Commit aedad4bc authored by Mathieu Faverge's avatar Mathieu Faverge
Protect Fortran files and fix undeclared warnings
parent d87566f3
...@@ -67,16 +67,22 @@ set(spm_sources ...@@ -67,16 +67,22 @@ set(spm_sources
spm_dof_extend.c spm_dof_extend.c
spm_read_driver.c spm_read_driver.c
spm_gen_fake_values.c spm_gen_fake_values.c
drivers/skitf.f
drivers/iohb.c drivers/iohb.c
drivers/mmio.c drivers/mmio.c
drivers/laplacian.c drivers/laplacian.c
drivers/readhb.c drivers/readhb.c
drivers/readijv.c drivers/readijv.c
drivers/readmm.c drivers/readmm.c
drivers/readrsa.c
if (PASTIX_WITH_FORTRAN)
set(spm_sources
${spm_sources}
drivers/skitf.f
drivers/readrsa.c
endif()
add_library(pastix_spm add_library(pastix_spm
${spm_sources} ${spm_sources}
...@@ -82,10 +82,11 @@ spmReadDriver( pastix_driver_t driver, ...@@ -82,10 +82,11 @@ spmReadDriver( pastix_driver_t driver,
switch(driver) switch(driver)
#if defined(PASTIX_WITH_FORTRAN)
case PastixDriverRSA: case PastixDriverRSA:
readRSA( filename, spm ); readRSA( filename, spm );
break; break;
#endif
case PastixDriverHB: case PastixDriverHB:
/* TODO: Possible to read the RHS, the solution or a guess of the solution */ /* TODO: Possible to read the RHS, the solution or a guess of the solution */
readHB( filename, spm ); readHB( filename, spm );
