Commit dbe9c7f8 authored by Mathieu Faverge's avatar Mathieu Faverge
Add comme spm2dense function
parent cbe40777
...@@ -305,6 +305,43 @@ spmConvert( int ofmttype, pastix_spm_t *spm ) ...@@ -305,6 +305,43 @@ spmConvert( int ofmttype, pastix_spm_t *spm )
* @ingroup pastix_spm
* @brief Convert the spm matrix into a dense matrix for test purpose. DO NOT
* USE with large matrices.
* @param[in,out] spm
* The sparse matrix structure to convert.
* @return
* The pointer to the allocated array storing the dense version of the
* matrix.
void *
spm2Dense( const pastix_spm_t *spm )
switch (spm->flttype) {
case PastixFloat:
return s_spm2dense( spm );
case PastixComplex32:
return c_spm2dense( spm );
case PastixComplex64:
return z_spm2dense( spm );
case PastixDouble:
return d_spm2dense( spm );
default:
return NULL;
...@@ -126,6 +126,7 @@ void spmExit( pastix_spm_t *spm ); ...@@ -126,6 +126,7 @@ void spmExit( pastix_spm_t *spm );
pastix_spm_t *spmCopy( const pastix_spm_t *spm ); pastix_spm_t *spmCopy( const pastix_spm_t *spm );
void spmBase( pastix_spm_t *spm, int baseval ); void spmBase( pastix_spm_t *spm, int baseval );
int spmConvert( int ofmttype, pastix_spm_t *ospm ); int spmConvert( int ofmttype, pastix_spm_t *ospm );
void * spm2Dense( const pastix_spm_t *spm );
pastix_int_t spmFindBase( const pastix_spm_t *spm ); pastix_int_t spmFindBase( const pastix_spm_t *spm );
double spmNorm( int ntype, const pastix_spm_t *spm ); double spmNorm( int ntype, const pastix_spm_t *spm );
int spmMatVec(const pastix_trans_t trans, const void *alpha, const pastix_spm_t *spm, const void *x, const void *beta, void *y ); int spmMatVec(const pastix_trans_t trans, const void *alpha, const pastix_spm_t *spm, const void *x, const void *beta, void *y );
