Commit df359214 authored by PICHON Gregoire's avatar PICHON Gregoire
update PR
parent 8195797e
......@@ -97,7 +97,7 @@ laplacian_usage(void)
* @retval PASTIX_ERR_BADPARAMETER if the configuration string is incorrect
static inline int
int
laplacian_parse_info( const char *filename,
pastix_spm_t *spm,
pastix_int_t *dim1,
......@@ -32,4 +32,12 @@ void d_spmExtendedLaplacian3D( pastix_spm_t *spm, pastix_int_t dim1, pastix_int_
void s_spmExtendedLaplacian3D( pastix_spm_t *spm, pastix_int_t dim1, pastix_int_t dim2, pastix_int_t dim3 );
void p_spmExtendedLaplacian3D( pastix_spm_t *spm, pastix_int_t dim1, pastix_int_t dim2, pastix_int_t dim3 );
int laplacian_parse_info( const char *filename,
pastix_spm_t *spm,
pastix_int_t *dim1,
pastix_int_t *dim2,
pastix_int_t *dim3,
double *alpha,
double *beta );
#endif /* _laplacian_h_ */
