Commit b89aec1c authored by PICHON Gregoire's avatar PICHON Gregoire
add example with compression and remove useless scaling without compression
parent 63f5c9ad
...@@ -25,6 +25,8 @@ ...@@ -25,6 +25,8 @@
#include "s_spm.h" #include "s_spm.h"
#include "p_spm.h" #include "p_spm.h"
#include <cblas.h>
#if !defined(DOXYGEN_SHOULD_SKIP_THIS) #if !defined(DOXYGEN_SHOULD_SKIP_THIS)
static int (*conversionTable[3][3][6])(pastix_spm_t*) = { static int (*conversionTable[3][3][6])(pastix_spm_t*) = {
...@@ -1179,7 +1181,7 @@ spmCheckAxb( int nrhs, ...@@ -1179,7 +1181,7 @@ spmCheckAxb( int nrhs,
void void
spmScal(const pastix_complex64_t alpha, pastix_spm_t* spm) spmScalMatrix(const pastix_complex64_t alpha, pastix_spm_t* spm)
switch(spm->flttype) switch(spm->flttype)
...@@ -1200,6 +1202,47 @@ spmScal(const pastix_complex64_t alpha, pastix_spm_t* spm) ...@@ -1200,6 +1202,47 @@ spmScal(const pastix_complex64_t alpha, pastix_spm_t* spm)
* @brief Scale a vector according to the spm type.
* x = alpha * x
* @param[in] alpha
* The scaling parameter.
* @param[in] spm
* The spm structure to know the type of the vector.
* @param[inout] x
* The vector to scal.
void
spmScalVector(const double alpha, pastix_spm_t* spm, void *x)
case PastixPattern:
break;
case PastixFloat:
cblas_sscal(spm->n, alpha, x, 1);
break;
case PastixComplex32:
cblas_csscal(spm->n, alpha, x, 1);
break;
case PastixComplex64:
cblas_zdscal(spm->n, alpha, x, 1);
break;
case PastixDouble:
default:
cblas_dscal(spm->n, alpha, x, 1);
...@@ -90,7 +90,8 @@ void spmUpdateComputedFields( pastix_spm_t *spm ); ...@@ -90,7 +90,8 @@ void spmUpdateComputedFields( pastix_spm_t *spm );
double spmNorm( pastix_normtype_t ntype, const pastix_spm_t *spm ); double spmNorm( pastix_normtype_t ntype, const pastix_spm_t *spm );
int spmMatVec(const pastix_trans_t trans, const void *alpha, const pastix_spm_t *spm, const void *x, const void *beta, void *y ); int spmMatVec(const pastix_trans_t trans, const void *alpha, const pastix_spm_t *spm, const void *x, const void *beta, void *y );
void spmScal( const pastix_complex64_t alpha, pastix_spm_t* spm ); void spmScalMatrix( const pastix_complex64_t alpha, pastix_spm_t* spm );
void spmScalVector( const double alpha, pastix_spm_t* spm, void *x );
