKGCONFIG_REQUIRED@
Requires.private: @HQR_PKGCONFIG_REQUIRED_PRIVATE@ Requires.private: @SPM_PKGCONFIG_REQUIRED_PRIVATE@
