Commit 9c9ecb99 authored by PICHON Gregoire's avatar PICHON Gregoire
remove spm from laplacian parsing
parent df359214
......@@ -70,11 +70,8 @@ laplacian_usage(void)
* Configuration string of the Laplacian. See laplacian_usage() for
* more information.
* @param[inout] spm
* At start, an allocated spm structure that will store the Lapalcian
* matrix.
* At exit, the fields of the spm are initialized and especially the
* type, symmetry and number of unknows are setup.
* @param[out] flttype
* The floating type of the elements in the matrix.
* @param[out] dim1
* The first dimension of the laplacian
......@@ -98,20 +95,16 @@ laplacian_usage(void)
int
laplacian_parse_info( const char *filename,
pastix_spm_t *spm,
pastix_int_t *dim1,
pastix_int_t *dim2,
pastix_int_t *dim3,
double *alpha,
double *beta )
pastix_coeftype_t *flttype,
pastix_int_t *dim1,
pastix_int_t *dim2,
pastix_int_t *dim3,
double *alpha,
double *beta )
double val1, val2;
long tmp1, tmp2, tmp3;
spm->colptr = NULL;
spm->rowptr = NULL;
spm->values = NULL;
spm->loc2glob = NULL;
*alpha = 1.;
*beta = 1.;
......@@ -126,27 +119,27 @@ laplacian_parse_info( const char *filename,
switch( flt ){
case 'Z':
case 'z':
spm->flttype = PastixComplex64;
*flttype = PastixComplex64;
break;
case 'C':
case 'c':
spm->flttype = PastixComplex32;
*flttype = PastixComplex32;
break;
case 'D':
case 'd':
spm->flttype = PastixDouble;
*flttype = PastixDouble;
break;
case 'S':
case 's':
spm->flttype = PastixFloat;
*flttype = PastixFloat;
break;
case 'P':
case 'p':
spm->flttype = PastixPattern;
*flttype = PastixPattern;
break;
case '1':
......@@ -158,7 +151,7 @@ laplacian_parse_info( const char *filename,
case '7':
case '8':
case '9':
* The first dimension is only one character long so we come
* back to the beginning of the string
......@@ -172,7 +165,7 @@ laplacian_parse_info( const char *filename,
else {
free(tmpf);
......@@ -187,29 +180,24 @@ laplacian_parse_info( const char *filename,
*dim3 = (pastix_int_t)tmp3;
*alpha = val1;
*beta = val2;
spm->gN = (*dim1)*(*dim2)*(*dim3);
else if ( sscanf( filename, "%ld:%ld:%ld:%lf", &tmp1, &tmp2, &tmp3, &val1 ) == 4 ) {
*dim1 = (pastix_int_t)tmp1;
*dim2 = (pastix_int_t)tmp2;
*alpha = val1;
else if ( sscanf( filename, "%ld:%ld:%ld", &tmp1, &tmp2, &tmp3 ) == 3 ) {
else if ( sscanf( filename, "%ld:%ld", &tmp1, &tmp2 ) == 2 ) {
spm->gN = (*dim1)*(*dim2);
else if ( sscanf( filename, "%ld", &tmp1 ) == 1 ) {
spm->gN = *dim1;
else {
laplacian_usage();
......@@ -217,12 +205,11 @@ laplacian_parse_info( const char *filename,
/* One of the dimension was set to 0 */
if ( spm->gN == 0 ) {
if ( (*dim1 == 0) || (*dim2 == 0) || (*dim3 == 0) ) {
laplacian_usage();
return PASTIX_ERR_BADPARAMETER;
spm->n = spm->gN;
return PASTIX_SUCCESS;
......@@ -292,15 +279,19 @@ int
genLaplacian( const char *filename,
pastix_spm_t *spm )
pastix_coeftype_t flttype;
pastix_int_t dim1, dim2, dim3;
double alpha = 1.;
double beta = 1.;
int rc;
rc = laplacian_parse_info(filename, spm, &dim1, &dim2, &dim3, &alpha, &beta );
rc = laplacian_parse_info(filename, &flttype, &dim1, &dim2, &dim3, &alpha, &beta );
if (rc != PASTIX_SUCCESS)
return rc;
spm->flttype = flttype;
spm->n = spm->gN = dim1 * dim2 * dim3;
laplacian_7points[spm->flttype](spm, dim1, dim2, dim3, alpha, beta);
......@@ -342,15 +333,19 @@ int
genExtendedLaplacian( const char *filename,
pastix_spm_t *spm )
double alpha = 1.;
double beta = 1.;
int rc;
rc = laplacian_parse_info(filename, spm, &dim1, &dim2, &dim3, &alpha, &beta);
rc = laplacian_parse_info(filename, &flttype, &dim1, &dim2, &dim3, &alpha, &beta);
return rc;
if( dim3 > 0 ) {
extended_laplacian_table3D[spm->flttype](spm, dim1, dim2, dim3);
......@@ -32,12 +32,12 @@ void d_spmExtendedLaplacian3D( pastix_spm_t *spm, pastix_int_t dim1, pastix_int_
void s_spmExtendedLaplacian3D( pastix_spm_t *spm, pastix_int_t dim1, pastix_int_t dim2, pastix_int_t dim3 );
void p_spmExtendedLaplacian3D( pastix_spm_t *spm, pastix_int_t dim1, pastix_int_t dim2, pastix_int_t dim3 );
int laplacian_parse_info( const char *filename,
pastix_spm_t *spm,
pastix_int_t *dim1,
pastix_int_t *dim2,
pastix_int_t *dim3,
double *alpha,
double *beta );
pastix_int_t *dim1,
pastix_int_t *dim2,
pastix_int_t *dim3,
double *alpha,
double *beta );
#endif /* _laplacian_h_ */
......@@ -44,7 +44,7 @@
typedef struct pastix_spm_s {
pastix_mtxtype_t mtxtype; /**< Matrix structure: PastixGeneral, PastixSymmetric
or PastixHermitian. */
pastix_coeftype_t flttype; /**< avals datatype: PastixPattern, PastixFloat, PastixDouble,
pastix_coeftype_t flttype; /**< avails datatype: PastixPattern, PastixFloat, PastixDouble,
PastixComplex32 or PastixComplex64 */
pastix_fmttype_t fmttype; /**< Matrix storage format: PastixCSC, PastixCSR, PastixIJV */
