GitLab
Explore
Primary navigation
Search or go to…
spm
Manage
Plan
Issue boards
Code
Merge requests
Repository graph
Compare revisions
Deploy
Container Registry
Model registry
Monitor
Incidents
Service Desk
Analyze
Value stream analytics
Contributor analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
solverstack
spm
b8979792
b8979792
7 years ago
Mathieu Faverge
Downloads
Patches
Big cleanup in the getopt call and add the spmPrintInfo call to examples
f886b4c1
Loading
2
2 changed files
drivers/laplacian.c
+2
-2
2 additions, 2 deletions
drivers/laplacian.c
spm_read_driver.c
+1
-11
1 addition, 11 deletions
spm_read_driver.c
3 additions
13 deletions
drivers/laplacian.c
2
2
b8979792
@@ -90,9 +90,9 @@ laplacian_parse_info( const char *filename,
/* Look for the datatype */
char
flt
char
flt
char
tmpf
strdup
filename
char
tmpf
str
n
dup
filename
256
if
sscanf
filename
"%c:%25
6
s"
flt
tmpf
2
if
sscanf
filename
"%c:%25
4
s"
flt
tmpf
2
filename
2
filename
2
switch
flt
switch
flt
case
'Z'
case
'Z'
This diff is collapsed.
spm_read_driver.c
11
b8979792
@@ -88,29 +88,22 @@ spmReadDriver( pastix_driver_t driver,
case
PastixDriverHB
case
PastixDriverHB
/* TODO: Possible to read the RHS, the solution or a guess of the solution */
printf
"driver: HB file: %s
\n
filename
readHB
filename
spm
readHB
filename
spm
break
break
case
PastixDriverIJV
case
PastixDriverIJV
printf
"driver: 3files file: %s
\n
filename
readIJV
filename
spm
readIJV
filename
spm
break
break
case
PastixDriverMM
case
PastixDriverMM
printf
"driver: MatrixMarket file: %s
\n
filename
readMM
filename
spm
readMM
filename
spm
break
break
case
PastixDriverLaplacian
case
if
mpirank
printf
"driver Laplacian: %s
\n
filename
genLaplacian
filename
spm
genLaplacian
filename
spm
break
break
case
PastixDriverXLaplacian
case
if
mpirank
printf
"driver Extended Laplacian: %s
\n
filename
genExtendedLaplacian
filename
spm
filename
spm
break
break
@@ -148,7 +141,7 @@ spmReadDriver( pastix_driver_t driver,
break
break
default:
default:
fprintf
stderr
d
river: Driver not implemented
\n
fprintf
stderr
spmReadD
\n
@@ -159,9 +152,6 @@ spmReadDriver( pastix_driver_t driver,
MPI_Bcast
spm
sizeof
pastix_spm_t
MPI_CHAR
comm
MPI_Bcast
spm
sizeof
pastix_spm_t
MPI_CHAR
comm
MPI_Bcast
nnz
PASTIX_MPI_INT
comm
MPI_Bcast
nnz
PASTIX_MPI_INT
comm
fprintf
stderr
"%d: mtxtype=%d, flttype=%d, nnz=%ld, gN=%ld
\n
mpirank
spm
mtxtype
spm
flttype
long
nnz
long
spm
gN
if
mpirank
if
mpirank
spm
colptr
pastix_int_t
malloc
spm
gN
sizeof
pastix_int_t
spm
colptr
pastix_int_t
malloc
spm
gN
sizeof
pastix_int_t
Loading
Save comment
