Commit ec34364c authored by Mathieu Faverge's avatar Mathieu Faverge
Merge default
parents 59e93e32 077028e4
include(RulesPrecisions)
### reset variables
set(generated_sources "")
set(generated_headers "")
set(HEADERS
z_spm.h
### Generate the headers in all precisions
precisions_rules_py(generated_headers
"${HEADERS}"
PRECISIONS "p;s;d;c;z")
set(SOURCES
z_spm.c
z_spm_convert_to_csc.c
z_spm_convert_to_csr.c
z_spm_convert_to_ijv.c
z_spm_genrhs.c
z_spm_matrixvector.c
z_spm_norm.c
z_spm_2dense.c
z_spm_print.c
set(spm_headers
${generated_headers}
spm.h
### Generate the sources in all precisions
precisions_rules_py(generated_sources
"${SOURCES}"
set(spm_sources
${generated_sources}
spm.c
spm_io.c
add_custom_target(spm_headers_tgt
DEPENDS ${spm_headers} )
set_source_files_properties(
spm.c
PROPERTIES DEPENDS spm_headers_tgt
set(PASTIX_LIB_SRCS
${PASTIX_LIB_SRCS}
${spm_sources}
...@@ -68,6 +68,46 @@ static int (*conversionTable[3][3][6])(pastix_spm_t*) = { ...@@ -68,6 +68,46 @@ static int (*conversionTable[3][3][6])(pastix_spm_t*) = {
* @ingroup pastix_spm
* spmInit - Init the spm structure given as parameter
* @param[in,out] spm
* The sparse matrix to init.
void
spmInit( pastix_spm_t *spm )
spm->mtxtype = PastixGeneral;
spm->flttype = PastixComplex64;
spm->fmttype = PastixCSC;
spm->gN = 0;
spm->n = 0;
spm->gnnz = 0;
spm->nnz = 0;
spm->gNexp = 0;
spm->nexp = 0;
spm->gnnzexp = 0;
spm->nnzexp = 0;
spm->dof = 1;
spm->dofs = NULL;
spm->colmajor = 1;
spm->colptr = NULL;
spm->rowptr = NULL;
spm->loc2glob = NULL;
spm->values = NULL;
...@@ -106,6 +146,10 @@ spmExit( pastix_spm_t *spm ) ...@@ -106,6 +146,10 @@ spmExit( pastix_spm_t *spm )
* @param[in] ofmttype
* The output format of the sparse matrix. It might be PastixCSC,
* PastixCSR, or PastixIJV.
* @param[in,out] spm * @param[in,out] spm
* The sparse matrix to rebase. * The sparse matrix to rebase.
...@@ -36,14 +36,24 @@ struct pastix_spm_s { ...@@ -36,14 +36,24 @@ struct pastix_spm_s {
int flttype; /**< avals datatype: PastixPattern, PastixFloat, PastixDouble, int flttype; /**< avals datatype: PastixPattern, PastixFloat, PastixDouble,
PastixComplex32 or PastixComplex64 */ PastixComplex32 or PastixComplex64 */
int fmttype; /**< Matrix storage format: PastixCSC, PastixCSR, PastixIJV */ int fmttype; /**< Matrix storage format: PastixCSC, PastixCSR, PastixIJV */
pastix_int_t gN; /**< Global number of vertices in the compressed graph */ pastix_int_t gN; /**< Global number of vertices in the compressed graph */
pastix_int_t n; /**< Local number of vertices in the compressed graph */ pastix_int_t n; /**< Local number of vertices in the compressed graph */
pastix_int_t gnnz; /**< Global number of non zeroes in the compressed graph */ pastix_int_t gnnz; /**< Global number of non zeroes in the compressed graph */
pastix_int_t nnz; /**< Local number of non zeroes in the compressed graph */ pastix_int_t nnz; /**< Local number of non zeroes in the compressed graph */
pastix_int_t gNexp; /**< Global number of vertices in the compressed graph */
pastix_int_t nexp; /**< Local number of vertices in the compressed graph */
pastix_int_t gnnzexp; /**< Global number of non zeroes in the compressed graph */
pastix_int_t nnzexp; /**< Local number of non zeroes in the compressed graph */
pastix_int_t dof; /**< Number of degrees of freedom per unknown, pastix_int_t dof; /**< Number of degrees of freedom per unknown,
if > 0, constant degree of freedom if > 0, constant degree of freedom
otherwise, irregular degree of freedom (refer to dofs) */ otherwise, irregular degree of freedom (refer to dofs) */
pastix_int_t *dofs; /**< Number of degrees of freedom per unknown (NULL, if dof > 0) */ pastix_int_t *dofs; /**< Number of degrees of freedom per unknown (NULL, if dof > 0) */
int colmajor; /**< If > 0, column major with dofs
otherwise, row major */
pastix_int_t *colptr; /**< List of indirections to rows for each vertex */ pastix_int_t *colptr; /**< List of indirections to rows for each vertex */
pastix_int_t *rowptr; /**< List of edges for each vertex */ pastix_int_t *rowptr; /**< List of edges for each vertex */
pastix_int_t *loc2glob; /**< Corresponding numbering from local to global */ pastix_int_t *loc2glob; /**< Corresponding numbering from local to global */
...@@ -89,4 +99,6 @@ pastix_int_t spmSymmetrize( pastix_spm_t *spm ); ...@@ -89,4 +99,6 @@ pastix_int_t spmSymmetrize( pastix_spm_t *spm );
pastix_spm_t *spmCheckAndCorrect( pastix_spm_t *spm ); pastix_spm_t *spmCheckAndCorrect( pastix_spm_t *spm );
void dofVar(pastix_spm_t* spm);//tmp
#endif /* _SPM_H_ */ #endif /* _SPM_H_ */
* @file spm_expand.c
* PaStiX spm routines
* PaStiX is a software package provided by Inria Bordeaux - Sud-Ouest,
* LaBRI, University of Bordeaux 1 and IPB.
* @version 5.1.0
* @author Mathieu Faverge
* @author Theophile Terraz
* @author Alban Bellot
* @date 2015-01-01
#include "common.h"
#include "spm.h"
#include "z_spm.h"
void
spmExpandCSC(pastix_spm_t* spm)
switch(spm->flttype)
case PastixFloat:
s_extandCSC(spm);
break;
case PastixComplex32:
c_extandCSC(spm);
break;
case PastixComplex64:
z_extandCSC(spm);
break;
case PastixDouble:
default:
d_extandCSC(spm);
break;
void print_tab_int(pastix_int_t* tab, pastix_int_t size)
int i;
for(i=0;i<size;i++)
printf("%d ",tab[i]);
printf("\n");
void print_tab_cpx(double* tab, pastix_int_t size)
int i;
for(i=0;i<size;i++)
printf("%f ",tab[i]);
printf("\n");
void init_rand()
srand(time(NULL));
int randminmax(pastix_int_t min, pastix_int_t max)
return min + rand()%(max-min+1);
pastix_int_t* computeCorrespondIndex(const pastix_int_t *dofs, pastix_int_t n)
pastix_int_t* dofs_coef=malloc(sizeof(pastix_int_t)*(n+1));
dofs_coef[0]=0;
int i;
for(i=1;i<n+1;i++)
dofs_coef[i]=dofs_coef[i-1]+dofs[i-1];
return dofs_coef;
void genDof(pastix_int_t step,pastix_int_t* dofs,pastix_int_t size)
int i;
for(i=0;i<size;i++)
dofs[i]=i%step+1;
void genRandDof(pastix_int_t min,pastix_int_t max,pastix_int_t* dofs,pastix_int_t size)
int i;
for(i=0;i<size;i++)
dofs[i]=randminmax(min,max);
pastix_int_t* computeEltPerCol(const pastix_spm_t *spm)
pastix_int_t col,row,baseval;
pastix_int_t* coef=malloc(sizeof(pastix_int_t)*spm->n);
int i;
for(i=0;i<spm->n;i++)
coef[i]=0;
baseval=spmFindBase( spm );
row=0;
for( col=0; col < spm->n; col++ )
for( row=spm->colptr[col]-baseval; row<spm->colptr[col+1]-baseval; row++)
coef[col] += spm->dofs[col] * spm->dofs[spm->rowptr[row]-baseval];
return coef;
* @ingroup spm_internal
* dofCst - Expand a CSC matrix without dofs into a CSC matrix with constant dofs
* @param[in] spm
* The spm to expand
void
dofCst(pastix_spm_t* spm,pastix_int_t dof)
int i;
pastix_int_t* dofs = malloc((spm->n+1)*sizeof(pastix_int_t));
spm->dof = dof;
spm->gNexp = spm->n*dof;
spm->nexp = spm->n*dof;
spm->nnzexp = spm->n*dof*dof;
spm->gnnzexp = spm->n*dof*dof;
spm->dofs = dofs;
for(i=0;i<spm->n+1;i++)
dofs[i]=dof*i;
spmExpandCSC(spm);
* dofVar - Expand a CSC matrix without dofs into a CSC matrix with variable dofs
* @param[in] spm
* The spm to expand
void
pastix_int_t *dofs=malloc(sizeof(pastix_int_t)*spm->n);
pastix_int_t i,nnzexp,nexp;
spm->gNexp = spm->gN;
spm->nexp = spm->n;
spm->gnnzexp = spm->gnnz;
spm->nnzexp = spm->nnz;
spm->dof = -1;
genDof(3,dofs,spm->n); //cyclique, pas de 3
//genRandDof(/*min*/1,/*max*/5 ,spm->dofs,spm->n); //random dofs, entre 1 et 5
spm->dofs = dofs;
pastix_int_t *coef = computeEltPerCol(spm); // free coef
nnzexp = 0;
nexp = 0;
nnzexp += coef[i];
nexp += spm->dofs[i];
spm->nnzexp = nnzexp;
spm->gnnzexp = nnzexp;
spm->gNexp = nexp;
spm->nexp = nexp;
pastix_int_t* tab = computeCorrespondIndex(dofs,spm->n);
spm->dofs = tab;
spmExpandCSC(spm);
print_tab_int(spm->colptr,spm->n);
print_tab_int(spm->rowptr,spm->nnz);
print_tab_cpx(spm->values,spm->nnzexp);
print_tab_int(spm->dofs,spm->n+1);
...@@ -37,4 +37,15 @@ pastix_int_t z_spmSymmetrize( pastix_spm_t *csc ); ...@@ -37,4 +37,15 @@ pastix_int_t z_spmSymmetrize( pastix_spm_t *csc );
int z_spmGenRHS(int type, int nrhs, const pastix_spm_t *spm, void *x, int ldx, void *b, int ldb ); int z_spmGenRHS(int type, int nrhs, const pastix_spm_t *spm, void *x, int ldx, void *b, int ldb );
int z_spmCheckAxb( int nrhs, const pastix_spm_t *spm, void *x0, int ldx0, void *b, int ldb, const void *x, int ldx ); int z_spmCheckAxb( int nrhs, const pastix_spm_t *spm, void *x0, int ldx0, void *b, int ldb, const void *x, int ldx );
pastix_complex64_t *z_spm2dense( const pastix_spm_t *spm );
void z_spmDensePrint( pastix_int_t m, pastix_int_t n, pastix_complex64_t *A, pastix_int_t lda );
void z_spmPrint( const pastix_spm_t *spm );
void z_spmConvertColMaj2RowMaj(pastix_spm_t *spm);
void z_spmConvertRowMaj2ColMaj(pastix_spm_t *spm);
void z_extandCSC(pastix_spm_t *spm);
void z_spmDofs2Flat(pastix_spm_t *spm);
#endif /* _z_spm_H_ */ #endif /* _z_spm_H_ */
* @file z_spm_2dense.c
* Convert a sparse matrix into a dense matrix.
* @version 5.1.0
* @date 2015-01-01
* @precisions normal z -> c d s
#include <stdint.h>
#include <stdlib.h>
#include <stdio.h>
#include <math.h>
#include <string.h>
#include <assert.h>
#include "pastix.h"
#include "common.h"
#include "spm.h"
#include "z_spm.h"
pastix_int_t i, j, lda, baseval;
pastix_complex64_t *A, *valptr;
pastix_int_t *colptr, *rowptr;
assert( spm->fmttype == PastixCSC );
assert( spm->flttype == PastixComplex64 );
lda = spm->gNexp;
A = (pastix_complex64_t*)malloc(lda * lda * sizeof(pastix_complex64_t));
memset( A, 0, lda * lda * sizeof(pastix_complex64_t));
baseval = spmFindBase( spm );
i = 0; j = 0;
colptr = spm->colptr;
rowptr = spm->rowptr;
valptr = (pastix_complex64_t*)(spm->values);
* Constant degree of fredom of 1
if ( spm->dof == 1 ) {
switch( spm->mtxtype ){
#if defined(PRECISION_z) || defined(PRECISION_c)
case PastixHermitian:
for(i=0; i<spm->n; i++, colptr++)
for(j=colptr[0]; j<colptr[1]; j++, rowptr++, valptr++)
A[ i * lda + (*rowptr - baseval) ] = *valptr;
A[ (*rowptr - baseval) * lda + i ] = conj(*valptr);
break;
#endif
case PastixSymmetric:
A[ (*rowptr - baseval) * lda + i ] = *valptr;
break;
case PastixGeneral:
default:
* General degree of freedom (constant or variable)
else {
pastix_int_t k, ii, jj, dofi, dofj, col, row;
pastix_int_t *dofs = spm->dofs;
dofi = ( spm->dof > 1 ) ? spm->dof : dofs[i+1] - dofs[i];
col = dofs[i];
for(k=colptr[0]; k<colptr[1]; k++, rowptr++)
j = (*rowptr - baseval);
dofj = ( spm->dof > 1 ) ? spm->dof : dofs[j+1] - dofs[j];
row = dofs[j];
for(ii=0; ii<dofi; ii++)
for(jj=0; jj<dofj; jj++, valptr++)
A[ (col + ii) * lda + (row + jj) ] = *valptr;
A[ (row + jj) * lda + (col + ii) ] = conj(*valptr);
break;
#endif
col = dofs[i];
row = dofs[j];
A[ (row + jj) * lda + (col + ii) ] = *valptr;
break;
case PastixGeneral:
default:
col = dofs[i];
row = dofs[j];
return A;
void
pastix_int_t i, j;
for(i=0; i<m; i++)
for(j=0; j<n; j++)
if ( cabs( A[ lda *j + i] ) != 0. ) {
fprintf( stderr, "%ld %ld (%e, %e)\n",
i, j, creal(A[lda * j + i]), cimag(A[lda * j + i]) );
#else
fprintf( stderr, "%ld %ld %e\n",
i, j, A[lda * j + i] );
#endif
return;
* @file z_spm_convert_col_row_major.c
* @version 5.1.0
* @date 2015-01-01
* @precisions normal z -> c d s p
#include "common.h"
#include "spm.h"
#include "z_spm.h"
* z_spmConvertColMaj2RowMaj - convert a matrix in Column Major format to a
* matrix in Row Major format.
* The colmaj matrix at enter,
* the rowmaj matrix at exit.
void
assert(spm->colmajor > 0);
assert(spm->dof != 1);
assert(spm->dofs);
spm->colmajor = -1;
pastix_int_t dofi, dofj, ii, jj, i, j, k, baseval;
pastix_int_t cpt=0;
pastix_int_t *tmp;
pastix_complex64_t *oavals, *navals;
oavals = (pastix_complex64_t*)spm->values;
navals = malloc(sizeof(pastix_complex64_t)*spm->nnzexp);
switch(spm->fmttype)
case PastixCSC:
for(i=0; i<spm->n; i++)
//dofi = ( spm->dof > 0 ) ? spm->dof : dofs[i+1] - dofs[i];
dofi = dofs[i+1] - dofs[i];
for(k=spm->colptr[i]; k<spm->colptr[i+1]; k++)
j = spm->rowptr[k-baseval] - baseval;
//dofj = ( spm->dof > 0 ) ? spm->dof : dofs[j+1] - dofs[j];
dofj = dofs[j+1] - dofs[j];
for(jj=0; jj<dofj; jj++)
navals[cpt + jj * dofi + ii] = *oavals;
oavals++;
cpt += dofi * dofj;
spm->values = navals;
break;
case PastixCSR:
tmp = spm->rowptr;
spm->rowptr = spm->colptr;
spm->colptr = tmp;
z_spmConvertRowMaj2ColMaj(spm);
spm->colmajor = -1;
tmp = spm->rowptr;
spm->colptr = tmp;
spm->fmttype = PastixCSR;
break;
case PastixIJV:
for(k=0; k<spm->nnz; k++)
j = spm->rowptr[k]-baseval;
i = spm->colptr[k]-baseval;
oavals++;
cpt += dofi * dofj;
default:
break;
* z_spmConvertColMaj2RowMaj - convert a matrix in Row Major format to a matrix
* in Column Major format.
* The rowmaj matrix at enter,
* the colmaj matrix at exit.
void
assert(spm->colmajor < 0);
assert(spm->dofs);
spm->colmajor = 1;
pastix_int_t cpt=0;
pastix_int_t *tmp;
case PastixCSC :
j = spm->rowptr[k-baseval]-baseval;
navals[cpt + ii * dofj + jj] = *oavals;
oavals++;
cpt += dofi * dofj;
break;
case PastixCSR :
tmp = spm->rowptr;
spm->colptr = tmp;
z_spmConvertColMaj2RowMaj(spm);
spm->colmajor = 1;
tmp = spm->rowptr;
spm->colptr = tmp;
break;
case PastixIJV:
oavals++;
cpt += dofi * dofj;
default:
break;
...@@ -9,6 +9,7 @@ ...@@ -9,6 +9,7 @@
* @version 5.1.0 * @version 5.1.0
* @author Mathieu Faverge * @author Mathieu Faverge
* @author Theophile Terraz * @author Theophile Terraz
* @date 2015-01-01 * @date 2015-01-01
* @precisions normal z -> c d s p * @precisions normal z -> c d s p
...@@ -80,11 +81,45 @@ z_spmConvertIJV2CSC( pastix_spm_t *spm ) ...@@ -80,11 +81,45 @@ z_spmConvertIJV2CSC( pastix_spm_t *spm )
/* Sort the rows and avals arrays by column */ /* Sort the rows and avals arrays by column */
spm->rowptr = malloc(spm->nnz * sizeof(pastix_int_t)); spm->rowptr = malloc(spm->nnz * sizeof(pastix_int_t));
pastix_int_t *node = calloc(spm->nnz+1,sizeof(pastix_int_t));
pastix_int_t *old_node = calloc(spm->nnz+1,sizeof(pastix_int_t));
pastix_int_t row, col, dofi, dofj;
for(i=0; i<spm->nnz; i++)
row = oldspm.rowptr[i]-baseval;
col = oldspm.colptr[i]-baseval;
dofi = ( spm->dof > 0 ) ? spm->dof : dofs[col+1] - dofs[col];
dofj = ( spm->dof > 0 ) ? spm->dof : dofs[row+1] - dofs[row];
old_node[i+1] = dofi * dofj;
node[spm->colptr[col]+1] += dofi * dofj;
spm->colptr[col]++;
for(i=0;i<spm->nnz;i++)
node[i+1]+=node[i];
old_node[i+1]+=old_node[i];
/* Restore the colptr indexes */
pastix_int_t tmp, tmp2;
tmp = spm->colptr[0];
spm->colptr[0] = 0;
for (j=0; j<spm->n; j++) {
tmp2 = spm->colptr[j+1];
spm->colptr[j+1] = tmp;
tmp = tmp2;
#if defined(PRECISION_p) #if defined(PRECISION_p)
spm->values = NULL; spm->values = NULL;
#else #else
spm->values = malloc(spm->nnz * sizeof(pastix_complex64_t)); pastix_int_t ii, jj;
spm->values = malloc(spm->nnzexp * sizeof(pastix_complex64_t));
navals = (pastix_complex64_t*)(spm->values); navals = (pastix_complex64_t*)(spm->values);
oavals = (pastix_complex64_t*)(oldspm.values); oavals = (pastix_complex64_t*)(oldspm.values);
#endif #endif
...@@ -92,11 +127,20 @@ z_spmConvertIJV2CSC( pastix_spm_t *spm ) ...@@ -92,11 +127,20 @@ z_spmConvertIJV2CSC( pastix_spm_t *spm )
for (j=0; j<spm->nnz; j++) for (j=0; j<spm->nnz; j++)
i = oldspm.colptr[j] - baseval; i = oldspm.colptr[j] - baseval;
spm->rowptr[ spm->colptr[i] ] = oldspm.rowptr[j]; spm->rowptr[ spm->colptr[i] ] = oldspm.rowptr[j];
#if !defined(PRECISION_p) #if !defined(PRECISION_p)
navals[ spm->colptr[i] ] = oavals[j]; dofi = ( spm->dof > 0 ) ? spm->dof : dofs[i+1] - dofs[i];
dofj = ( spm->dof > 0 ) ? spm->dof : dofs[oldspm.rowptr[j]-baseval+1] - dofs[oldspm.rowptr[j]-baseval];
navals[node[spm->colptr[i]]] = oavals[ old_node[j]];
old_node[j]++;
node[spm->colptr[i]]++;
#endif #endif
(spm->colptr[i])++; (spm->colptr[i])++;
...@@ -106,7 +150,6 @@ z_spmConvertIJV2CSC( pastix_spm_t *spm ) ...@@ -106,7 +150,6 @@ z_spmConvertIJV2CSC( pastix_spm_t *spm )
/* Rebuild the colptr with the correct baseval */ /* Rebuild the colptr with the correct baseval */
tmp = spm->colptr[0]; tmp = spm->colptr[0];
spm->colptr[0] = baseval; spm->colptr[0] = baseval;
spmptx = spm->colptr + 1; spmptx = spm->colptr + 1;
for (i=1; i<(spm->n+1); i++, spmptx++) for (i=1; i<(spm->n+1); i++, spmptx++)
...@@ -119,7 +162,7 @@ z_spmConvertIJV2CSC( pastix_spm_t *spm ) ...@@ -119,7 +162,7 @@ z_spmConvertIJV2CSC( pastix_spm_t *spm )
spmExit( &oldspm ); spmExit( &oldspm );
spm->fmttype = PastixCSC; spm->fmttype = PastixCSC;
spm->colmajor = 1;
return PASTIX_SUCCESS; return PASTIX_SUCCESS;
...@@ -152,6 +195,10 @@ z_spmConvertCSR2CSC( pastix_spm_t *spm ) ...@@ -152,6 +195,10 @@ z_spmConvertCSR2CSC( pastix_spm_t *spm )
pastix_int_t type = spm->mtxtype;
if(spm->dof != 1)
switch( spm->mtxtype ) { switch( spm->mtxtype ) {
#if defined(PRECISION_z) || defined(PRECISION_c) #if defined(PRECISION_z) || defined(PRECISION_c)
case PastixHermitian: case PastixHermitian:
...@@ -184,26 +231,36 @@ z_spmConvertCSR2CSC( pastix_spm_t *spm ) ...@@ -184,26 +231,36 @@ z_spmConvertCSR2CSC( pastix_spm_t *spm )
pastix_int_t *row_csc; pastix_int_t *row_csc;
pastix_int_t *col_csc; pastix_int_t *col_csc;
pastix_int_t *node;
pastix_int_t *dofs;
pastix_complex64_t *val_csc; pastix_complex64_t *val_csc;
pastix_complex64_t *valptr = (pastix_complex64_t*)(spm->values); pastix_complex64_t *valptr = (pastix_complex64_t*)(spm->values);
int cpt = 0;
#endif #endif
pastix_int_t j, k, col, row, nnz, baseval; pastix_int_t i, j, k, col, row, nnz, baseval;
pastix_int_t dofi, dofj;
baseval = spmFindBase( spm ); baseval = spmFindBase( spm );
nnz = spm->nnz; nnz = spm->nnz;
row_csc = malloc(nnz * sizeof(pastix_int_t)); row_csc = malloc(nnz * sizeof(pastix_int_t));
col_csc = calloc(spm->n+1,sizeof(pastix_int_t)); col_csc = calloc(spm->n+1,sizeof(pastix_int_t));
dofs = spm->dofs;
assert( row_csc ); assert( row_csc );
assert( col_csc ); assert( col_csc );
assert( node );
assert( ( (dofs) && !(spm->dof > 0) ) ||
( !(dofs) && (spm->dof > 0) ) ); // (dofs) xor (spm->dof > 0)
val_csc = malloc(nnz*sizeof(pastix_complex64_t)); val_csc = malloc(spm->nnzexp*sizeof(pastix_complex64_t));
assert( val_csc ); assert( val_csc );
#endif #endif
/* Count the number of elements per column */ /* Count the number of elements per column */
for (j=0; j<nnz; j++) { for (j=0; j<nnz; j++) {
col = spm->colptr[j] - baseval; col = spm->colptr[j] - baseval;
...@@ -217,6 +274,35 @@ z_spmConvertCSR2CSC( pastix_spm_t *spm ) ...@@ -217,6 +274,35 @@ z_spmConvertCSR2CSC( pastix_spm_t *spm )
col_csc[j+1] += col_csc[j]; col_csc[j+1] += col_csc[j];
for(k=spm->rowptr[i]; k<spm->rowptr[i+1]; k++)
j = spm->colptr[k-baseval] - baseval;
row = ( spm->dof > 0 ) ? j : dofs[j];
col = ( spm->dof > 0) ? i : dofs[i];
node[col_csc[j]+1] += dofi * dofj;
col_csc[j]++;
for(i=0;i <spm->nnz; i++)
node[i+1] += node[i];
tmp = col_csc[0];
col_csc[0] = 0;
tmp2 = col_csc[j+1];
col_csc[j+1] = tmp;
tmp = tmp2;
assert( (col_csc[spm->gN]) == nnz ); assert( (col_csc[spm->gN]) == nnz );
for (row=0; row<spm->n; row++) { for (row=0; row<spm->n; row++) {
...@@ -227,27 +313,34 @@ z_spmConvertCSR2CSC( pastix_spm_t *spm ) ...@@ -227,27 +313,34 @@ z_spmConvertCSR2CSC( pastix_spm_t *spm )
col = spm->colptr[k] - baseval; col = spm->colptr[k] - baseval;
j = col_csc[col]; j = col_csc[col];
row_csc[j] = row + baseval; row_csc[j] = row + baseval;
val_csc[j] = valptr[k]; dofi = ( spm->dof > 0 ) ? spm->dof : dofs[col+1] - dofs[col];
for(jj=0; jj < dofj ; jj++)
for(ii=0; ii < dofi ; ii++)
val_csc[node[j] + ii * dofj + jj] = valptr[cpt];
cpt++;
#endif #endif
col_csc[col] ++; col_csc[col]++;
/* Restore the colptr indexes */ /* Restore the colptr indexes */
pastix_int_t tmp, tmp2; pastix_int_t tmp, tmp2;
tmp = col_csc[0]; tmp = col_csc[0];
col_csc[0] = baseval; col_csc[0] = baseval;
for (j=0; j<spm->n; j++) { for (j=0; j<spm->n; j++)
tmp2 = col_csc[j+1]; tmp2 = col_csc[j+1];
col_csc[j+1] = tmp + baseval; col_csc[j+1] = tmp + baseval;
tmp = tmp2; tmp = tmp2;
spmExit( spm ); spmExit( spm );
spm->colptr = col_csc; spm->colptr = col_csc;
spm->rowptr = row_csc; spm->rowptr = row_csc;
...@@ -259,5 +352,8 @@ z_spmConvertCSR2CSC( pastix_spm_t *spm ) ...@@ -259,5 +352,8 @@ z_spmConvertCSR2CSC( pastix_spm_t *spm )
if(spm-> dof != 1)
spm->mtxtype = type;
spm->colmajor = 1;
* @authot Alban Bellot
...@@ -43,6 +44,10 @@ z_spmConvertCSC2CSR( pastix_spm_t *spm ) ...@@ -43,6 +44,10 @@ z_spmConvertCSC2CSR( pastix_spm_t *spm )
pastix_int_t *tmp; pastix_int_t *tmp;
pastix_int_t result; pastix_int_t result;
if(spm->dof != 1)
...@@ -66,7 +71,6 @@ z_spmConvertCSC2CSR( pastix_spm_t *spm ) ...@@ -66,7 +71,6 @@ z_spmConvertCSC2CSR( pastix_spm_t *spm )
spm->rowptr = spm->colptr; spm->rowptr = spm->colptr;
spm->colptr = tmp; spm->colptr = tmp;
spm->fmttype = PastixCSR; spm->fmttype = PastixCSR;
break; break;
...@@ -91,6 +95,10 @@ z_spmConvertCSC2CSR( pastix_spm_t *spm ) ...@@ -91,6 +95,10 @@ z_spmConvertCSC2CSR( pastix_spm_t *spm )
if(spm-> dof != 1)
spm->colmajor = -1;
return result; return result;
...@@ -123,16 +131,53 @@ z_spmConvertIJV2CSR( pastix_spm_t *spm ) ...@@ -123,16 +131,53 @@ z_spmConvertIJV2CSR( pastix_spm_t *spm )
#endif #endif
pastix_int_t *spmptx, *otmp; pastix_int_t *spmptx, *otmp;
pastix_int_t i, j, tmp, baseval, total; pastix_int_t i, j, tmp, baseval, total;
pastix_spm_t oldspm; pastix_int_t row, col, dofi, dofj;
/* Backup the input */ pastix_int_t *node = calloc(spm->nnz+1,sizeof(pastix_int_t));
memcpy( &oldspm, spm, sizeof(pastix_spm_t) ); pastix_int_t *old_node = calloc(spm->nnz+1,sizeof(pastix_int_t));
* Check the baseval, we consider that arrays are sorted by columns or rows * Check the baseval, we consider that arrays are sorted by columns or rows
pastix_int_t ii, jj, k;
/* Transpose values in row major format */
if( spm->colmajor )
pastix_int_t cpt=0;
pastix_int_t* dofs = spm->dofs;
oavals++;
cpt += dofi * dofj;
#endif
/* Compute the new rowptr */ /* Compute the new rowptr */
spm->rowptr = (pastix_int_t *) calloc(spm->n+1,sizeof(pastix_int_t)); spm->rowptr = (pastix_int_t *) calloc(spm->n+1,sizeof(pastix_int_t));
...@@ -158,10 +203,39 @@ z_spmConvertIJV2CSR( pastix_spm_t *spm ) ...@@ -158,10 +203,39 @@ z_spmConvertIJV2CSR( pastix_spm_t *spm )
/* Sort the colptr and avals arrays by rows */ /* Sort the colptr and avals arrays by rows */
spm->colptr = malloc(spm->nnz * sizeof(pastix_int_t)); spm->colptr = malloc(spm->nnz * sizeof(pastix_int_t));
node[spm->rowptr[row]+1] += dofi * dofj;
spm->rowptr[row]++;
node[i+1]+=node[i];
/* Restore the rowptr indexes */
tmp = spm->rowptr[0];
spm->rowptr[0] = 0;
tmp2 = spm->rowptr[j+1];
spm->rowptr[j+1] = tmp;
tmp = tmp2;
#else #else
spm->values = malloc(spm->nnz * sizeof(pastix_complex64_t)); spm->values = malloc(spm->nnzexp * sizeof(pastix_complex64_t));
#endif #endif
...@@ -173,7 +247,17 @@ z_spmConvertIJV2CSR( pastix_spm_t *spm ) ...@@ -173,7 +247,17 @@ z_spmConvertIJV2CSR( pastix_spm_t *spm )
spm->colptr[ spm->rowptr[i] ] = oldspm.colptr[j]; spm->colptr[ spm->rowptr[i] ] = oldspm.colptr[j];
navals[ spm->rowptr[i] ] = oavals[j]; dofi = ( spm->dof > 0 ) ? spm->dof : dofs[i+1] - dofs[i];
dofj = ( spm->dof > 0 ) ? spm->dof : dofs[oldspm.colptr[j]-baseval+1] - dofs[oldspm.colptr[j]-baseval];
navals[node[spm->rowptr[i]]] = oavals[ old_node[j]];
old_node[j]++;
node[spm->rowptr[i]]++;
#endif #endif
(spm->rowptr[i])++; (spm->rowptr[i])++;
...@@ -195,7 +279,9 @@ z_spmConvertIJV2CSR( pastix_spm_t *spm ) ...@@ -195,7 +279,9 @@ z_spmConvertIJV2CSR( pastix_spm_t *spm )
spm->colmajor = -1;
...@@ -62,6 +63,37 @@ z_spmConvertCSC2IJV( pastix_spm_t *spm ) ...@@ -62,6 +63,37 @@ z_spmConvertCSC2IJV( pastix_spm_t *spm )
if( spm->colmajor < 1 ) //A test
int k, ii, jj, dofi, dofj;
int cpt = 0;
pastix_complex64_t* oavals = (pastix_complex64_t*)spm->values;
pastix_complex64_t* navals = malloc(sizeof(pastix_complex64_t)*spm->nnzexp);
pastix_int_t* dofs=spm->dofs;
i = col_ijv[k]-baseval;
oavals++;
cpt += dofi * dofj;
memFree_null(spm->colptr); memFree_null(spm->colptr);
spm->colptr = col_ijv; spm->colptr = col_ijv;
...@@ -113,6 +145,35 @@ z_spmConvertCSR2IJV( pastix_spm_t *spm ) ...@@ -113,6 +145,35 @@ z_spmConvertCSR2IJV( pastix_spm_t *spm )
/* Transpose values in column major format */
if( spm->colmajor > 1 )
pastix_int_t k, ii, jj, dofi, dofj;
pastix_int_t cpt=0;
j = row_ijv[k]-baseval;
oavals++;
cpt += dofi * dofj;
memFree_null(spm->rowptr); memFree_null(spm->rowptr);
spm->rowptr = row_ijv; spm->rowptr = row_ijv;
* @file z_spm_dofs2flat.c
* @version 5.1.0
* @date 2015-01-01
#include <stdint.h>
#include <stdlib.h>
#include <stdio.h>
#include <math.h>
#include <string.h>
#include <assert.h>
#include "pastix.h"
#include "common.h"
#include "spm.h"
#include "z_spm.h"
* z_spmDofs2Flat - Convert a sparse matrix with dofs into a sparse matrix without dofs.
* @param[in] spm
* The sparse matrix which needs to be converted
void
pastix_int_t i, j, k, ii, jj, dofi, dofj, col, row, baseval, cpt;
pastix_int_t *new_col = calloc(spm->nexp+1,sizeof(pastix_int_t));
pastix_int_t *new_row;
pastix_complex64_t *new_vals;
pastix_complex64_t *vals = (pastix_complex64_t*)spm->values;
switch(spm->mtxtype)
case PastixGeneral:
new_row = malloc(sizeof(pastix_int_t)*spm->nnzexp);
new_vals = malloc(sizeof(pastix_complex64_t)*spm->nnzexp);
for(i=0;i<spm->n ; i++)
col = ( spm->dof > 0 ) ? i : dofs[i];
for(k=spm->colptr[i]-baseval; k<spm->colptr[i+1]-baseval; k++)
new_col[col+ii+1] += dofj;
for(i=0; i<spm->nexp; i++)
new_col[i+1]+=new_col[i];
cpt = 0;
for(i=0; i < spm->n;i++)
for(k=spm->colptr[i]-baseval ; k<spm->colptr[i+1]-baseval ;k++)
j = spm->rowptr[k] - baseval;
for(ii=0;ii < dofi; ii++)
for(jj=0;jj < dofj ; jj++)
new_vals[new_col[col+ii]] = vals[cpt];
new_row[new_col[col+ii]] = row + jj + baseval;
new_col[col+ii]++;
cpt++;
int tmp;
int tmp1 = 0;
tmp = new_col[i];
new_col[i] = tmp1+baseval;
tmp1 = tmp;
new_col[i] += baseval;
spm->gN = spm->gNexp;
spm->n = spm->nexp;
spm->gnnz = spm->gnnzexp;
spm->nnz = spm->nnzexp;
spm->dof = 1;
spm->dofs = NULL;
spm->colmajor = 1;
spm->colptr = new_col;
spm->rowptr = new_row;
//spm->loc2glob = NULL; // ?
spm->values = new_vals;
break;
if( i != j )
new_col[col+ii+1] += 1;
else
if(ii <= jj )
new_col[i+1] += new_col[i];
pastix_int_t nnz = new_col[spm->nexp];
new_row = malloc(sizeof(pastix_int_t)*nnz);
new_vals = malloc(sizeof(pastix_complex64_t)*nnz);
cpt = 0;
if( i == j )
if ( ii <= jj )
/* diagonal dominant for spd matrix
if( ii == jj)
new_vals[new_col[col+ii]] = 2*vals[cpt];
else
new_col[col+ii]++;
else
new_col[col+ii]++;
cpt++;
int tmp;
int tmp1 = 0;
tmp = new_col[i];
tmp1 = tmp;
spm->n = spm->nexp;
spm->gnnz = nnz;
spm->nnz = nnz;
spm->gnnzexp = nnz;
spm->nnzexp = nnz;
spm->dof = 1;
spm->dofs = NULL;
spm->colmajor = 1;
break;
assert(spm->loc2glob == NULL);//to do
* @file z_spm_expand.c
* @version 5.1.0
* @date 2015-01-01
#include "common.h"
#include "spm.h"
#include "z_spm.h"
void z_extandCSC(pastix_spm_t* spm)
pastix_int_t col, row, i, cpt, dofj, dofi, baseval;
cpt=0;
pastix_complex64_t *valptr = (pastix_complex64_t*)spm->values;
pastix_complex64_t *newval = calloc(spm->nnzexp,sizeof(pastix_complex64_t));
for( col=0; col<spm->n; col++)
dofi = ( spm->dof > 0 ) ? spm->dof : spm->dofs[col+1] - spm->dofs[col];
dofj = ( spm->dof > 0 ) ? spm->dof : spm->dofs[spm->rowptr[row]-baseval+1] - spm->dofs[spm->rowptr[row]-baseval];
for( i=0; i<dofi*dofj; i++)
newval[cpt] = valptr[row] / ((i/dofj) + (i%dofj) + 2); // Col major
cpt++;
spm->values=newval;
...@@ -73,7 +73,9 @@ z_spmGeCSCv( int trans, ...@@ -73,7 +73,9 @@ z_spmGeCSCv( int trans,
const pastix_complex64_t *valptr = (pastix_complex64_t*)csc->values; const pastix_complex64_t *valptr = (pastix_complex64_t*)csc->values;
const pastix_complex64_t *xptr = x; const pastix_complex64_t *xptr = x;
pastix_complex64_t *yptr = y; pastix_complex64_t *yptr = y;
pastix_int_t col, row, i, baseval; pastix_int_t col, row, i, j, baseval;
pastix_int_t ii, jj, k, dofi, dofj;
pastix_int_t *dofs = csc->dofs;
if ( (csc == NULL) || (x == NULL) || (y == NULL ) ) if ( (csc == NULL) || (x == NULL) || (y == NULL ) )
...@@ -89,10 +91,10 @@ z_spmGeCSCv( int trans, ...@@ -89,10 +91,10 @@ z_spmGeCSCv( int trans,
/* first, y = beta*y */ /* first, y = beta*y */
if( beta == 0. ) { if( beta == 0. ) {
memset( yptr, 0, csc->gN * sizeof(pastix_complex64_t) ); memset( yptr, 0, csc->gNexp * sizeof(pastix_complex64_t) );
else { else {
for( i=0; i<csc->gN; i++, yptr++ ) { for( i=0; i<csc->gNexp; i++, yptr++ ) {
(*yptr) *= beta; (*yptr) *= beta;
yptr = y; yptr = y;
...@@ -104,12 +106,22 @@ z_spmGeCSCv( int trans, ...@@ -104,12 +106,22 @@ z_spmGeCSCv( int trans,
if( trans == PastixNoTrans ) if( trans == PastixNoTrans )
for( col=0; col < csc->gN; col++ ) for( i=0; i < csc->gN; i++ )
for( i=csc->colptr[col]; i<csc->colptr[col+1]; i++ ) dofi = ( csc->dof > 0 ) ? csc->dof : dofs[i+1] - dofs[i];
col = ( csc->dof > 0 ) ? i : dofs[i];
for( k=csc->colptr[i]; k<csc->colptr[i+1]; k++ )
row = csc->rowptr[i-baseval]-baseval; j = csc->rowptr[k-baseval]-baseval;
yptr[row] += alpha * valptr[i-baseval] * xptr[col]; dofj = ( csc->dof > 0 ) ? csc->dof : dofs[j+1] - dofs[j];
row = ( csc->dof > 0 ) ? j : dofs[j];
yptr[row+jj] += alpha * (*valptr) * xptr[col+ii];
...@@ -118,15 +130,26 @@ z_spmGeCSCv( int trans, ...@@ -118,15 +130,26 @@ z_spmGeCSCv( int trans,
else if( trans == PastixTrans ) else if( trans == PastixTrans )
yptr[col] += alpha * valptr[i-baseval] * xptr[row]; dofj = ( csc->dof > 0 ) ? csc->dof : dofs[j+1] - dofs[j];
yptr[col+ii] += alpha * (*valptr) * xptr[row+jj];
#if defined(PRECISION_c) || defined(PRECISION_z) #if defined(PRECISION_c) || defined(PRECISION_z)
else if( trans == PastixConjTrans ) else if( trans == PastixConjTrans )
...@@ -145,7 +168,6 @@ z_spmGeCSCv( int trans, ...@@ -145,7 +168,6 @@ z_spmGeCSCv( int trans,
return PASTIX_ERR_BADPARAMETER; return PASTIX_ERR_BADPARAMETER;
...@@ -194,7 +216,9 @@ z_spmSyCSCv( pastix_complex64_t alpha, ...@@ -194,7 +216,9 @@ z_spmSyCSCv( pastix_complex64_t alpha,
...@@ -210,30 +234,40 @@ z_spmSyCSCv( pastix_complex64_t alpha, ...@@ -210,30 +234,40 @@ z_spmSyCSCv( pastix_complex64_t alpha,
/* First, y = beta*y */ /* First, y = beta*y */
else { else {
yptr = y; yptr = y;
if( alpha != 0. ) { if(alpha != 0.)
for( col=0; col < csc->gN; col++ ) {
for( i=csc->colptr[col]; i < csc->colptr[col+1]; i++ ) dofi = ( csc->dof > 0 ) ? csc->dof : dofs[i+1] - dofs[i];
if( col != row ) row = ( csc->dof > 0 ) ? j : dofs[j];
yptr[col] += alpha * valptr[i-baseval] * xptr[row]; for(jj=0; jj<dofj; jj++, valptr++)
if( i != j )
...@@ -283,7 +317,9 @@ z_spmHeCSCv( pastix_complex64_t alpha, ...@@ -283,7 +317,9 @@ z_spmHeCSCv( pastix_complex64_t alpha,
...@@ -297,30 +333,41 @@ z_spmHeCSCv( pastix_complex64_t alpha, ...@@ -297,30 +333,41 @@ z_spmHeCSCv( pastix_complex64_t alpha,
else { else {
yptr = y; yptr = y;
baseval = spmFindBase( csc ); baseval = spmFindBase( csc );
if( alpha != 0.)
if( alpha != 0. ) { {
row=csc->rowptr[i-baseval]-baseval; j = csc->rowptr[k-baseval]-baseval;
yptr[col] += alpha * conj( valptr[i-baseval] ) * xptr[row]; for(ii=0; ii<dofi; ii++)
if( i != j )
yptr[col+ii] += alpha * conj( *valptr ) * xptr[row+jj];
#endif #endif
...@@ -50,7 +50,7 @@ z_spmFrobeniusNorm( const pastix_spm_t *spm ) ...@@ -50,7 +50,7 @@ z_spmFrobeniusNorm( const pastix_spm_t *spm )
double sumsq = 0.; double sumsq = 0.;
if (spm->mtxtype == PastixGeneral) { if (spm->mtxtype == PastixGeneral) {
for(i=0; i <spm->nnz; i++, valptr++) { for(i=0; i <spm->nnzexp; i++, valptr++) {
frobenius_update( 1, &scale, &sumsq, valptr ); frobenius_update( 1, &scale, &sumsq, valptr );
...@@ -62,20 +62,32 @@ z_spmFrobeniusNorm( const pastix_spm_t *spm ) ...@@ -62,20 +62,32 @@ z_spmFrobeniusNorm( const pastix_spm_t *spm )
else { else {
pastix_int_t *colptr = spm->colptr; pastix_int_t *colptr = spm->colptr;
pastix_int_t *rowptr = spm->rowptr; pastix_int_t *rowptr = spm->rowptr;
int nb; pastix_int_t *dofs = spm->dofs;
int nb, dofi, dofj, ii, jj;
switch( spm->fmttype ){ switch( spm->fmttype ){
case PastixCSC: case PastixCSC:
for(i=0; i<spm->n; i++, colptr++) { for(i=0; i<spm->n; i++, colptr++)
for(j=colptr[0]; j<colptr[1]; j++, rowptr++, valptr++) { {
nb = ( i == (*rowptr-baseval) ) ? 1 : 2; dofi = ( spm->dof > 0 ) ? spm->dof : dofs[i+1] - dofs[i];
frobenius_update( nb, &scale, &sumsq, valptr ); for(j=colptr[0]; j<colptr[1]; j++, rowptr++)
dofj = ( spm->dof > 0 ) ? spm->dof : dofs[(*rowptr-baseval)+1] - dofs[(*rowptr-baseval)];
for(ii=0 ; ii < dofi; ii++)
for(jj=0; jj < dofj ;jj++,valptr++)
valptr++; valptr++;
frobenius_update( nb, &scale, &sumsq, valptr ); frobenius_update( nb, &scale, &sumsq, valptr );
#endif #endif
break; break;
...@@ -139,11 +151,10 @@ z_spmMaxNorm( const pastix_spm_t *spm ) ...@@ -139,11 +151,10 @@ z_spmMaxNorm( const pastix_spm_t *spm )
pastix_complex64_t *valptr = (pastix_complex64_t*)spm->values; pastix_complex64_t *valptr = (pastix_complex64_t*)spm->values;
double tmp, norm = 0.; double tmp, norm = 0.;
for(i=0; i <spm->nnz; i++, valptr++) { for(i=0; i < spm->nnzexp; i++, valptr++) {
tmp = cabs( *valptr ); tmp = cabs( *valptr );
norm = norm > tmp ? norm : tmp; norm = norm > tmp ? norm : tmp;
return norm; return norm;
...@@ -171,22 +182,37 @@ z_spmMaxNorm( const pastix_spm_t *spm ) ...@@ -171,22 +182,37 @@ z_spmMaxNorm( const pastix_spm_t *spm )
double double
z_spmInfNorm( const pastix_spm_t *spm ) z_spmInfNorm( const pastix_spm_t *spm )
pastix_int_t col, row, i, baseval; pastix_int_t col, row, i, j, k, ii, jj, baseval;
double norm = 0.; double norm = 0.;
double *sumcol; double *sumcol;
MALLOC_INTERN( sumcol, spm->gN, double ); MALLOC_INTERN( sumcol, spm->gNexp, double );
memset( sumcol, 0, spm->gN * sizeof(double) ); memset( sumcol, 0, spm->gNexp * sizeof(double) );
for( col=0; col < spm->gN; col++ ) for( i=0; i < spm->n; i++)
for( i=spm->colptr[col]-baseval; i<spm->colptr[col+1]-baseval; i++ ) dofi = ( spm->dof > 0 ) ? spm->dof : dofs[i+1] - dofs[i];
for(k=spm->colptr[i]; k < spm->colptr[i+1]; k++)
sumcol[spm->rowptr[i]-baseval] += cabs( valptr[i] ); j = spm->rowptr[k - baseval] - baseval;
for(ii=0; ii < dofi; ii++)
for(jj=0; jj < dofj; jj++, valptr++)
sumcol[row + jj] += cabs( *valptr );
...@@ -194,11 +220,29 @@ z_spmInfNorm( const pastix_spm_t *spm ) ...@@ -194,11 +220,29 @@ z_spmInfNorm( const pastix_spm_t *spm )
if ( (spm->mtxtype == PastixHermitian) || if ( (spm->mtxtype == PastixHermitian) ||
(spm->mtxtype == PastixSymmetric) ) (spm->mtxtype == PastixSymmetric) )
for( col=0; col < spm->gN; col++ ) valptr = (pastix_complex64_t*)spm->values;
for(i=0; i < spm->n; i++)
for( i=spm->colptr[col]-baseval+1; i<spm->colptr[col+1]-baseval; i++ ) col = ( spm->dof > 0 ) ? i : dofs[i];
sumcol[col] += cabs( valptr[i] ); j = spm->rowptr[k - baseval] - baseval;
if(i != j)
sumcol[col + ii] += cabs( *valptr );
else
valptr += dofi * dofj;
...@@ -250,7 +294,7 @@ z_spmInfNorm( const pastix_spm_t *spm ) ...@@ -250,7 +294,7 @@ z_spmInfNorm( const pastix_spm_t *spm )
for( i=0; i<spm->gN; i++) for( i=0; i<spm->gNexp; i++)
if(norm < sumcol[i]) if(norm < sumcol[i])
...@@ -286,22 +330,37 @@ z_spmInfNorm( const pastix_spm_t *spm ) ...@@ -286,22 +330,37 @@ z_spmInfNorm( const pastix_spm_t *spm )
double double
z_spmOneNorm( const pastix_spm_t *spm ) z_spmOneNorm( const pastix_spm_t *spm )
double *sumrow; double *sumrow;
MALLOC_INTERN( sumrow, spm->gN, double ); MALLOC_INTERN( sumrow, spm->gNexp, double );
memset( sumrow, 0, spm->gN * sizeof(double) ); memset( sumrow, 0, spm->gNexp * sizeof(double) );
for( col=0; col < spm->gN; col++ ) for(i=0; i < spm->n; i++)
for( i=spm->colptr[col]-baseval; i<spm->colptr[col+1]-baseval; i++ ) col = ( spm->dof > 0 ) ? i : dofs[i];
sumrow[col] += cabs( valptr[i] ); j = spm->rowptr[k - baseval] - baseval;
sumrow[col + ii] += cabs( *valptr );
...@@ -309,11 +368,29 @@ z_spmOneNorm( const pastix_spm_t *spm ) ...@@ -309,11 +368,29 @@ z_spmOneNorm( const pastix_spm_t *spm )
for( i=spm->colptr[col]-baseval+1; i<spm->colptr[col+1]-baseval; i++ ) dofi = ( spm->dof > 0 ) ? spm->dof : dofs[i+1] - dofs[i];
sumrow[spm->rowptr[i]-baseval] += cabs( valptr[i] ); j = spm->rowptr[k - baseval] - baseval;
if(i != j)
sumrow[row + jj] += cabs( *valptr );
else
...@@ -365,7 +442,7 @@ z_spmOneNorm( const pastix_spm_t *spm ) ...@@ -365,7 +442,7 @@ z_spmOneNorm( const pastix_spm_t *spm )
if(norm < sumrow[i]) if(norm < sumrow[i])
* @file z_spm_print.c
* @version 5.1.0
* @date 2015-01-01
#include <stdint.h>
#include <stdlib.h>
#include <stdio.h>
#include <math.h>
#include <string.h>
#include <assert.h>
#include "pastix.h"
#include "common.h"
#include "spm.h"
#include "z_spm.h"
void
pastix_int_t i, j, baseval;
pastix_complex64_t *valptr;
pastix_int_t *colptr, *rowptr, *dofs;
i = 0; j = 0;
dofs = spm->dofs;
col = dofs[i];
row = dofs[j];
row + jj, col + ii, *valptr );
if (i != j) {
col + ii, row + jj, conj(*valptr) );
break;
#endif
col = dofs[i];
row = dofs[j];
if (i != j) {
col + ii, row + jj, *valptr );
break;
case PastixGeneral:
default:
col = dofs[i];
row = dofs[j];
return;
